This task loads the MSN Queue Manager and is installed when you install MSN Explorer or MSN Messenger. LOADQM gobbles up system resources and appears on most end-users’ Task Lists who come to us complaining of low System & User Resources or very slow, “crawling”, PCs. In December 2003 this is still one of the worst behaved Microsoft programs !
Recommendation :
Disable immediately, or Delete using The Ultimate Troubleshooter. Next, reboot your PC and find LOADQM in the C:\WINDOWS folder. Rename it to LOADQM.EXE.OLD as if you do not it will otherwise get put back in your Task List at some stage or other (on some PCs you may need to boot into Safe Mode before you are able to rename LOADQM). Note : LOADQM gets re‑installed every time you install a new version of Microsoft’s MSN Messenger.
