kaal schandaal
- 10 apr 2007
Ik gebruik Nero 7 Ultra Edition en heb er nooit problemen mee gehad maar films branden lukt niet meer en data dvd ook niet
iemand een oplossing???
Dit geeft ie aan maar begrijp er niks van
Vast bedankt voor de moeite :thumb:
1c82-0010-8011-0000-0436-6692-6776
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10-9-1999 11:06:00
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2-11-2004 12:54:32
NT-SPTI used
Nero Version: 7.0.0.0 (Nero Express)
Recorder: <_NEC DVD_RW ND-2500A> Version: 1.06 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD_RW ND-2500A >Version: 1.06 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : ST3160021A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
_NEC DVD_RW ND-2500A E: CDRom0
IDE-DVD ROM 16x G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523756kB)
Free physical memory: 143MB (146480kB)
Memory in use : 72 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.12.2007
UDF-compilatie
20:43:36 #1 Text 0 File Isodoc.cpp, Line 6410
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Revision : 1.02
UDF Partition Type : physical
20:43:36 #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 262144KB of Memory
20:43:36 #3 Text 0 File Reader.cpp, Line 124
Reader running
20:43:36 #4 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using DVD media
20:43:36 #5 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1465375 (325:38.25, 2862MB)
20:43:36 #6 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
20:43:36 #7 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R
Disc Manufacturer: MBI 03 - RG40
Disc Application Code: 64, Disc Physical Code: 193
20:43:36 #8 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
20:43:36 #9 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1465376 (1465376) = #1465376/325:38.26
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1465376 blocks [E: _NEC DVD_RW ND-2500A]
20:43:36 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [E: _NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3001090048, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1465376 | lead-out | 1 | 0x41 | 0x00
20:43:44 #11 Text 0 File SCSIPassThrough.cpp, Line 56
Error on LockVolume: Toegang geweigerd.
20:43:44 #12 Text 0 File SCSIPassThrough.cpp, Line 104
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
20:43:44 #13 Text 0 File Cdrdrv.cpp, Line 9571
SPTIDismountVolume not successfull
20:43:52 #14 Text 0 File SCSIPassThrough.cpp, Line 56
20:43:52 #15 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
20:43:53 #16 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
20:43:53 #17 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
20:43:53 #18 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 2,4x (3.324 kB/sec)
20:43:53 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:43:53 #20 Text 0 File DVDR.cpp, Line 2469
Recording mode: Sequential Recording Mode
20:43:53 #21 Text 0 File MMC.cpp, Line 21541
Set BUFE: Buffer underrun protection -> ON
20:43:53 #22 Text 0 File DVDR.cpp, Line 2624
Start write address at LBA 0
DVD high compatibility mode: Yes
20:43:53 #23 Text 0 File Cdrdrv.cpp, Line 8385
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 00 00 00 00 00 .`...0@P........
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ..þ...ÿ.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
20:43:53 #24 SPTI -1046 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x53 00 00 00 00 00 16 5C 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
20:43:53 #25 CDR -1046 File ThreadedTransferInterface.cpp, Line 1783
Illegal disc
20:43:53 #26 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1783
Could not perform start of Disc-at-once
20:43:53 #27 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 2,4x (3.324 kB/sec)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10-9-1999 11:06:00
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
