Verdwenen iconen. Ondanks sfc geen idee wat er gaande is
kostenzer
3 jun 2007
WordPerfect Office 2021
Ik heb nu al diverse keren Win10 opnieuw geïnstalleerd. Steeds het zelfde probleem:
Het icon is weg. De naam/bschrijving staat er nog. Programma's werken gewoon.
Met sfc /scannow krijg je een lijst zonder einde....
De foutmeldingen heb ik er uit geknipt om het wat compacter te maken. Mocht er behoefte zijn aan de volledige lijst dan kan dat.
2022-01-27 22:12:41, Info                  CSI    00000076 Warning: Overlap: Directory \??\C:\Windows\System32\drivers\en-US\ is owned twice or has its security set twice
   Original owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch amd64, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
   New owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch amd64, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
2022-01-27 22:12:41, Info                  CSI    00000077 Warning: Overlap: Directory \??\C:\Windows\System32\wbem\en-US\ is owned twice or has its security set twice
2022-01-27 22:12:41, Info                  CSI    00000078 Warning: Overlap: Directory \??\C:\Windows\help\mui\0409\ is owned twice or has its security set twice
2022-01-27 22:13:35, Info                  CSI    000000f6 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\ is owned twice or has its security set twice
   Original owner: Microsoft-Windows-shell32, version 10.0.19041.1503, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35}
   New owner: Microsoft-Windows-shell32, version 10.0.19041.1503, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35}
2022-01-27 22:13:35, Info                  CSI    000000f7 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ is owned twice or has its security set twice
2022-01-27 22:13:35, Info                  CSI    000000f8 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\ is owned twice or has its security set twice
2022-01-27 22:14:29, Info                  CSI    00000174 Warning: Overlap: Directory \??\C:\Windows\SysWOW64\drivers\en-US\ is owned twice or has its security set twice
   Original owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch Host= amd64 Guest= x86, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
   New owner: Microsoft-Windows-Foundation-Default-Security.Resources, version 10.0.19041.1, arch Host= amd64 Guest= x86, culture [l:5]'en-US', nonSxS, pkt {l:8 b:31bf3856ad364e35}
2022-01-27 22:14:29, Info                  CSI    00000175 Warning: Overlap: Directory \??\C:\Windows\SysWOW64\wbem\en-US\ is owned twice or has its security set twice
2022-01-27 22:14:29, Info                  CSI    00000176 Warning: Overlap: Directory \??\C:\Windows\help\mui\0409\ is owned twice or has its security set twice
2022-01-27 22:14:50, Info                  CSI    000001a8 Warning: Overlap: Directory \??\C:\Program Files (x86)\ is owned twice or has its security set twice
   Original owner: Microsoft-Windows-shell32, version 10.0.19041.1503, arch Host= amd64 Guest= x86, nonSxS, pkt {l:8 b:31bf3856ad364e35}
   New owner: Microsoft-Windows-shell32, version 10.0.19041.1503, arch Host= amd64 Guest= x86, nonSxS, pkt {l:8 b:31bf3856ad364e35}
2022-01-27 22:14:50, Info                  CSI    000001a9 Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\ is owned twice or has its security set twice
2022-01-27 22:14:50, Info                  CSI    000001aa Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ is owned twice or has its security set twice
2022-01-27 22:14:50, Info                  CSI    000001ab Warning: Overlap: Directory \??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\ is owned twice or has its security set twice
CSIPERF:TXCOMMIT;3590
2022-01-27 22:15:13, Info                  CSI    000001e9 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction  have been successfully repaired
Enig idee wat er hier gaande is en of dit te voorkomen is? Ik denk aan weer een nieuwinstallatie. Gedownloade versies EN de officiele versie hebben het zelfde verschijnsel.
Mvg
Rob
Misschien een issue met je videokaart? Heb je die driver al geüpdated?
Volg dit draadje onderaan pagina 1 en door op pagina 2
Bij het zien van het plaatje dacht ik JA, dat is het probleem. En die site heb ik direct vastgelegd.
Ondertussen heb ik er weer uren in steken en heb wat gedaan wat menig expert me zou afraden. Ik heb een kopie van de opstart / c partitie gemaakt van mijn desktop. Die blind over die van de laptop gezet en.... Het werkt.
User omgezet van "desktop" naar "nieuwe" en die van "desktop" gewist.
Er is nog een restant wat ik niet weg krijg. Er staat een cd-station in de verkenner die er niet is. Verder lijkt alles perfect te lopen. Een heerlijke gewaarwording na dagen geklungel wat niets opleverde.
Zoals aangegeven, die link lijkt me ook goud waard.
Bedankt voor je / jullie moeite.
Mvg
Rob
Het probleem lijkt helemaal opgelost. Een simpele oplossing gevonden op youtube bij een Hindoestaanse inzender.
Maak hier een .reg bestand van:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Icons]
"29"="C:\\Windows\\System32\\shell32.dll"
"C:\\Windows\\System32\\shell32.dll" stond er bij mij niet meer bij.
En zet het in het register erbij.
In het verhaaltje stond dat het i.pv. "29" ook "9" kon zijn.
Het enige wat ik nog interessant zou vinden om te weten is, waar om verdween "C:\\Windows\\System32\\shell32.dll" ?
Mensen doe je voordeel er mee.
Mvg
Rob
Is het dan software- of hardwarematig? Zaken verdwijnen...
Tja, ik ben niet wat je noemt een M$ fan, maar het is een brok programmeerwerk dat met heel veel rekening probeert te houden. En, in verhouding gaat er, voor zover ik het kan beoordelen, niet veel fout. Toch is iedere geconstateerde fout een ergernis. Zeker als je er uren aan spendeert om het recht te breien.
Apple maakt het zich een stuk gemakkelijker. Een véél beperktere, véél te duur betaalde hardware en softwaren die veel fouten afvangt zodat ze niet zo snel aan het licht komen. Mij gaat het te ver die goed te noemen.
De fouten die jij constateert kan ik niet beamen. De hier aangedragen fout is de enige fout die ik constateerde en niet weg kreeg. Er waren netwerkproblemen. Computer a zie b maar komt niet op b. Computer b ziet a en komt op a. Waar zit nu de fout en wat is de fout?
Na opnieuw installeren van b waren de problemen opgelost.
Een ander probleem is dat de instellingen van een programmaatje vaak verdwijnen. Ik kan alleen concluderen dat dat aan dat programmaatje ligt en niet aan windows. Op windows kun je veel zetten wat niet altijd even goed of veilig is. Helaas. Maar het ligt lang niet altijd aan Windows.
Ik heb Linux ook overwogen. Ik ben er een tijdje mee bezig geweest, maar het kost me te veel tijd om dat op zo'n niveau eigen te maken als ik nu heb bij windows en een zeer belangrijk programma voor mij loopt niet onder windows.
Van mensen die met Linux werken hoor ik eigenlijk nooit iets negatiefs. Ja het inwerken kost veel tijd en energie.
Succes met je problemen.
Rob
