IE 6 ondersteunt geen transparantie op zich maar:
The Internet Explorer problem
Up until IE7, there has been no fully native support for PNG alpha channel transparency in Internet Explorer. However, since IE5.5 there has been some support in the form of proprietary filter called the AlphaImageLoader. Internet Explorer filters can be applied directly in your CSS (for both inline and background images), or by setting the same CSS property with JavaScript.
CSS:
img {
filter: progid
XImageTransform.Microsoft.AlphaImageLoader(...);
Source: /code/supersleight-transparent-png-in-ie6/1.txt
JavaScript:
img.style.filter = "progid
XImageTransform.Microsoft.AlphaImageLoader(...)";
Source: /code/supersleight-transparent-png-in-ie6/2.txt
That may sound like a problem solved, but all is not as it may appear. Firstly, as you may realise, there’s no CSS property called filter in the W3C CSS spec. It’s a proprietary extension added by Microsoft that could potentially cause other browsers to reject your entire CSS rule.
Secondly, AlphaImageLoader does not magically add full PNG transparency support so that a PNG in the page will just start working. Instead, when applied to an element in the page, it draws a new rendering surface in the same space that element occupies and loads a PNG into it. If that sounds weird, it’s because that’s precisely what it is. However, by and large the result is that PNGs with an alpha channel can be accommodated.
The pitfalls
So, whilst support for PNG transparency in IE5.5 and 6 is possible, it’s not without its problems.
Background images cannot be positioned or repeated
The AlphaImageLoader does work for background images, but only for the simplest of cases. If your design requires the image to be tiled (background-repeat) or positioned (background-position) you’re out of luck. The AlphaImageLoader allows you to set a sizingMethod to either crop the image (if necessary) or to scale it to fit. Not massively useful, but something at least.
http://24ways.org/2007/supersleight-transparent-png-in-ie6
