Hi
ik heb een problempje elke keer als ik in Paneel Beheer ga en als ik op
[ Nieuw Paneel toevoegen] klik stuurt die mij terug naar home page
weetje michin wat het oorzak kan zijn
hier staan de codes daar van
panel_editor.php:
Als je weet hoe ik me kan reden laat me aub weeten thx
panel_editor.php:
<?php
| PHP-Fusion 6 Content Management System
| Copyright © 2002 - 2006 Nick Jones
| http://www.php-fusion.co.uk/
| Released under the terms & conditions of v2 of the
| GNU General Public License. For details refer to
| the included gpl.txt file or visit http://gnu.org
require_once "../maincore.php";
require_once BASEDIR."subheader.php";
require_once ADMIN."navigation.php";
include LOCALE.LOCALESET."admin/panels.php";
if (!checkrights("P") || !defined("iAUTH") || $aid != iAUTH) fallback("../index.php");
if (isset($panel_id) && !isNum($panel_id)) fallback(FUSION_SELF.$aidlink);
$temp = opendir(INFUSIONS);
while ($folder = readdir($temp)) {
if (!in_array($folder, array(".","..")) && strstr($folder, "_panel")) {
if (is_dir(INFUSIONS.$folder)) $panel_list[] = $folder;
closedir($temp); sort($panel_list); array_unshift($panel_list, "none");
if (isset($_POST['save'])) {
$error = "";
$panel_name = stripinput($_POST['panel_name']);
if ($panel_name == "") $error .= $locale['470']."<br>";
if ($_POST['panel_filename'] == "none") {
$panel_filename = "";
$panel_content = addslash($_POST['panel_content']);
$panel_type = "php";
} else {
$panel_filename = stripinput($_POST['panel_filename']);
$panel_type = "file";
$panel_content = "";
$panel_side = isNum($_POST['panel_side']) ? $_POST['panel_side'] : "1";
$panel_access = isNum($_POST['panel_access']) ? $_POST['panel_access'] : "0";
if ($panel_side == "1" || $panel_side == "4") {
$panel_display = "0";
} else {
$panel_display = isset($_POST['panel_display']) ? "1" : "0";
if (isset($panel_id)) {
if ($panel_name != "") {
$data = dbarray(dbquery("SELECT * FROM ".$db_prefix."panels WHERE panel_id='$panel_id'"));
if ($panel_name != $data['panel_name']) {
$result = dbquery("SELECT * FROM ".$db_prefix."panels WHERE panel_name='$panel_name'");
if (dbrows($result) != 0) $error .= $locale['471']."<br>";
if ($panel_type == "php" && $panel_content == "") $error .= $locale['472']."<br>";
if ($error == "") {
$result = dbquery("UPDATE ".$db_prefix."panels SET panel_name='$panel_name', panel_filename='$panel_filename', panel_content='$panel_content', panel_access='$panel_access', panel_display='$panel_display' WHERE panel_id='$panel_id'");
opentable($locale['480']);
echo "<center><br>\n";
if ($error != "") {
echo $locale['481']."<br><br>\n".$error."<br>\n";
} else {
echo $locale['482']."<br><br>\n";
echo "<a href='panels.php".$aidlink."'>".$locale['486']."</a><br><br>
<a href='index.php".$aidlink."'>".$locale['487']."</a><br><br>
</center>\n";
closetable();
} else {
if ($panel_type == "file" && $panel_filename == "none") $error .= $locale['473']."<br>";
if ($error == "") {
$result = dbquery("SELECT * FROM ".$db_prefix."panels WHERE panel_side='$panel_side' ORDER BY panel_order DESC LIMIT 1");
if (dbrows($result) != 0) { $data = dbarray($result); $neworder = $data['panel_order'] + 1; } else { $neworder = 1; }
$result = dbquery("INSERT INTO ".$db_prefix."panels (panel_name, panel_filename, panel_content, panel_side, panel_order, panel_type, panel_access, panel_display, panel_status) VALUES ('$panel_name', '$panel_filename', '$panel_content', '$panel_side', '$neworder', '$panel_type', '$panel_access', '$panel_display', '0')");
opentable($locale['483']);
if ($error != "") {
echo $locale['484']."<br><br>
".$error."<br>\n";
} else {
echo $locale['485']."<br><br>\n";
</center>\n";
closetable();
} else {
if (isset($_POST['preview'])) {
$panel_filename = $_POST['panel_filename'];
$panel_content = isset($_POST['panel_content']) ? $_POST['panel_content'] : "";
$panel_access = $_POST['panel_access'];
$panel_side = $_POST['panel_side'];
$panelon = isset($_POST['panel_display']) ? " checked" : "";
$panelopts = $_POST['panel_side'] == "1" || $_POST['panel_side'] == "4" ? " style='display:none'" : " style='display:block'";
$panel_content = stripslash($panel_content);
opentable($panel_name);
if ($panel_filename != "none") {
@include INFUSIONS.$panel_filename."/".$panel_filename.".php";
} else {
eval($panel_content);
$panel_content = phpentities($panel_content);
closetable();
tablebreak();
if (isset($step) && $step == "edit") {
$result = dbquery("SELECT * FROM ".$db_prefix."panels WHERE panel_id='$panel_id'");
$panel_name = $data['panel_name'];
$panel_filename = $data['panel_filename'];
$panel_content = phpentities(stripslashes($data['panel_content']));
$panel_type = $data['panel_type'];
$panel_access = $data['panel_access'];
$panel_side = $data['panel_side'];
$panelon = $data['panel_display'] == "1" ? " checked" : "";
$panelopts = $panel_side == "1" || $panel_side == "4" ? " style='display:none'" : " style='display:block'";
$action = FUSION_SELF.$aidlink."&panel_id=$panel_id";
opentable($locale['450']);
} else {
if (!isset($_POST['preview'])) {
$panel_name = "";
$panel_content = "openside(\"name\");\n"." echo \"content\";\n"."closeside();";
$panel_type = "";
$panel_access = "";
$panel_side = "";
$panelon = "";
$panelopts = " style='display:none'";
$action = FUSION_SELF.$aidlink;
opentable($locale['451']);
$user_groups = getusergroups(); $access_opts = "";
while(list($key, $user_group) = each($user_groups)){
$sel = ($panel_access == $user_group['0'] ? " selected" : "");
$access_opts .= "<option value='".$user_group['0']."'$sel>".$user_group['1']."</option>\n";
echo "<form name='editform' method='post' action='$action'>
<table align='center' cellpadding='0' cellspacing='0'>
<tr>
<td class='tbl'>".$locale['452']."</td>
<td class='tbl'><input type='text' name='panel_name' value='$panel_name' class='textbox' style='width:200px;'></td>
</tr>\n";
if ($panel_type == "file") {
echo "<tr>
<td class='tbl'>".$locale['453']."</td>
<td class='tbl'><select name='panel_filename' class='textbox' style='width:200px;'>\n";
for ($i=0;$i < count($panel_list);$i++) {
echo "<option".($panel_filename == $panel_list[$i] ? " selected" : "").">$panel_list[$i]</option>\n";
echo "</select></td>\n</tr>\n";
} else {
echo "<tr>
echo "</select> <span class='small2'>".$locale['454']."</span></td>\n</tr>\n";
if ($panel_type == "php") {
echo "<tr>
<td valign='top' class='tbl'>".$locale['455']."</td>
<td class='tbl'><textarea name='panel_content' cols='95' rows='15' class='textbox'>$panel_content</textarea></td>
</tr>\n";
} else {
echo "<tr>
</tr>\n";
if (!isset($panel_id)) {
echo "<tr>
<td class='tbl'>".$locale['456']."</td>
<td class='tbl'><select name='panel_side' class='textbox' style='width:150px;' onchange=\"showopts(this.options[this.selectedIndex].value);\">
<option value='1'".($panel_side == "1" ? " selected" : "").">".$locale['420']."</option>
<option value='2'".($panel_side == "2" ? " selected" : "").">".$locale['421']."</option>
<option value='3'".($panel_side == "3" ? " selected" : "").">".$locale['425']."</option>
<option value='4'".($panel_side == "4" ? " selected" : "").">".$locale['422']."</option>
</select></td>
</tr>\n";
echo "<tr>
<td class='tbl'>".$locale['457']."</td>
<td class='tbl'><select name='panel_access' class='textbox' style='width:150px;'>
$access_opts</select></td>
</tr>
<tr>
<td align='center' colspan='2' class='tbl'>
<div id='panelopts'".$panelopts."><input type='checkbox' name='panel_display' value='1'$panelon>".$locale['460']."</div>
<br>\n";
if ($panel_type == "php") echo "<input type='hidden' name='panel_filename' value='none'>\n";
echo "<input type='hidden' name='panel_side' value='$panel_side'>\n";
echo "<input type='submit' name='preview' value='".$locale['458']."' class='button'>
<input type='submit' name='save' value='".$locale['459']."' class='button'></td>
</tr>
</table>
</form>\n";
closetable();
echo "<script type='text/javascript'>
function showopts(panelside) {
if (panelside == 1 || panelside == 4) {
panelopts.style.display = 'none';
} else {
panelopts.style.display = 'block';
</script>\n";
echo "</td>\n";
require_once BASEDIR."footer.php";
