Privacywetgeving
Sub Exporteer()
[COLOR="#008000"] 'maak een kopie van het werkblad[/COLOR]
Sheets("te kopieren").Copy After:=Sheets(Sheets.Count)
Sheets(Sheets.Count).Select
[COLOR="#008000"]'verwijder de vba code[/COLOR]
wsName = Sheets(Sheets.Count).CodeName
With ThisWorkbook.VBProject.VBComponents(wsName).CodeModule
.DeleteLines 1, .CountOfLines
Dim NieuwFact As Variant
ActiveSheet.Copy
NieuwFact = "C:\Users\" & Environ("username") & "\Desktop\" & ActiveSheet.Name & ".xlsx"
Application.DisplayAlerts = False
ActiveWorkbook.SaveAs NieuwFact, FileFormat:=51
ActiveWorkbook.Close
Sheets(Sheets.Count).Delete
Sub Exporteer()
ActiveSheet.Copy
application.displayalerts = false
[COLOR=#ff0000]blad1.copy[/COLOR]
[COLOR=#ff0000]activeworkbook[/COLOR].saveas thisworkbook.path & "\hierjebestandsnaam", 51
ActiveSheet.Copy
NieuwFact = Environ("userprofile") & "\Desktop\" & ActiveSheet.Name
ActiveWorkbook.SaveAs Filename:=path & Filename & Format(Date, "ddmmyyuummss") & ".xlsx", FileFormat:=51, CreateBackup:=False
Lijkt me toch dat deze er nog instaan.Zonder formules ?
Sub test()
Dim path As String
path = "G:\test\"
Filename = "test"
ActiveSheet.Copy
Cells.Copy
Range("A1").PasteSpecial Paste:=xlPasteValues
ActiveSheet.Buttons.Delete
