Privacywetgeving
Sheets("data").Columns("G:G").Replace "*: ", "", xlPart
Sub inuit()
Dim ar
ar = Sheets("data").Cells(1).CurrentRegion.Value2
ar = Application.Index(ar, Evaluate("row(2:" & UBound(ar) & ")"), Array(5, 6, 9, 7, 18))
With Sheets("in").Range("D1")
.Parent.Range("D" & Rows.Count).End(xlUp).Offset(1).Resize(UBound(ar), UBound(ar, 2)) = ar
With .CurrentRegion
.AutoFilter 6, "<0"
.Offset(1).EntireRow.Delete
.AutoFilter
With Sheets("uit").Range("D1")
With .CurrentRegion
.AutoFilter 6, ">0"
.AutoFilter
Range("A2:R200").ClearContents
Sub inuit()
Dim ar, sht
ar = Sheets("data").Cells(1).CurrentRegion.Offset(1).Value2
ar = Application.Index(ar, Evaluate("row(1:" & UBound(ar) & ")"), Array(5, 6, 9, 7, 18))
For Each sht In Sheets(Array("in", "uit"))
With sht.Range("D1")
With .CurrentRegion
.AutoFilter 6, IIf(sht.Name = "in", "<0", ">0")
.AutoFilter
.RemoveDuplicates Array(4, 5, 6, 7, 8), 1
Next
Sheets("data").Range("A2:R200").ClearContents
If Sheets("data").Range("D2") = vbNullString Then Exit Sub
Sheets("data").Rows("2:" & Range("E2").End(xlDown).Row).Delete Shift:=xlUp
Sub M_snb()
With Blad1
.Cells(1, 26) = "aantal"
.Cells(2, 26) = ">0"
.Cells(1).CurrentRegion.AdvancedFilter 2, .Cells(1, 26).CurrentRegion, Blad2.Cells(1).CurrentRegion.Offset(, 3).Resize(, 5)
.Cells(2, 26) = "<0"
.Cells(1).CurrentRegion.AdvancedFilter 2, .Cells(1, 26).CurrentRegion, Blad3.Cells(1).CurrentRegion.Offset(, 3).Resize(, 5)
