Privacywetgeving
Option Explicit
Function Tel_Unieke_Waarden(rngInput As Range) As Long
Dim rngCel As Range
Dim Unieke_Waarden As New Collection
Application.Volatile
On Error Resume Next
For Each rngCel In rngInput
Unieke_Waarden.Add rngCel.Value, CStr(rngCel.Value)
Next rngCel
Tel_Unieke_Waarden = Unieke_Waarden.Count
End Function
Sub Aantal_Orders()
i = "Output"
ii = "Blad1"
With ThisWorkbook.Sheets(i)
With .Cells.CurrentRegion
If .Parent.AutoFilterMode Then .Parent.AutoFilterMode = False
.AutoFilter 9, Criteria1:="<>*BGE"
Columns("F:F").Copy Destination:=Worksheets(ii).Range("A1")
Worksheets(ii).Select
Range("$A$1:$A$5000").RemoveDuplicates Columns:=1, Header:=xlYes
Aantal = Range("A7000").End(xlUp).Row
Sheets("Statistieken").Range("U4").End(xlToLeft).Offset(0, 1) = Aantal - 1
Worksheets(ii).Columns("A:A").Delete
Sheets(i).ShowAllData
Sheets(i).Activate
Sub Aantal_Orders()
With ThisWorkbook.Sheets("Output")
If .AutoFilterMode Then .AutoFilterMode = False
.Cells(1).CurrentRegion.AutoFilter 9, Criteria1:="<>*BGE"
sn = .Columns(6).SpecialCells(2)
Set d = CreateObject("scripting.dictionary")
For i = 2 To UBound(sn)
If Not .Rows(i).Hidden Then d.Item(sn(i, 1)) = ""
Next i
Sheets("Statistieken").Range("U4").End(xlToLeft).Offset(, 1) = d.Count
.ShowAllData
