Nieuwe Syteem Oké?????
joeyschrama
30 mrt 2007
Hallo..
ik was op internet aan het kijken en kwam deze aanbieding tegen:
Socket 775 Mainboard All in One + VGA DDR1/AGP + CPU Pentium 4, 3 ghz + koeler € 99
Processor
Type / Model: Intel Pentium 4 531
64-bit Computer: Ja
Aantal processoren: 1
Kloksnelheid: 3 GHz
Bussnelheid: 800 MHz
Compatibele processorsocket: LGA775 Socket
Grootte Level 1-cache: 16 KB
Grootte geïnstalleerd: L2 Cache - 1 MB
Type: Advanced Transfer Cache
Fabricageproces: 90 nm
Thermal Design Power: 84 W
Thermische specificatie: 67.7 °C
Ontwerpfuncties: Streaming SIMD-extensies 2, Hyper-Threading technologie, streaming SIMD-extensie 3, Execute Disable Bit mogelijkheid, Intel 64 Technology
Moederbord: PCCHIPS M957G ALL IN ONE
M957 V 1.0
SPECIFICATION
Processor
• LGA775 socket for latest intel® Pentium® 4/Celeron® D processors with Hyper Threading Technology ready, support 800/533MHz FSB
• Support Intel® Prescott CPU
Chipset
• VIA PM800 Northbridge and VT8237 Southbridge Chipset
• Embedded UniChromeII Graphics w/ 64M share memory
• Realtek ALC655 6-channel audio codec, Compliant with AC'97 2.3 specification
• LAN - VIA VT6103 10/100Mbps Fast Ethernet PHY
System BIOS
• AMI 2Mb Firmware Hub
• Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
• Full support for ACPI revision 1.0 specification
Memory
• Two 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266)
• Maximum: 2GB
Expansion Slots
• 3 PCI slots, 1 AGP slot (8x), 1 CNR slot
I/O Interface
Back Panel I/O Ports
• One PS/2 keyboard
• One PS/2 mouse
• One Parallel Port
• One Serial Port
• One VGA port
• Four USB 2.0 Ports
• One RJ 45 Port
• One Audio I/O (Line-in, Line-out and Mic-in)
IDE: 2 x UltraDMA 133/100/66
Internal I/O Connectors & Headers
• 20-pin ATX power supply connector
• 4-pin ATX 12V power supply connector
• Two USB 2.0 header support additional 4 USB2.0 ports
• Two Serial ATA connectors
• One Front panel switch/LED header
• One Front panel audio header
• CPU / SYS FAN headers
• One IrDA for SIR header
• One Speaker header
• One CD in header
• One Floppy connector-support 360K~2.88M Byte, 3 Mode FDDs or LS120
Form Factor & Layers
• MicroATX Form Factor(244mm*220mm)
Ik vraag mij af of dit een goed systeem is (voor de wat oudere games Onderandere: Need for speed Most wanted Etc????
Ik heb thuis nog deze onderdelenliggen die ik er dan aan toevoeg: 160 Gig harddisk (Maxtor 72000 Rpm), 1 Gig ddr400 werkgeheugen, floppyspeler, dvd brander, 300 Watt voeding...
Zou dit een redelijk systeem zijn??
Alvast bedankt!!!:thumb:
Oke Ziet er nep uit want een Blu-Ray Brander kost al 414€ En die pc zelf kost 100 euro
ik dacht te lezen dat ie die brander al thuis had liggen:confused:
@ts:mis nog een beetje videokaart.
nu zit er een onboard op.dat wordt lastig
indien een goede videokaart erin kun je er best nog wel games mee spelen van een wat oudere generatie
en afhankelijk van je videokaart de nieuwste games maar wel op low of medium
Volgens mij praten we niet over een systeem, maar alleen een moederbordje met processor en meer niet.
PCChips zijn low, low, low budget bordjes meet alles onboard, beslist niet geschikt om te gamen!
geen super gamen nee:thumb:
hey,
ik las dat je 1 gb ddr geheuen en 1 gb ddr2 geheugen wou toevoegen. dat gaat natuurlijk niet he. je kunt niet en ddr en ddr2 op het moederbord doen.
greetz
Kan wel;)
Lees maar: dual core geheugen...
Ddr 1 en 2 :cool:
En al bedankt vor alle reacties!!!
K wil Hem hoofdzakelijk ook gebruiken om te downloaden (newsgrouppe)
Parren en rarren...
Zou dit wel snel gaan (Ivm Hyper-tread)
K hoop het wel want met mijn huidige processor niet (amd 1.6 Ghz, 512 mb Wekrgeheugen, 64 mb video)
P.s. zou deze combinatie (die helemaal bovenaan staat wel werkem met een 300 watt voeding??? ik hoop het wel !!)
Kan Iemand mij mischien zeggen of deze combinatie gaat werken met een 300 watt voeding????
Ik heb namelijk geen zin om een nieuwe te kopen:rolleyes:
je bedoelt het bordje wat je in je ts geplaatst hebt?
mag dan geen probleem zijn.mits het een goede voeding is
Ik heb mijn Systeem voor kerst gekregen:D
En hij werkt perfect!!!!!!!:thumb:
