Ik heb een probleem met java:
Ik werk onder linux: Ubuntu 7.10 met NetBeans IDE 6.1.
Daar probeer ik met volgende code een nieuw Writer document te openen:
SWriter.java (onderdeel van OpenOffice.org 2.2 software development kit)
Ik krijg als uitvoer:
Dit slaat op volgende code:
try {
// get the remote office component context
xContext = com.sun.star.comp.helper.Bootstrap.bootstrap();
if( xContext != null )
System.out.println("Connected to a running office ...");
} catch( Exception e) {
e.printStackTrace(System.err);
System.exit(1);
Hoe kan ik dit oplossen?
* $RCSfile: SWriter.java,v $
* $Revision: 1.5 $
* last change: $Author: rt $ $Date: 2005/01/31 17:17:30 $
* The Contents of this file are made available subject to the terms of
* the BSD license.
* Copyright (c) 2003 by Sun Microsystems, Inc.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* 3. Neither the name of Sun Microsystems, Inc. nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
* TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
* USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// comment: Step 1: bootstrap UNO and get the remote component context
// Step 2: open an empty text document
// Step 3: enter some text
// Step 4: insert a text table
// Step 5: insert colored text
// Step 6: insert a text frame
import com.sun.star.uno.UnoRuntime;
public class SWriter {
public static void main(String args[]) {
//oooooooooooooooooooooooooooStep 1oooooooooooooooooooooooooooooooooooooooo
// bootstrap UNO and get the remote component context. The context can
// be used to get the service manager
com.sun.star.uno.XComponentContext xContext = null;
try {
System.exit(1);
//oooooooooooooooooooooooooooStep 2oooooooooooooooooooooooooooooooooooooooo
// open an empty document. In this case it's a writer document.
// For this purpose an instance of com.sun.star.frame.Desktop
// is created. It's interface XDesktop provides the XComponentLoader,
// which is used to open the document via loadComponentFromURL
//Open Writer document
System.out.println("Opening an empty Writer document");
com.sun.star.text.XTextDocument myDoc = openWriter(xContext);
//oooooooooooooooooooooooooooStep 3oooooooooooooooooooooooooooooooooooooooo
// insert some text.
// For this purpose get the Text-Object of the document an create the
// cursor. Now it is possible to insert a text at the cursor-position
// via insertString
//getting the text object
com.sun.star.text.XText xText = myDoc.getText();
//create a cursor object
com.sun.star.text.XTextCursor xTCursor = xText.createTextCursor();
//inserting some Text
xText.insertString( xTCursor, "The first line in the newly created text document.\n", false );
//inserting a second line
xText.insertString( xTCursor, "Now we're in the second line\n", false );
//oooooooooooooooooooooooooooStep 4oooooooooooooooooooooooooooooooooooooooo
// insert a text table.
// For this purpose get MultiServiceFactory of the document, create an
// instance of com.sun.star.text.TextTable and initialize it. Now it can
// be inserted at the cursor position via insertTextContent.
// After that some properties are changed and some data is inserted.
//inserting a text table
System.out.println("Inserting a text table");
//getting MSF of the document
com.sun.star.lang.XMultiServiceFactory xDocMSF =
(com.sun.star.lang.XMultiServiceFactory) UnoRuntime.queryInterface(
com.sun.star.lang.XMultiServiceFactory.class, myDoc);
//create instance of a text table
com.sun.star.text.XTextTable xTT = null;
try {
Object oInt = xDocMSF.createInstance("com.sun.star.text.TextTable");
xTT = (com.sun.star.text.XTextTable)
UnoRuntime.queryInterface(com.sun.star.text.XTextTable.class,oInt);
} catch (Exception e) {
System.err.println("Couldn't create instance "+ e);
//initialize the text table with 4 columns an 4 rows
xTT.initialize(4,4);
com.sun.star.beans.XPropertySet xTTRowPS = null;
//insert the table
try {
xText.insertTextContent(xTCursor, xTT, false);
// get first Row
com.sun.star.container.XIndexAccess xTTRows = xTT.getRows();
xTTRowPS = (com.sun.star.beans.XPropertySet)UnoRuntime.queryInterface(
com.sun.star.beans.XPropertySet.class, xTTRows.getByIndex(0));
System.err.println("Couldn't insert the table " + e);
// get the property set of the text table
com.sun.star.beans.XPropertySet xTTPS = (com.sun.star.beans.XPropertySet)
UnoRuntime.queryInterface(com.sun.star.beans.XPropertySet.class, xTT);
// Change the BackColor
try {
xTTPS.setPropertyValue("BackTransparent", new Boolean(false));
xTTPS.setPropertyValue("BackColor",new Integer(13421823));
xTTRowPS.setPropertyValue("BackTransparent", new Boolean(false));
xTTRowPS.setPropertyValue("BackColor",new Integer(6710932));
System.err.println("Couldn't change the color " + e);
// write Text in the Table headers
System.out.println("Write text in the table headers");
insertIntoCell("A1","FirstColumn", xTT);
insertIntoCell("B1","SecondColumn", xTT) ;
insertIntoCell("C1","ThirdColumn", xTT) ;
insertIntoCell("D1","SUM", xTT) ;
//Insert Something in the text table
System.out.println("Insert something in the text table");
(xTT.getCellByName("A2")).setValue(22.5);
(xTT.getCellByName("B2")).setValue(5615.3);
(xTT.getCellByName("C2")).setValue(-2315.7);
(xTT.getCellByName("D2")).setFormula("sum <A2:C2>");
(xTT.getCellByName("A3")).setValue(21.5);
(xTT.getCellByName("B3")).setValue(615.3);
(xTT.getCellByName("C3")).setValue(-315.7);
(xTT.getCellByName("D3")).setFormula("sum <A3:C3>");
(xTT.getCellByName("A4")).setValue(121.5);
(xTT.getCellByName("B4")).setValue(-615.3);
(xTT.getCellByName("C4")).setValue(415.7);
(xTT.getCellByName("D4")).setFormula("sum <A4:C4>");
//oooooooooooooooooooooooooooStep 5oooooooooooooooooooooooooooooooooooooooo
// insert a colored text.
// Get the propertySet of the cursor, change the CharColor and add a
// shadow. Then insert the Text via InsertString at the cursor position.
// get the property set of the cursor
com.sun.star.beans.XPropertySet xTCPS = (com.sun.star.beans.XPropertySet)
xTCursor);
Object oldValue = null;
// Change the CharColor and add a Shadow
try {
xTCPS.setPropertyValue("CharColor",new Integer(255));
xTCPS.setPropertyValue("CharShadowed", new Boolean(true));
//create a paragraph break
try {
xText.insertControlCharacter(xTCursor,
com.sun.star.text.ControlCharacter.PARAGRAPH_BREAK, false);
System.err.println("Couldn't insert break "+ e);
//inserting colored Text
System.out.println("Inserting colored Text");
xText.insertString(xTCursor, " This is a colored Text - blue with shadow\n",
false );
try {
//oooooooooooooooooooooooooooStep 6oooooooooooooooooooooooooooooooooooooooo
// insert a text frame.
// create an instance of com.sun.star.text.TextFrame using the MSF of the
// document. Change some properties an insert it.
// Now get the text-Object of the frame an the corresponding cursor.
// Insert some text via insertString.
// Create a TextFrame
com.sun.star.text.XTextFrame xTF = null;
com.sun.star.drawing.XShape xTFS = null;
try {
Object oInt = xDocMSF.createInstance("com.sun.star.text.TextFrame");
xTF = (com.sun.star.text.XTextFrame) UnoRuntime.queryInterface(
com.sun.star.text.XTextFrame.class,oInt);
xTFS = (com.sun.star.drawing.XShape) UnoRuntime.queryInterface(
com.sun.star.drawing.XShape.class,oInt);
com.sun.star.awt.Size aSize = new com.sun.star.awt.Size();
aSize.Height = 400;
aSize.Width = 15000;
xTFS.setSize(aSize);
// get the property set of the text frame
com.sun.star.beans.XPropertySet xTFPS = (com.sun.star.beans.XPropertySet)
UnoRuntime.queryInterface(com.sun.star.beans.XPropertySet.class, xTF);
// Change the AnchorType
try {
xTFPS.setPropertyValue("AnchorType",
com.sun.star.text.TextContentAnchorType.AS_CHARACTER);
//insert the frame
System.out.println("Insert the text frame");
try {
xText.insertTextContent(xTCursor, xTF, false);
System.err.println("Couldn't insert the frame " + e);
//getting the text object of Frame
com.sun.star.text.XText xTextF = xTF.getText();
com.sun.star.text.XTextCursor xTCF = xTextF.createTextCursor();
xTextF.insertString(xTCF,
"The first line in the newly created text frame.", false);
"\nWith this second line the height of the frame raises.", false);
//insert a paragraph break
try {
com.sun.star.text.ControlCharacter.PARAGRAPH_BREAK, false );
try {
xTCPS.setPropertyValue("CharColor",new Integer(65536));
xTCPS.setPropertyValue("CharShadowed", new Boolean(false));
xText.insertString(xTCursor, " That's all for now !!", false );
System.out.println("done");
System.exit(0);
public static com.sun.star.text.XTextDocument openWriter(
com.sun.star.uno.XComponentContext xContext)
//define variables
com.sun.star.frame.XComponentLoader xCLoader;
com.sun.star.text.XTextDocument xDoc = null;
com.sun.star.lang.XComponent xComp = null;
try {
// get the remote office service manager
com.sun.star.lang.XMultiComponentFactory xMCF =
xContext.getServiceManager();
Object oDesktop = xMCF.createInstanceWithContext(
"com.sun.star.frame.Desktop", xContext);
xCLoader = (com.sun.star.frame.XComponentLoader)
UnoRuntime.queryInterface(com.sun.star.frame.XComponentLoader.class,
oDesktop);
com.sun.star.beans.PropertyValue [] szEmptyArgs =
new com.sun.star.beans.PropertyValue [0];
String strDoc = "private:factory/swriter";
xComp = xCLoader.loadComponentFromURL(strDoc, "_blank", 0, szEmptyArgs);
xDoc = (com.sun.star.text.XTextDocument)
UnoRuntime.queryInterface(com.sun.star.text.XTextDocument.class,
xComp);
} catch(Exception e){
System.err.println(" Exception " + e);
return xDoc;
public static void insertIntoCell(String CellName, String theText,
com.sun.star.text.XTextTable xTTbl) {
com.sun.star.text.XText xTableText = (com.sun.star.text.XText)
UnoRuntime.queryInterface(com.sun.star.text.XText.class,
xTTbl.getCellByName(CellName));
com.sun.star.text.XTextCursor xTC = xTableText.createTextCursor();
com.sun.star.beans.XPropertySet xTPS = (com.sun.star.beans.XPropertySet)
UnoRuntime.queryInterface(com.sun.star.beans.XPropertySet.class, xTC);
try {
xTPS.setPropertyValue("CharColor",new Integer(16777215));
xTableText.setString( theText );
com.sun.star.comp.helper.BootstrapException: no office executable found!
at com.sun.star.comp.helper.Bootstrap.bootstrap(Bootstrap.java:253)
at SWriter.<init>(SWriter.java:76)
try {
System.exit(1);
