Uitlezen minidump
Bramzzz
3 dec 2004
Hallo allemaal,
Ik zat net een spelletje te spelen en toen rebootte mn pc opeens. Ik heb de .dmp uitgelezen met de debugging tool van windows. Ik kom er echter geen wijs uit. Kan iemand iets uit onderstaande dump halen?
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini031810-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c720
Debug session time: Thu Mar 18 21:10:51.187 2010 (GMT+1)
System Uptime: 0 days 2:19:53.878
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image ati2cqag.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ati2cqag.dll
*** ERROR: Module load completed but symbols could not be loaded for ati2cqag.dll
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {eb47f794, 0, bf08fac6, 1}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : ati2cqag.dll ( ati2cqag+29ac6 )
Followup: MachineOwner
Alvast bedankt!
Ik heb ff de nieuwste driver van ATI gepakt. Nu ff kijken wat er gebeurd :)
