Private Sub Login_Function()
Select Case UsernameTextBox.Text = "" Or PasswordTextBox.Text = ""
Case True
Select Case UsernameTextBox.Text = "Administrator"
Case True
Select Case UsernameTextBox.Text = My.Settings.AdminPassword
Case True
MsgBox("LOGGED IN AS ADMIN")
Case False
MsgBox("Wrong Admin pass")
End Select
Case False
MsgBox("Een van de velden is incorrect ingevoerd." & vbNewLine & vbNewLine & "Controleer uw gegevens en probeer het opnieuw.", vbOKOnly)
End Select
Case False
Select Case AdminCheckBox.Checked
Case True
Select Case PasswordTextBox.Text = My.Settings.AdminPassword
Case True
Case False
End Select
Case False
Case True
Case True
Case False
End Select
Case False
'Login procedure
Select Case UserListTableAdapter1.Login(UsernameTextBox.Text, PasswordTextBox.Text) = Nothing
Case False
MsgBox("Normal USER Correct Logged in!")
Case True
End Select
End Select
End Select
End Select
