joeyschrama
- 30 mrt 2007
Hallo..
ik was op internet aan het kijken en kwam deze aanbieding tegen:
Socket 775 Mainboard All in One + VGA DDR1/AGP + CPU Pentium 4, 3 ghz + koeler € 99
Processor
Type / Model: Intel Pentium 4 531
64-bit Computer: Ja
Aantal processoren: 1
Kloksnelheid: 3 GHz
Bussnelheid: 800 MHz
Compatibele processorsocket: LGA775 Socket
Grootte Level 1-cache: 16 KB
Grootte geïnstalleerd: L2 Cache - 1 MB
Type: Advanced Transfer Cache
Fabricageproces: 90 nm
Thermal Design Power: 84 W
Thermische specificatie: 67.7 °C
Ontwerpfuncties: Streaming SIMD-extensies 2, Hyper-Threading technologie, streaming SIMD-extensie 3, Execute Disable Bit mogelijkheid, Intel 64 Technology
Moederbord: PCCHIPS M957G ALL IN ONE
M957 V 1.0
SPECIFICATION
Processor
• LGA775 socket for latest intel® Pentium® 4/Celeron® D processors with Hyper Threading Technology ready, support 800/533MHz FSB
• Support Intel® Prescott CPU
Chipset
• VIA PM800 Northbridge and VT8237 Southbridge Chipset
• Embedded UniChromeII Graphics w/ 64M share memory
• Realtek ALC655 6-channel audio codec, Compliant with AC'97 2.3 specification
• LAN - VIA VT6103 10/100Mbps Fast Ethernet PHY
System BIOS
• AMI 2Mb Firmware Hub
• Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
• Full support for ACPI revision 1.0 specification
Memory
• Two 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266)
• Maximum: 2GB
Expansion Slots
• 3 PCI slots, 1 AGP slot (8x), 1 CNR slot
I/O Interface
Back Panel I/O Ports
• One PS/2 keyboard
• One PS/2 mouse
• One Parallel Port
• One Serial Port
• One VGA port
• Four USB 2.0 Ports
• One RJ 45 Port
• One Audio I/O (Line-in, Line-out and Mic-in)
IDE: 2 x UltraDMA 133/100/66
Internal I/O Connectors & Headers
• 20-pin ATX power supply connector
• 4-pin ATX 12V power supply connector
• Two USB 2.0 header support additional 4 USB2.0 ports
• Two Serial ATA connectors
• One Front panel switch/LED header
• One Front panel audio header
• CPU / SYS FAN headers
• One IrDA for SIR header
• One Speaker header
• One CD in header
• One Floppy connector-support 360K~2.88M Byte, 3 Mode FDDs or LS120
Form Factor & Layers
• MicroATX Form Factor(244mm*220mm)
Ik vraag mij af of dit een goed systeem is (voor de wat oudere games Onderandere: Need for speed Most wanted Etc????
Ik heb thuis nog deze onderdelenliggen die ik er dan aan toevoeg: 160 Gig harddisk (Maxtor 72000 Rpm), 1 Gig ddr400 werkgeheugen, floppyspeler, dvd brander, 300 Watt voeding...
Zou dit een redelijk systeem zijn??
Alvast bedankt!!!:thumb:
Processor
64-bit Computer: Ja
Kloksnelheid: 3 GHz
M957 V 1.0
SPECIFICATION
Processor
Chipset
System BIOS
Memory
• Maximum: 2GB
Expansion Slots
I/O Interface
• One PS/2 keyboard
• One PS/2 mouse
• One Parallel Port
• One Serial Port
• One VGA port
• One RJ 45 Port
• One CD in header
