Verschillende BSOD's tijdens opstarten
martijnaikema
1 dec 2001
Beste allemaal,
Mn pc lijkt er weer eens mee opgehouden te zijn. Tijdens het booten van de pc krijg ik elke keer een blauw scherm. De meldingen zijn verschillend. Ik heb o.a. de volgende fouten al voorbij zien komen:
* IRQL_NOT_LESS_OR_EQUAL
STOP: 0x0000000A (0xFFFFFF9F, 0x000000FF, 0x00000001, 0x826573B0)
* Disbale or uninstall any anti-virus, disk defragmentationor backup utilities. Check you hard drive configuration, and check for any updated drivers. Run CHKDSK /F to check for hard drive corruption, and then restart the computer.
STOP: 0x00000024 (0x001904AA, 0xAA804980, 0xAA80467C, 0x1AC9F125)
* Check to be sure you have adequate disk space. If a driver is identified in the stop message, disable the river or check with the manufacturer for driver updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup options, and then select safe mode.
STOP: 0x0000008E (0xC0000005, 0x8283E7B0, 0xA6EFFC38, 0x00000000)
* STOP 0x0000008E (0xC0000005, 0x8A969087, 0x9366E870, 0x00000000)
fltmgr.sys - adress 8A969087 base at 8A967000, DateStamp 49e01907
* DRIVER_IRQL_NOT_LESS_OR_EQUAL
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or softwaremanufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup options, and then select safe mode.
STOP: 0x00000001 (0x084D8DEC, 0x00000002, 0x00000001, 0x8A88EF0D)
Classpnp.sys - Adress 8A88EF0D base at 8A889000, DateStamp 49e01ee9
* Fout bij win32k.sys (was te laat met maken van een foto van de foutmelding)
Ik heb al verschillende dingen geprobeerd:
* Memtest86 scan - geen errors
* CHKDSK - geen fouten gevonden
* Systeemherstel (vanuit de boot-options)
- Startup Repair - could not detect a problem
- System Restore - geeft een error
- Windows Memory Diagnostic Tool - geen errors
De BSOD's zijn soms voor het Vista-logo, soms tussen het vista-logo en het inloggen en soms na het inloggen.
Door de verschillende fouten heb ik geen idee waar ik moet beginnen. Ik hoop dan ook dat iemand me verder kan helpen. Ik kan namelijk helemaal niet meer in mn Vista komen.
Alvast bedankt voor de hulp.
Groet,
Martijn
Bedankt voor je hulp.
Ga ik zo even proberen.
Ik kreeg net tijdens Safe Mode nog een andere error:
MEMORY_MANAGEMENT
Ik heb daarop opnieuw een MemTest gedaan en hier kwam het volgende uit:
Geheugen #1 at slot #1
Test #1 blijft steken op 75%
Highest Error Adress: 0005b82abc0 - 1464.6 MB Test 1 - Errors 2
Geheugen #2 at slot #1
Test #2 blijft steken op 18%
Highest Error Adress: 000fffffffb - 4095.9 MB Test 2 - Errors from 0 - 32767
