DeleteDuplicateRows
This macro will delete duplicate rows in a range.* To use, select a single-column range of cells, comprising the range of rows from which duplicates are to be deleted, e.g., C2:C99.** To determine whether a row has duplicates, the values in the selected column are compared. Entire rows are not compared against one another.* Only the selected column is used for comparison.* When duplicate values are found in the active column, the first row remains, and all subsequent rows are deleted.
Public Sub DeleteDuplicateRows()
' DeleteDuplicateRows
' This will delete duplicate records, based on the Active Column. That is,
' if the same value is found more than once in the Active Column, all but
' the first (lowest row number) will be deleted.
' To run the macro, select the entire column you wish to scan for
' duplicates, and run this procedure.
Dim R As Long
Dim N As Long
Dim V As Variant
Dim Rng As Range
On Error GoTo EndMacro
Application.Calculation = xlCalculationManual
Set Rng = Application.Intersect(ActiveSheet.UsedRange, _
******************* ActiveSheet.Columns(ActiveCell.Column))
Application.StatusBar = "Processing Row: " & Format(Rng.Row, "#,##0")
N = 0
For R = Rng.Rows.Count To 2 Step -1
If R Mod 500 = 0 Then
*** Application.StatusBar = "Processing Row: " & Format(R, "#,##0")
V = Rng.Cells(R, 1).Value
' Note that COUNTIF works oddly with a Variant that is equal to vbNullString.
' Rather than pass in the variant, you need to pass in vbNullString explicitly.
If V = vbNullString Then
*** If Application.WorksheetFunction.CountIf(Rng.Columns(1), vbNullString) > 1 Then
******* Rng.Rows(R).EntireRow.Delete
******* N = N + 1
*** End If
Else
*** If Application.WorksheetFunction.CountIf(Rng.Columns(1), V) > 1 Then
******* N = N + 1
*** End If
Next R
EndMacro:
Application.StatusBar = False
Application.Calculation = xlCalculationAutomatic
MsgBox "Duplicate Rows Deleted: " & CStr(N)
