All videos are stuck on the loading screen.This could be caused by a number of things. First, you'll need a broadband connection with at least 500+Kbps for the best viewing experience.
If your connection speed meets the minimum requirement but you are still stuck on the loading screen, this could be caused by a firewall or internet blocker. These types of programs could block the media stream from YouTube. If you have a firewall, you might want to temporarily disable it to see if the videos load. If so, you would need to adjust the firewall settings to allow streaming media from YouTube to pass the firewall. If you are not sure on how to do this, please contact the manufacturer of your firewall.
This might also be caused by another streaming application such as Quicktime fighting for the stream. heb ik weggehaald gedeinstaleerd Please check streaming applications installed on your computer like RealPlayer, Quicktime, and Windows Media Player and ensure they are not enabled as the default player.
Finally, you may be trying to view a video that has been marked as "Private" by its owner. Unless you are logged in and a member of that member's "Friends" or "Family" list, you will not be able to see the video. Check another video to determine if all videos are failing to load, or just one.
How do I clear the browser cache and cookies and enable cookies on my computer?If you're experiencing trouble converting your account to a Musician, Comedian, or Director account, you may be able to resolve the issue by clearing your cache and cookies. You may also need to try the second process below: enabling browser cookies. Here are steps to clear the browser cache and cookies and enable cookies in the most common browsers.
Clear cookies for Internet Explorer 7
1. Click “Start” and select “Control Panel”.
(Note: With Windows XP Classic View click the Windows “Start” button and select “Settings” and “Control Panel”).
2. Open the Internet Options icon.
3. Click the “General” tab if it isn't selected already.
4. Under the Browsing history section, click the “Delete” button.
5. Click the “Delete cookies” button.
6. Select “Yes” if a box appears to confirm.
7. Click “OK” to close the window.
heb ik gedaan werkt nog steeds niet
ook als in de url kopieeer en speel in mediaplayer of quicktime krijg ik error en me firewall aan en uit gezet maar nog steeds niets...wordt gek!!!!
