nico200
- 13 mrt 2003
Ik wil een registersleutel toevoegen maar ik weet niet hoe. Lees het volgende verhaal:
Wooohooo...I found a way to do this finally... Its there in sourceforge gimp-win-remote zip file download. README file says all about how to pass files from other applications..
Key is putting this value in registry. After updating the registry.. use gimp-win-remote.exe as binary in external app that is passing the image.
Optional/Advanced:
If you would like to use a third party application to send files to GIMP, an
optional registry value is available which eliminates the need for specifying
the GIMP binary/version on the command line. This can be helpful with
applications that do not allow you to add this parameter.
Save the following between the dashes to a "gimp-win-remote.reg", and remember
to change the gimp-2.2.exe to the version you wish to run. Please note that to
execute the new "gimp-win-remote.reg file will require administrative rights.
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\GNU\gimp-win-remote]
@="gimp-2.2.exe"
Wat moet ik doen. Ik begrijp het niet helemaal.
Bij voorbaat dank.
Nico
Optional/Advanced:
REGEDIT4
@="gimp-2.2.exe"
Bij voorbaat dank.
Nico
