Sub test()
Dim SearchRange As Range
Dim FindWhat As Variant
Dim FoundCells As Range
Set SearchRange = Sheets("blad1").Columns("A:C")
FindWhat = "100"
Set FoundCells = FindAll(SearchRange:=SearchRange, _
FindWhat:=FindWhat, _
LookIn:=xlValues, _
LookAt:=xlPart, _
SearchOrder:=xlByColumns, _
MatchCase:=False)
If Not FoundCells Is Nothing Then
FoundCells.Interior.ColorIndex = 4
' modFindAll
' By Chip Peasron, chip@cpearson.com. www.cpearson.com
' 24-October-2007
' This module is described at www.cpearson.com/Excel/FindAll.aspx
' Requires Excel 2000 or later.
' This module contains two functions, FindAll and FindAllOnWorksheets that are use
' to find values on a worksheet or multiple worksheets.
' FindAll searches a range and returns a range containing the cells in which the
' searched for text was found. If the string was not found, it returns Nothing.
' FindAllOnWorksheets searches the same range on one or more workshets. It return
' an array of ranges, each of which is the range on that worksheet in which the
' value was found. If the value was not found on a worksheet, that worksheet's
' element in the returned array will be Nothing.
' In both functions, the parameters that control the search have the same meaning
' and effect as they do in the Range.Find method.
Function FindAll(SearchRange As Range, _
FindWhat As Variant, _
Optional LookIn As XlFindLookIn = xlValues, _
Optional LookAt As XlLookAt = xlWhole, _
Optional SearchOrder As XlSearchOrder = xlByRows, _
Optional MatchCase As Boolean = False) As Range
' FindAll
' This searches the range specified by SearchRange and returns a Range object
' that contains all the cells in which FindWhat was found. The search parameters to
' this function have the same meaning and effect as they do with the
' Range.Find method. If the value was not found, the function return Nothing.
Dim FoundCell As Range
Dim FirstFound As Range
Dim LastCell As Range
Dim ResultRange As Range
With SearchRange
Set LastCell = .Cells(.Cells.Count)
'On Error Resume Next
On Error GoTo 0
Set FoundCell = SearchRange.Find(what:=FindWhat, _
after:=LastCell, _
LookIn:=LookIn, _
LookAt:=LookAt, _
SearchOrder:=SearchOrder, _
MatchCase:=MatchCase)
If Not FoundCell Is Nothing Then
Set FirstFound = FoundCell
Set ResultRange = FoundCell
Set FoundCell = SearchRange.FindNext(after:=FoundCell)
Do Until False ' Loop forever. We'll "Exit Do" when necessary.
If (FoundCell Is Nothing) Then
Exit Do
If (FoundCell.Address = FirstFound.Address) Then
Exit Do
Set ResultRange = Application.Union(ResultRange, FoundCell)
Loop
Set FindAll = ResultRange
End Function
