InitSmileys()
ScanForSmileys()
Dim SmileyTable As Hashtable
Dim MaxStringLen As Integer
Public Sub InitSmileys()
SmileyTable = New Hashtable(3)
SmileyTable.Add(": D", New Bitmap(My.Resources.icon_cheesygrin))
SmileyTable.Add(": @", New Bitmap(My.Resources.icon_evil))
SmileyTable.Add(": |", New Bitmap(My.Resources.icon_neutral))
SmileyTable.Add(": (", New Bitmap(My.Resources.icon_sad))
MaxStringLen = 3 'the largest length of an emoticon value
Public Sub DisposeSmileys()
For Each img As Image In SmileyTable.Values
img.Dispose()
Next
SmileyTable.Clear()
SmileyTable = Nothing
Private Sub ScanForSmileys()
'Loop through all indices (chars) of the RichTextBox
For i As Integer = 0 To RichTextBox1.TextLength - 1
Dim remaininglength As Integer = RichTextBox1.TextLength - i 'the trailing length
'for each possible length
For emlength As Integer = MaxStringLen To 1 Step -1
If emlength <= remaininglength Then
'check if this value of this length exists in the hashtable
Dim lengthtext As String = RichTextBox1.Text.Substring(i, emlength) 'the part of the text ':)' for example with length 2
Dim replacewithimage As Image = SmileyTable.Item(lengthtext) 'get item
If Not IsNothing(replacewithimage) Then 'check if it is found
'replace
RichTextBox1.Select(i, emlength)
Clipboard.SetDataObject(replacewithimage)
RichTextBox1.Paste()
Exit For
Next
Next
