Ik krijg met cod 1 de error : Could Not Load OpenGL. Make Sure you have the latest drivers for your video card installed..
En als ik het wegklik krijg ik CoD Console Met dit erin :
COD MP 1.5 build win-x86 Nov 10 2004
----- FS_Startup -----
Current language: english
Current search path:
D:\ACTIVI~1\CALLOF~3\main\_cookable_grenades_prm.pk3 (6 files)
D:\ACTIVI~1\CALLOF~3\main\pakb.pk3 (60 files)
D:\ACTIVI~1\CALLOF~3\main\paka.pk3 (41 files)
D:\ACTIVI~1\CALLOF~3\main\pak9.pk3 (149 files)
D:\ACTIVI~1\CALLOF~3\main\pak8.pk3 (235 files)
D:\ACTIVI~1\CALLOF~3\main\pak6.pk3 (3 files)
D:\ACTIVI~1\CALLOF~3\main\pak5.pk3 (4858 files)
D:\ACTIVI~1\CALLOF~3\main\pak4.pk3 (1668 files)
D:\ACTIVI~1\CALLOF~3\main\pak3.pk3 (1992 files)
D:\ACTIVI~1\CALLOF~3\main\pak2.pk3 (694 files)
D:\ACTIVI~1\CALLOF~3\main\pak1.pk3 (2642 files)
D:\ACTIVI~1\CALLOF~3\main\pak0.pk3 (12816 files)
D:\ACTIVI~1\CALLOF~3/main
D:\ACTIVI~1\CALLOF~3\main\localized_english_pak3.pk3 (7 files)
localized assets pak file for english
D:\ACTIVI~1\CALLOF~3\main\localized_english_pak2.pk3 (9 files)
D:\ACTIVI~1\CALLOF~3\main\localized_english_pak1.pk3 (3736 files)
D:\ACTIVI~1\CALLOF~3\main\localized_english_pak0.pk3 (1204 files)
File Handles:
30120 files in pk3 files
execing default_mp.cfg
couldn't exec language.cfg
execing config_mp.cfg
couldn't exec autoexec_mp.cfg
========= autoconfigure
configure_mp.csv: using configuration 2000 cpu MHz 256 sys MB 256 vid MB
execing configure_mp.cfg
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Measured CPU speed is 2.52 GHz
System memory is 1024 MB (capped at 1 GB)
Video card memory is 512 MB
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: sanel-m4ivrptp2
IP: 10.0.0.150
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (6)
...shutting down QGL
...unloading OpenGL DLL
Forcing 800x600 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 4: 800 600 FS
...calling CDS: ok
...created window@0,0 (800x600)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (4)
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site.
PC Specs :
Intel Q6600 2.56Ghz
Asus P5K
G.E.I.L 2GB DDR2 800Mhz
XFX Geforce 9600 GT XXX 740M
#1 Heb de nieuwste drivers voor me videokaart van de XFX website
#2 Heb Directx ook helemaal Up to Date
Willen/Kunnen jullie me A.U.B Snel helpen..
Alvast Bedankt,
File Handles:
Winsock Initialized
IP: 10.0.0.150
----- R_Init -----
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
RE_Shutdown( 1 )
PC Specs :
Intel Q6600 2.56Ghz
Asus P5K
Alvast Bedankt,
