DankjewelIn Windows 11 had ik ook wat problemen met de weergave in Explorer.
Opgelost met dit:
WinSetView (Tool to Globally Set Explorer Folder Views)
WinSetView is a tool that will let you easily set File Explorer default folder views (including turning off grouping everywhere if so desired). It works by setting registry values that File Explorer already supports. It does not modify Explorer or add any tasks or services. Please follow the...www.elevenforum.com
ga ik ook eens proberen.
