Uit Help van M1.6
Zal dus ongetwijfeld ook wel in M1.7 zitten ;(
Navigator Preferences - Tabbed Browsing
This section describes how to use the Tabbed Browsing preferences panel. If you're not already viewing it, follow these steps:
1. Open the Edit menu and choose Preferences.
2. Under the Navigator category, click Tabbed Browsing. (If no subcategories are visible, double-click Navigator to expand the list.)
The Tabbed Browsing preferences panel allows you to set up Tabbed Browsing:
Note: On Mac OS, where instructed to press Control (Ctrl), press Command instead.
* Tab Display:
o Hide the tab bar when only one tab is open: Select this to display the Tabbed Browsing bar only when more then one Navigator tab is open.
o Load links in the background: Select this to prevent Mozilla from switching to a new tab when using "Open in a New Tab" to open a link.
* Open tabs instead of windows for:
o Middle-click or control-click of links in a Web page: Select this to open web page links in a new tab when clicking a link with the middle mouse button or while pressing Ctrl.
o Control+Enter in the Location bar: Select this to open a web-page link in a new tab when you type a URL in the Location Bar and press Ctrl+Enter.
Opening Tabs
You can open a Navigator tab in the following ways:
Opening a New Blank Navigator Tab:
* From the File menu: Open the File menu, choose New, and then New Navigator Tab.
* From the Tab Bar: If visible, click the "new tab" icon on the left side of the Tab Bar.
* From a pop-up menu: If the Tab Bar is visible, right-click on it, and choose New Tab from the pop.
Opening a Web Page Link in a Navigator Tab:
* From a pop-up menu: Right-click on a web page link and choose Open Link in New Tab. (To right-click on Mac OS, press Ctrl and click the mouse button.)
* From the Location Bar: Type a web page location in the Location Bar and press Ctrl+Enter. (On Mac, press Cmd+Enter)
Note: You must set your Tabbed Browsing preferences to open a Navigator tab from the Location Bar. See Navigator Preferences - Tabbed Browsing for more information.
Tips:
To quickly open a new blank Navigator tab, press Ctrl+T.
* To reload one or all Navigator tabs, right-click anywhere on the Tab Bar and select Reload Tab or Reload All Tabs, respectively.
