Weet iemand wat hier precies moet gebeuren?
Hugo-K
15 aug 2006
Wat precies te doen?
Er wordt gevraagd
3; Replace your hosts file with the one in this folder
or open your hosts file with notepad and change it
to look like this;
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
127.0.0.1 activate.adobe.com
127.0.0.1 practivate.adobe.com
127.0.0.1 ereg.adobe.com
127.0.0.1 activate.wip3.adobe.com
127.0.0.1 wip3.adobe.com
127.0.0.1 3dns-3.adobe.com
127.0.0.1 3dns-2.adobe.com
127.0.0.1 adobe-dns.adobe.com
127.0.0.1 adobe-dns-2.adobe.com
127.0.0.1 adobe-dns-3.adobe.com
127.0.0.1 ereg.wip3.adobe.com
127.0.0.1 activate-sea.adobe.com
127.0.0.1 wwis-dubc1-vip60.adobe.com
127.0.0.1 activate-sjc0.adobe.com
127.0.0.1 adobe.activate.com
127.0.0.1 adobeereg.com
127.0.0.1 http://www.adobeereg.com
127.0.0.1 125.252.224.90
127.0.0.1 125.252.224.91
127.0.0.1 hl2rcv.adobe.com
hosts file is at;
C:\Windows\System32\drivers\etc
4; Restart and make sure hosts entries are saved (open it with notepad and look).
________________________________________________
Ik weet wel wat mijn IP-adres is, maar over mijn Host ben ik niet zeker. Waar zou ik dit kunnen vinden?
En hoe moet de text er dan precies uitzien? Ik begrijp dat IP-adres en host moet invullen dan opslaan en dan een bestand vervangen.
Alvast bedankt!
Er staat toch heel duidelijk wat er moet gebeuren? zoek de file "hosts" openen, text erin dumpen ; saven
Maak een nieuwe snelkoppeling op je bureaublad naar:
notepad.exe %windir%\system32\drivers\etc\hosts
Rechtsklik op die snelkoppeling, en kies voor "Als Administrator uitvoeren".
Doe de aanpassingen, klik op het rode kruisje en geef ja als gevraagd wordt of je het wilt opslaan.
[off-topic]Bah, een activatie-crack voor adobe producten.[/off-topic]
Tijs.
Ik begrijp niet zo goed welke aanpassing ik moet doen?
Het werkt nog steeds niet, sorry
