VBA code nodig om 2 tabellen te vergelijken; regels vergelijken en arceren
Maurush
23 feb 2011
Hey allen,
Zie onderstaand een kopie van mijn post op Ozgrid. Helaas nog geen reactie gehad en dacht vraag het hier ook even na.
I have two worksheets with data which are a dumps form our ERP software, I have imported the excel data into two sheets and placed them in tables (one sheet, one table).
The data contains items which still have to be purchased and parts that have already been ordered, some of these parts have an order acknowledgement (OA) and some are still pending for an OA.
To keep a good overview of which items still need to be purchased or still have to be followed up for an OA, I would like to load a new dump from our ERP and compare it with the last dump (let's say a week before).
The new data will be imported on sheet 1 and the historic data can be found on sheet 2.
I would like to check which rows of the new dump are present in the table on sheet 2 and if so, see what items have been changed.
Important is to check if values of 3 different columns in table 1 are present in table 2, only then this row item is the same item as in table 2. Please note that the rows can be anywere, so row number 3 on sheet 1 can correspond with row 10 on sheet 2.
The first image shows the table on sheet 2 with historic dates, the second image shows the table with the new dump on sheet 1.
In yellow the columns are highlighted which will need te be used to check if data from 1 row in table 1 is present in table 2 on sheet 2.
In the second image you see that particular cells are highlighted, these cells contain data which is different (blue) or a complete row that is not present in the historic data (red).
I have tried a lot of codes but cannot figure out the correct approach. See below the code I have ended up with, but maybe a different approach would be better.
Private Sub CMD_Check_Data_Click()
    Dim Compare_Range_Dump As Range
    Dim iRow As Long
    Dim LastRow As Long
    Dim rCell As Range
    LastRow = Range("A:N").Find("*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
    With Worksheets("DUMP Inkopen per productieorder")
        Set Compare_Range_Dump = .Range("E3:E" & LastRow)
    If IsEmpty(Range("A3")) Then
        MsgBox "No data to check", vbOKOnly + vbInformation, ""
    Else
        For Each rCell In Compare_Range_Dump
            Dim i As Integer
            For i = 1 To LastRow
                If rCell.Value = ThisWorkbook.Sheets("Inkopen per productieorder").Range("E" & i).Value Then
                    iRow = ThisWorkbook.Sheets("Inkopen per productieorder").Range("E" & i).Row 'Row where value was found
                    If rCell.Value = ThisWorkbook.Sheets("Inkopen per productieorder").Range("E" & iRow).Value & _
                    rCell.Offset(0, -1).Value = ThisWorkbook.Sheets("Inkopen per productieorder").Range("E" & iRow).Offset(0, -1).Value Then
                        rCell.Interior.Color = RGB(102, 204, 0)
                        rCell.Offset(0, -1).Interior.Color = RGB(102, 204, 0)
                    Else
                        rCell.Interior.Color = RGB(255, 0, 0)
                        rCell.Offset(0, -1).Interior.Color = RGB(255, 0, 0)
            Next i
        Next
        MsgBox "Check done", vbOKOnly + vbInformation, ""
Ik ben al een tijdje aan het prutsen en kom er maar niet uit, hopelijk kan één van jullie mij helpen. Alvast bedankt.
Ruud
maak over beide werkbladen een extra kolom waarbij je de relevante kolommen samenvoegt, behalve misschien die kolom van orderbevestiging.
Dan kan je rechtstreeks of eventueel met een 2e hulpkolom kijken of die samengestelde string ook voorkomt op het andere tabblad en dat in een formule gieten voor een voorwaardelijke opmaak. Dus geen VBA nodig.
Met een voorbeeldbestandje is het zo aan te tonen als je er niet uitkomt.
Over hoeveel rijen gaat het ?
Beste Cow18,
Dit heb ik geprobeerd in 1 van m'n eerdere pogingen echter kreeg ik toen niet goed voor elkaar om de juiste rijen te vinden en dan ook nog eens de individuele kolommen te vergelijken met de historische data om deze vervolgens te highlighten, daar waar de nieuwe data anders is.
Inmiddels heeft iemand op Ozgrid mij al een stuk verder geholpen en verwacht ik ook snel een oplossing te vinden. Bij deze de link naar mijn post: http://www.ozgrid.com/forum/showthread.php?t=205070
Wanneer de code definitief is zal ik hier ook de oplossing plaatsen.
In ieder geval bedankt!
