Synctoy Schedule
Julius
1 jul 2004
Wie kan mij helpen
Probeer synctoy als taak te plannen bij opstarten te syncroniseren wat kan volgens Microsoft MAAR het lukt mij niet dit goed in te stellen
Men wil ergens achter de opdracht "-R" hebben
Maar waar moet ik dat nu instellen ????
:mad: :mad: :mad:
Wie kan mij helpen
Ik neem aan dat 'men' dat meldt in een scherm? zou je dat hier eens kunnen neerzetten? zodat we weten wat er precies gezegd wordt?
Dit staat er in de gebruiks aanwijzing van het programmma
Windows XP
To schedule a task using the operating system:
From the Start menu, select All Programs - Accessories - System Tools - Scheduled Tasks.
Select Add scheduled task to start the Scheduled Task Wizard. You will see a list of possible programs to run.
SyncToy may appear as an option in the list. If SyncToy does not appear in the list, click Browse and go find it.
The wizard will next prompt you to enter how often you want to run the scheduled SyncToy (for example, daily, weekly, et cetera). Select a frequency.
The next page asks when to start the task. Select a start time.
The next page asks for the user name and password to run the program under. Enter your user name and password.
The final page contains an option to open the properties dialog when the wizard ends. Select this checkbox.
Modify the Run textbox to include the –R command line option. –R all by itself will run all folder pairs that are active for run all. If you want to run just a single folder pair, add –R“My Pair” to the end of the command line. Note: there is a space before the hyphen but not one after the R. If the folder pair name contains a space, surround it with quotation marks, as the example above shows. For another example, assume that SyncToy is in the folder named C:\My Folder and that you want to run a folder pair named "My folder pair." Enter the command line as follows, including the quotation marks: "C:\My Folder\SyncToy.exe" -R"My folder pair." Note that there are two sets of quotation marks in this case: one is around the path to the SyncToy program file and the other surrounds the folder pair name.
Het is opgelost Je moet wel een wachtwoordt bij Windows account aanmaken anders werkt het niet
Ook de wachtwoorden in Synctoy moeten aangemaakt zijn
:p :p :p :p :p
