Oke de errors:
Notice: Use of undefined constant DB_TYPE - assumed 'DB_TYPE' in C:\xampp\htdocs\GameEngine\Database.php on line 13
Notice: Use of undefined constant SQL_SERVER - assumed 'SQL_SERVER' in C:\xampp\htdocs\GameEngine\Database\db_MYSQL.php on line 17
Notice: Use of undefined constant SQL_USER - assumed 'SQL_USER' in C:\xampp\htdocs\GameEngine\Database\db_MYSQL.php on line 17
Notice: Use of undefined constant SQL_PASS - assumed 'SQL_PASS' in C:\xampp\htdocs\GameEngine\Database\db_MYSQL.php on line 17
Warning: mysql_connect() [function.mysql-connect]: php_network_getaddresses: getaddrinfo failed: Host is onbekend. in C:\xampp\htdocs\GameEngine\Database\db_MYSQL.php on line 17
Warning: mysql_connect() [function.mysql-connect]: [2002] php_network_getaddresses: getaddrinfo failed: Host is onbekend. (trying to connect via tcp://SQL_SERVER:3306) in C:\xampp\htdocs\GameEngine\Database\db_MYSQL.php on line 17
De script database.php:
De script db_MYSQL.php (regel 1 t/m 30 is een vrij groot script):
PHP:
<?php
include("config.php");
switch(DB_TYPE) {
case 1:
include("Database/db_MYSQLi.php");
break;
//case 2:
//include("Database/db_MSSQL.php");
//break;
default:
include("Database/db_MYSQL.php");
break;
PHP:
<?php
class MYSQL_DB {
var $connection;
function MYSQL_DB() {
$this->connection = mysql_connect(SQL_SERVER, SQL_USER, SQL_PASS) or die(mysql_error());
mysql_select_db(SQL_DB, $this->connection) or die(mysql_error());
function register($username, $password, $email, $tribe, $locate, $act) {
$time = time();
$timep = (time() + PROTECTION);
$q = "INSERT INTO " . TB_PREFIX . "users (username,password,access,email,timestamp,tribe,location,act,protect) VALUES ('$username', '$password', " . USER . ", '$email', $time, $tribe, $locate, '$act', $timep)";
if(mysql_query($q, $this->connection)) {
return mysql_insert_id($this->connection);
} else {
return false;
function activate($username, $password, $email, $tribe, $locate, $act, $act2) {
$time = time();
$q = "INSERT INTO " . TB_PREFIX . "activate (username,password,access,email,tribe,timestamp,location,act,act2) VALUES ('$username', '$password', " . USER . ", '$email', $tribe, $time, $locate, '$act', '$act2')";
} else {
return false;
