Sub Test()
Dim wrdApp As Object
Dim wrdDoc As Object
Dim Taal As String
Dim Hoofdpad As String
Dim Zinnetje As String
Taal = UCase(Range("B11"))
If Taal = "" Then
MsgBox "Taal ontbreekt!", vbCritical, "Vul een taal in"
Exit Sub
Hoofdpad = "C:\Users\Jonathan\Documents\test"
Set wrdApp = CreateObject(Class:="Word.Application")
Set wrdDoc = wrdApp.Documents.Open(Filename:=Hoofdpad & Taal & "\intake_" & Taal & ".dotx")
Select Case Taal
Case "NEDERLANDS": Zinnetje = "Dit is gemaakt vanuit Excel en komt in zicht!"
Case "ENGELS": Zinnetje = "This is made from Excel and comes into view!"
Case "FRANS": Zinnetje = "This is made from Excel and comes into view!"
End Select
wrdDoc.Range.InsertAfter Zinnetje
wrdApp.Visible = True
wrdApp.WindowState = 1
wrdApp.Activate
Public Sub CreateNewExcel(strFileName As String)
On Error GoTo Err_CreateNewExcel
Dim appExcel As Excel.Application
Dim bksBooks As Excel.Workbooks
Dim wkbBook As Excel.Workbook
Dim wksSheet As Excel.Worksheet
Set appExcel = GetObject(, "Excel.Application")
Set bksBooks = appExcel.Workbooks
Set wkbBook = bksBooks.Add(strFileName)
Set wksSheet = wkbBook.Sheets(1)
wksSheet.Activate
¨...... verdere excel code
Sub Test()
Dim Taal As String
If Taal = "" Then
Exit Sub
Select Case Taal
End Select
wrdApp.Activate
