Brand problemen met Nero 7 Ultra Edition
kaal schandaal
10 apr 2007
Ik gebruik Nero 7 Ultra Edition en heb er nooit problemen mee gehad maar films branden lukt niet meer en data dvd ook niet :confused: iemand een oplossing???
Dit geeft ie aan maar begrijp er niks van
1c82-0010-8011-0000-0436-6692-6776
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10-9-1999 11:06:00
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2-11-2004 12:54:32
NT-SPTI used
Nero Version: 7.0.0.0 (Nero Express)
Recorder:             <_NEC DVD_RW ND-2500A>    Version: 1.06 - HA 1 TA 0 - 7.0.0.0
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
CD-ROM:               <_NEC     DVD_RW ND-2500A >Version: 1.06 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral       : ST3160021A                       atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : _NEC DVD_RW ND-2500A             atapi Port 3 ID 0  DMA: On
=== CDRom-Device-Map ===
_NEC DVD_RW ND-2500A       E:   CDRom0
IDE-DVD ROM 16x            G:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 511MB (523756kB)
Free physical memory: 143MB (146480kB)
Memory in use       : 72 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.12.2007
UDF-compilatie
20:43:36	#1 Text 0 File Isodoc.cpp, Line 6410
	UDF document burn settings
	Determine maximum speed : FALSE
	Simulate                : FALSE
	Write                   : TRUE
	Finalize CD             : TRUE
	Multisession            : FALSE
	Burning mode            : DAO
	Mode                    : 1
	UDF Mode                : pure
	UDF Revision            : 1.02
	UDF Partition Type      : physical
20:43:36	#2 Text 0 File ThreadedTransfer.cpp, Line 525
	ReadBuffer-Pipe got 262144KB of Memory
20:43:36	#3 Text 0 File Reader.cpp, Line 124
	Reader running
20:43:36	#4 Text 0 File Burncd.cpp, Line 3301
	Turn on Disc-At-Once, using DVD media
20:43:36	#5 Text 0 File DlgWaitCD.cpp, Line 277
	Last possible write address on media:  2298495 (510:46.45, 4489MB)
	Last address to be written:            1465375 (325:38.25, 2862MB)
20:43:36	#6 Text 0 File DlgWaitCD.cpp, Line 289
	Write in overburning mode: NO (enabled: CD)
20:43:36	#7 Text 0 File DlgWaitCD.cpp, Line 2568
	Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R
	 Disc Manufacturer: MBI 03 - RG40
	 Disc Application Code: 64, Disc Physical Code: 193
20:43:36	#8 Text 0 File DlgWaitCD.cpp, Line 456
	>>> Protocol of DlgWaitCD activities: <<<
20:43:36	#9 Text 0 File ThreadedTransferInterface.cpp, Line 846
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 ()
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 1465376 (1465376) = #1465376/325:38.26
	    relocatable, disc pos for caching/writing not required/ required, no patch infos
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1465376 blocks [E: _NEC DVD_RW ND-2500A]
20:43:36	#10 Text 0 File ThreadedTransferInterface.cpp, Line 1058
	Prepare recorder [E: _NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc fixated
	 Tracks 1 to 1:
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    3001090048, ISRC ""
	DAO layout:
	 __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
	       0 |  lead-in |   0 |    0x41 | 0x00
	       0 |        1 |   0 |    0x41 | 0x00
	       0 |        1 |   1 |    0x41 | 0x00
	 1465376 | lead-out |   1 |    0x41 | 0x00
20:43:44	#11 Text 0 File SCSIPassThrough.cpp, Line 56
	Error on LockVolume: Toegang geweigerd.
20:43:44	#12 Text 0 File SCSIPassThrough.cpp, Line 104
	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
20:43:44	#13 Text 0 File Cdrdrv.cpp, Line 9571
	SPTIDismountVolume not successfull
20:43:52	#14 Text 0 File SCSIPassThrough.cpp, Line 56
20:43:52	#15 Phase 24 File dlgbrnst.cpp, Line 1724
	Caching of files started
20:43:53	#16 Text 0 File Burncd.cpp, Line 4129
	Cache writing successful.
20:43:53	#17 Phase 25 File dlgbrnst.cpp, Line 1724
	Caching of files completed
20:43:53	#18 Phase 36 File dlgbrnst.cpp, Line 1724
	Burn process started at 2,4x (3.324 kB/sec)
20:43:53	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2669
	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:43:53	#20 Text 0 File DVDR.cpp, Line 2469
	Recording mode: Sequential Recording Mode
20:43:53	#21 Text 0 File MMC.cpp, Line 21541
	Set BUFE: Buffer underrun protection -> ON
20:43:53	#22 Text 0 File DVDR.cpp, Line 2624
	Start write address at LBA 0
	DVD high compatibility mode: Yes
20:43:53	#23 Text 0 File Cdrdrv.cpp, Line 8385
	---- DVD Structure: Physical Format Information (00h) ----
	Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD-R   (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
	 Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
	 End Physical Sector Number of Data Area:      26127F h
	 End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
	 Data in Burst Cutting Area (BCA) does not exist
	  Start sector number of the current Border-Out: 2FE10 h
	  Start sector number of the next Border-In:     2FFA0 h
	 Media Specific [16..63]:
	      00 60 00 10 20 30 40 50 - 00 00 00 00 00 00 00 00    .`...0@P........
	      00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00    ..þ...ÿ.........
	      00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
20:43:53	#24 SPTI -1046 File SCSIPassThrough.cpp, Line 306
	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
	Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
	Sense Code: 0x30
	Sense Qual: 0x05
	CDB Data:   0x53 00 00 00 00 00 16 5C 20 00 00 00
	Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
20:43:53	#25 CDR -1046 File ThreadedTransferInterface.cpp, Line 1783
	Illegal disc
20:43:53	#26 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1783
	Could not perform start of Disc-at-once
20:43:53	#27 Phase 38 File dlgbrnst.cpp, Line 1724
	Burn process failed at 2,4x (3.324 kB/sec)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10-9-1999 11:06:00
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Vast bedankt voor de moeite :thumb:
probeer nero eens te updaten en kijk dat of je het probleem nog steeds hebt
ik bedoel een update via de nero site
Heb ik nu gedaan maar branden lukt nog steeds niet
heb je vaker - gebruikt, en als je op een andere manier brand,lukt het dan wel?
nog ff............... je instellingen staan wel goed?
Ik ben er nog niet uit maar gelukkig heb ik nog een andere pc die ik nu maar gebruik voor het branden.
Toch bedankt beste mensen :thumb:
