VBA Default Printer String (language independent)
alphamax
16 mrt 2011
Windows 11 en-US
Office 2007 nl-NL
Haalt de string op van de default printer en de poort in de juiste taal.
Zodat je deze in kan vullen in excel bij
Application.ActivePrinter
Gets the string of the default printer and port in the right language.
So you can enter it in excel with
[SIZE=1]Private Function GetDefaultPrinterNameAndPort()    'am_2020
    Const HKEY_CURRENT_USER = &H80000001
    Dim aON As Variant
    Dim sDefaultPrinterName As String
    Dim sDefaultPrinterPort As String
    Dim sKeyPath As String
    Dim sOn As String
    Dim sValue As String
    sKeyPath = "Software\Microsoft\Windows NT\CurrentVersion\PrinterPorts"
    With CreateObject("WbemScripting.SWbemLocator")
        sDefaultPrinterName = .ConnectServer(".", "root\cimv2").ExecQuery("Select * from Win32_Printer Where Default = True").ItemIndex(0).name
        aON = Split(Application.ActivePrinter, " ")
        sOn = aON(UBound(aON) - 1)
        .ConnectServer(".", "root\default").Get("stdregprov").GetStringValue HKEY_CURRENT_USER, sKeyPath, sDefaultPrinterName, sValue
        sDefaultPrinterPort = Mid$(sValue, 10, 5)
    GetDefaultPrinterNameAndPort = sDefaultPrinterName & " " & sOn & " " & sDefaultPrinterPort
End Function[/SIZE]
Nieuwe verbeterde code / new and improved code.
Excel in Module
Option Explicit
Private Declare Function GetProfileStringA Lib "kernel32" (ByVal lpAppName As String, ByVal lpKeyName As String, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Long) As Long
Private Function GetDefaultPrinterNameAndPortExcel()
'http://www.java2s.com/Code/VBA-Excel-Access-Word/Windows-API/Getdefaultprinterinformation.htm
    Dim aOn As Variant
    Dim aPrinter As Variant
    Dim sOn As String
    Dim sPrinter As String * 255
    GetProfileStringA "Windows", "Device", "", sPrinter, 254
    aPrinter = Split(Application.Trim(sPrinter), ",")
    aOn = Split(Application.ActivePrinter, " ")
    sOn = aOn(UBound(aOn) - 1)
    GetDefaultPrinterNameAndPortExcel = aPrinter(0) & " " & sOn & " " & aPrinter(2)
End Function
Public Sub Main()
    Dim sDefaultPrinterNameAndPortExcel As String
    sDefaultPrinterNameAndPortExcel = GetDefaultPrinterNameAndPortExcel
Access in Module
Option Explicit
Private Function GetDefaultPrinterNameAndPortAccess() As Printer
'http://www.java2s.com/Code/VBA-Access-Access-Word/Windows-API/Getdefaultprinterinformation.htm
'https://stackoverflow.com/questions/30485227/ms-access-change-default-printer-via-vba
    Dim oPrinter As Printer
    aPrinter = Split(sPrinter, ",")
    For Each oPrinter In Application.Printers
        If oPrinter.DeviceName = aPrinter(0) Then
            Set GetDefaultPrinterNameAndPortAccess = oPrinter
    Next
End Function
Public Sub Main()
    Dim oDefaultPrinterNameAndPortAccess As Printer
    Set oDefaultPrinterNameAndPortAccess = GetDefaultPrinterNameAndPortAccess
Ga ik eens mee spelen.
Dank je wel voor het delen :)
In Access heb je een iets andere code nodig, want ActivePrinter kent-ie niet.
Private Function GetDefaultPrinterNameAndPort() As String    'am_2020
Dim aON As Variant
Dim sDefaultPrinterName As String, sDefaultPrinterPort As String
Dim sKeyPath As String, sOn As String, sValue As String
        sDefaultPrinterName = .ConnectServer(".", "root\cimv2").ExecQuery("Select * from Win32_Printer Where Default = True").ItemIndex(0).Name
        aON = Split(Application.Printer.DeviceName, " ")
End Function
Sub Tes
tPrinter()
    MsgBox GetDefaultPrinterNameAndPort
Nieuwe verbeterde code / new and improved code., zie bericht#1
Zijn activeprinter en defaultprinter wel voldoende onderscheiden ?
Voor de defaultprinter:
Sub M_snb_default()
  For Each it In GetObject("winmgmts:\\.\root\cimv2").ExecQuery("Select * from Win32_Printer")
    If it.Default Then Exit For
  Next
  MsgBox join(array(it.Name,it.ShareName,it.DriverName,"")," on " & it.PortName & vblf)
Sub M_snb_default()
  sn = split(application.activeprinter)
  Next
  MsgBox join(array(it.Name,it.ShareName,it.DriverName,"")," " & sn(ubound(sn)-1) & " " & it.PortName & vblf)
Desnoods maak je gebruik van Application.LanguageSettings.LanguageID(2)
In jouw code is it.PortName
  • PORTPROMPT:
  • SHRFAX:
  • USB001
  • of een ander adres
Terwijl het
Ne0x:
moet zijn, wil het werken met application.activeprinter.
De defaultprinter staat in het register, inclusief de port.
Van de defaultprinter de activeprinter maken gaat dan met:
Sub M_snb_defaultprinter_active()
  sn = Split(ActivePrinter)
  sp = Split(CreateObject("wscript.shell").regread("HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows\Device"), ",")
  ActivePrinter = sp(0) & " " & sn(UBound(sn) - 1) & " " & sp(UBound(sp))
in bericht#9
Doet hetzelfde als
in de nieuwe code van bericht#1
Er zijn meerdere wegen die naar rome leiden.
