The page cannot be displayed
De inhoud van het .php bestand (open het bestand in kladblok, kopieer de code en plak het hier tussen
PHP:
tags).
PHP:
tags).
Ik zal het wel fout hebben gedaan maar bedoelde je dit:
(Ik denk van niet :o)
PHP:
 * Phorm v3.5.2
 * Copyright (c) 1998-2005 Holotech Enterprises (support@phorm.com)
 * You may freely distribute this program as-is, without modifications,
 * and with all accompanying example files, modules and documentation in
 * the original distribution. If you are not sure whether you have a
 * valid distribution, you can obtain one from http://www.phorm.com/.
 * You may use this program freely, and modify it for your own purposes.
 * There is no charge for this program, but if you register it, you will:
 *   1) Encourage me to continue developing it
 *   2) Automatically receive future releases
 *   3) Have free technical support for Phorm
 *   4) Earn my eternal gratitude
 * Also, if you register, you will receive the file upload and file
 * attachment modules. Register at http://www.phorm.com/register/,
 * or include at least your name and email address, and send US$10 to:
 *      Alan Little
 *      Holotech Enterprises
 *      775 Wagner Dr. #11
 *      Battle Creek, Michigan  49017  USA
 * Please make checks and money orders payable to Alan Little.
 * I hope you find this program useful. Aloha.
 *                                                 Alan Little
 *                                                 July 2005
// Return a message with simple variable substitution.
  function ph_Message($MessageKey) {
    global $ph_Messages;
    $Message = $ph_Messages[$MessageKey];
    while (ereg("\\{\\{([^}]*)\\}\\}", $Message, $regs)) {
      $var = $regs[1]; global $$var;
      $Message = str_replace($regs[0], $$var, $Message);
    return $Message;
  Just to be sure */
  $HTTP_REFERER = getenv("HTTP_REFERER");
  $REMOTE_ADDR  = getenv("REMOTE_ADDR");
  $HTTP_HOST    = getenv("HTTP_HOST");
  if ($HTTP_HOST != "www.phorm.loc") error_reporting(E_ERROR | E_WARNING | E_PARSE);
// Prevent global arrays from being included in each other
// Necessary because Phorm is simulating register_globals = on
  $ph_globals = array(
    'HTTP_SERVER_VARS', 'HTTP_ENV_VARS', 'HTTP_COOKIE_VARS',
    'HTTP_GET_VARS', 'HTTP_POST_VARS', 'HTTP_POST_FILES',
    'HTTP_SESSION_VARS', '_SERVER', '_ENV', '_COOKIE',
    '_GET', '_POST', '_POST_FILES', '_SESSION'
  $ph_globals2 = $ph_globals;
  while (list(,$ph_outer) = each($ph_globals)) {
    while (list(,$ph_inner) = each($ph_globals2)) {
	    unset(${$ph_outer}[$ph_inner]);
    reset($ph_globals2);
// Extract POST, GET, COOKIE, FILE and SERVER arrays in case register_globals is off
  if (is_array($_COOKIE))          $HTTP_COOKIE_VARS = $_COOKIE;
  if (is_array($_GET))             $HTTP_GET_VARS    = $_GET;
  if (is_array($_POST))            $HTTP_POST_VARS   = $_POST;
  if (is_array($_SERVER))          $HTTP_SERVER_VARS = $_SERVER;
  if (is_array($_FILES))           $HTTP_POST_FILES  = $_FILES;
  if (is_array($HTTP_COOKIE_VARS)) extract($HTTP_COOKIE_VARS);
  if (is_array($HTTP_GET_VARS))    extract($HTTP_GET_VARS);
  if (is_array($HTTP_POST_VARS))   extract($HTTP_POST_VARS);
  if (is_array($HTTP_SERVER_VARS)) extract($HTTP_SERVER_VARS);
  if (is_array($HTTP_POST_FILES)) {
    while (list($ph_var, $ph_val) = each($HTTP_POST_FILES))
      $$ph_var = $ph_val['tmp_name'];
    reset($HTTP_POST_FILES);
  Unset any ph_ variables to prevent anyone from trying to sneak something
  in (such as ph_debug variables!) */
  $ph_section = "unset ph";
  while (list($ph_var, $ph_val) = each($GLOBALS)) {
    if (ereg("^ph_", $ph_var)) {
      unset($$ph_var);
      unset($ph_var);
  reset($GLOBALS);
  if (!isset($ph_ForceDec)) $ph_ForceDec = true;
  Process PHORM_ variables passed in, and set up the UpFiles array.
  If ForceDec is set, record and unset PHORM_ variables */
  $ph_section = "unset phorm_";
    if (ereg("^PHORM_", $ph_var)) {
      if (ereg("^PHORM_FILE([0-9]{2})$", $ph_var, $ph_regs)) {
        $ph_UpFiles[$ph_regs[1]] = $ph_var;
      if ($ph_ForceDec) {
        $ph_varHold[$ph_var] = $ph_val;
        unset($$ph_var);
  reset($GLOBALS);
  $ph_Vers       = "Phorm v3.5.2";
  $ph_PHMVers    = str_replace("Phorm v", "", $ph_Vers);
  $ph_FILVers    = "3.5.2";
  $ph_PHPMinVers = "3.0.9";
// Set up paths
  $ph_root = getenv("PHORM_ROOT");
  if (strlen($ph_root)  &&
     (!is_dir($ph_root) ||
      !is_dir("$ph_root/lib"))) {
    $ph_Alerts['999'] = "%%% - Invalid directory $ph_root in environment variable PHORM_ROOT.";
    unset($ph_root);
  if (!$ph_root) $ph_root = ".";
  $ph_root = ereg_replace("[/\\\]$", "", $ph_root);
  $ph_cwd = $ph_root;
  $ph_tpd = $ph_cwd; $ph_atd = $ph_cwd; $ph_upd = $ph_cwd;
  if (is_dir("$ph_cwd/templates"))   $ph_tpd.= "/templates";
  if (is_dir("$ph_cwd/attachments")) $ph_atd.= "/attachments";
  if (is_dir("$ph_cwd/uploads"))     $ph_upd.= "/uploads";
  if (file_exists("debugz.php")) include("debugz.php");
// Load the alert and error messages
  if (is_readable("$ph_root/lib/messages.txt")) {
    $ph_msgfile = file("$ph_root/lib/messages.txt");
    while (list(,$ph_mline) = each($ph_msgfile)) {
      $ph_mline = trim($ph_mline);
      if (!$ph_mline || ereg("^#", $ph_mline)) continue;
      // split() instead of explode() for the limit parm in PHP3
      list($ph_mkey, $ph_msg) = split(" ", $ph_mline, 2);
      $ph_Messages[$ph_mkey] = $ph_msg;
    unset($ph_msgfile);
  else {
    $ph_Alerts['00M'] = "%%% - Critical Alert: unable to access alert & error messages file.";
// Load the plugins registry.
  if (is_readable("$ph_root/plugins/registry.php") && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> Registry Load<BR>";
    $ph_registry = file("$ph_root/plugins/registry.php");
    while (list(, $ph_regline) = each($ph_registry)) {
      $ph_regline = trim($ph_regline);
      if (!$ph_regline || !ereg("^< |^> ", $ph_regline)) continue;
      list($ph_beaf, $ph_stage, $ph_plfile) = explode(" ", trim($ph_regline));
      $ph_plfile = basename($ph_plfile);
      $ph_plugbase = str_replace(strrchr($ph_plfile, "."), "", $ph_plfile);
      if (file_exists("$ph_root/plugins/$ph_plugbase/$ph_plfile"))
        $ph_plfile = "$ph_plugbase/$ph_plfile";
      if ($ph_debug32) echo "<B>Plugin:</B> $ph_beaf|$ph_stage|$ph_plfile<BR>";
      $ph_stage = $ph_beaf.$ph_stage;
      $ph_plfile = "$ph_root/plugins/$ph_plfile";
      $ph_Plugins[$ph_stage].= "$ph_plfile|";
    unset($ph_registry);
// Load the function library and MIME types
  $ph_section = "setup";
  $ph_LibLoad = false;
  if (!$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> Library Load...";
    if (is_readable("$ph_root/lib/functions.php")) {
      include("$ph_root/lib/functions.php");
      if ($ph_debug3) echo "done<BR>";
      if ($ph_LibVersion != $ph_Vers) {
        $ph_Errs['001'] = ph_Message("E001");
        $ph_Abort = true;
    else {
      if ($ph_debug3) echo "failed<BR>";
      $ph_Errs['000'] = ph_Message("E000");
      $ph_Abort = true;
//  A missing MIME types file is only a problem if the fileattach module is present.
    if (is_readable("$ph_root/lib/mimetypes.php")) {
      include("$ph_root/lib/mimetypes.php");
    else {
      if (is_readable("$ph_root/lib/fileattach.php")) {
        $ph_Errs['002'] = ph_Message("E002");
        $ph_Abort = true;
// Check the PHP version
  if (!$ph_Abort) {
    if (!ph_CheckVers($ph_PHPMinVers)) {
      $ph_Errs['003'] = ph_Message('E003');
      $ph_Abort = true;
  if (isset($CONTENT_TYPE)) {
  // Check file_uploads if user is uploading.
    if (ereg('^multipart/form-data', $CONTENT_TYPE)
    && ph_CheckVers('4.0.0')
    && !ini_get('file_uploads')) {
      $ph_Alerts['009'] = ph_Message('A009');
      $ph_Errs['009'] = ph_Message('E009');
      $ph_Abort = true;
  if ($ph_debug2) echo '<B>JS:</B> Setup 1<BR>';
  define('ph_OVERWRITE', 1);
  define('ph_MAKEUNIQUE', 2);
  define('ph_MAKEUNIQUESAVED', 3);
  define('ph_DISCARD', 4);
  define('ph_DECLARE', '::FORM::');
  define('ph_GENERIC', '::generic::');
  $ph_extns = array('php', 'php3', 'php4', 'inc', 'txt');
  $ph_UpLoads = is_readable("$ph_root/lib/fileupload.php");
  $ph_vRegs[0]  = '\\{\\{([^}]*)\\}\\}';
  $ph_vRegs[1]  = '\{\{([^}]*)\}\}';
  $ph_vRegs[2]  = '{{([^}]*)}}';
  $ph_vRegs[3]  = '{{2}([^}]*)}{2}';
  $ph_vRegs[4]  = '\{{2}([^}]*)\}{2}';
  $ph_vRegs[5]  = '[{]{2}([^}]*)[}]{2}';
  $ph_vRegs[6]  = '<<([^>]*)>>';
  $ph_vRegs[7]  = '\\{\\{([A-Za-z0-9_]*)\\}\\}';
  $ph_vRegs[8]  = '\{\{([A-Za-z0-9_]*)\}\}';
  $ph_vRegs[9]  = '{{([A-Za-z0-9_]*)}}';
  $ph_vRegs[10] = '{{2}([A-Za-z0-9_]*)}{2}';
  $ph_vRegs[11] = '\{{2}([A-Za-z0-9_]*)\}{2}';
  $ph_vRegs[12] = '[{]{2}([A-Za-z0-9_]*)[}]{2}';
  $ph_vRegs[13] = '<<([A-Za-z0-9_]*)>>';
  $ph_dbLogged = false; $ph_txLogged = false; $ph_eMailed = false;
  $ph_ErrLevel = 0;
  srand((double)microtime()*1000000);
  $ph_HTLink =
    "<BR><BR><CENTER><FONT SIZE=1>".
    "<A HREF=\"http://www.phorm.com/\">$ph_Vers</A>".
    "</FONT></CENTER>";
  $ph_HTTag =
    "\n\n\n\n-- \n$ph_Vers by Holotech Enterprises http://www.holotech.net/";
  $ph_config_delim = "\t";
  $ph_MaxTMPL = 25;
  $ph_GotData = false;
  $ph_Acked   = false;
  $ph_Cards['mastercard']       = 'mcd';
  $ph_Cards['visa']             = 'vis';
  $ph_Cards['american express'] = 'amx';
  $ph_Cards['discover']         = 'dsc';
  $ph_Cards['diners club']      = 'dnc';
  $ph_Cards['delta']            = 'dlt';
  $ph_Cards['switch']           = 'swi';
  $ph_Cards['mcd']              = 'Mastercard';
  $ph_Cards['vis']              = 'Visa';
  $ph_Cards['amx']              = 'American Express';
  $ph_Cards['dsc']              = 'Discover';
  $ph_Cards['dnc']              = 'Diners Club';
  $ph_Cards['dlt']              = 'Delta';
  $ph_Cards['swi']              = 'Switch';
  $ph_Cards['jcb']              = 'JCB';
  $ph_UploadDir = get_cfg_var('upload_tmp_dir');
  $ph_MultiArgs =
    array ('ONEOF', 'FLDLEN', 'RANGE', 'UNIQUE', 'EXISTS', 'FILEEXT');
// Process plugins
  $ph_stage = ">setu1";
  if ($ph_debug34) echo "<B>Stage: </B>".str_replace("<", "&lt;", $ph_stage)."<BR>";
  $ph_PlugList = explode("|", $ph_Plugins[$ph_stage]);
  while (list(, $ph_plfile) = each($ph_PlugList)) {
    if (!$ph_plfile) continue;
    if ($ph_debug33) echo "Plugin <B>$ph_plfile</B> at ".str_replace("<", "&lt;", $ph_stage)."<BR>";
    if (is_readable($ph_plfile)) {
      include ($ph_plfile);
      if ($ph_LibLoad) ph_PlugStat("", "Store");
    else {
      $ph_Alerts['000'] = ph_Message("A000");
  $ph_stage = "<gcnfg";
    else {
// Restore $PHORM_NAME and $PHORM_BASE for phormbase operation
  $PHORM_NAME = $ph_varHold["PHORM_NAME"];
  $PHORM_BASE = $ph_varHold["PHORM_BASE"];
  ph_oveuh();
  Process phormbase */
  $ph_section = "phormbase";
  if ($PHORM_NAME && !$PHORM_BASE) $PHORM_BASE = $PHORM_NAME;
  if ($PHORM_BASE && !$PHORM_NAME) $PHORM_NAME = $PHORM_BASE;
  if ($PHORM_NAME && !$ph_Abort) {
    while (list(,$ph_extn) = each($ph_extns)) {
      $ph_phormbase = "$ph_root/phormbase.$ph_extn";
      if (file_exists($ph_phormbase)) break;
    reset($ph_extns);
    if ($ph_debug3) echo "<B>NS:</B> $ph_phormbase<BR>";
    if (!$ph_BaseFile = @file($ph_phormbase)) {
      $ph_Errs['010'] = ph_Message("E010");
      if ($php_errormsg) $ph_Errs['010P'] = "%%%: $php_errormsg";
      $ph_Abort = true;
    else {
      if ($ph_debug3) echo "<B>NS:</B> Phormbase ($PHORM_NAME: ";
      $ph_linenum = 1;
      while (list(,$ph_bline) = each($ph_BaseFile)) {
        $ph_bline = trim($ph_bline);
        list($ph_form, $ph_path) = split("[ \t]*:[ \t]*|$ph_config_delim", $ph_bline);
        $ph_path = trim($ph_path);
        if ($ph_bline && !$ph_path) $ph_Alerts['020'] = ph_Message("A020");
        if ($ph_form == $PHORM_NAME) {
          if (!ereg("^[/\\\]", $ph_path)) $ph_path = "$ph_root/$ph_path";
          if ($ph_debug3) echo "$ph_path)<BR>";
          $ph_basedir = $ph_path;
        $ph_linenum++;
      if ($ph_debug3 && !strlen($ph_basedir)) echo "No match)<BR>";
  unset($PHORM_BASE);
  Check for the phormconfig file and process it */
  $ph_section = "phormconfig";
    $ph_phormconfig = "$ph_root/phormconfig.$ph_extn";
    if (file_exists($ph_phormconfig)) break;
  reset($ph_extns);
  if (file_exists($ph_phormconfig)) {
    if ($ph_debug3) echo "<B>NS:</B> $ph_phormconfig<BR>";
    if (!is_readable($ph_phormconfig)) {
      $ph_Errs['020'] = ph_Message("E020");
      $ph_Abort = true;
    else {
      include ("$ph_phormconfig");
  $ph_nl = ($PHORM_EMCRLF)? "\r\n" : "\n";
  Check the Referer */
  $ph_section = "referer";
  if ($PHORM_REFERER && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> Referer<BR>";
    ereg("https?://([^/]*)/([^?]*)", $HTTP_REFERER, $ph_regs);
    $ph_RefHost = $ph_regs[1]; $ph_RefPath = $ph_regs[2];
    if (!ereg("\|$ph_RefHost\|", $PHORM_REFERER)
    &&  !ereg("\|$ph_RefHost/$ph_RefPath\|", $PHORM_REFERER)) {
      $ph_Errs['080'] = ph_Message("E080");
      $ph_Abort = true;
// Set the regex to use for variable substitution.
  $ph_section = "regex";
  if ($ph_Regex) $PHORM_REGEX = $ph_Regex;
  if ($ph_RegEx) $PHORM_REGEX = $ph_RegEx;
  if (!$PHORM_REGEX) $PHORM_REGEX = 0;
  if ($PHORM_REGEX > 13) $PHORM_REGEX = 13;
  $ph_vReg   = $ph_vRegs[$PHORM_REGEX];
  if ($ph_debug31) echo "<B>REGEX:</B> ".ereg_replace("<", "&lt;", $ph_vReg)."<BR>\n";
// Process plugins
  $ph_stage = ">gcnfg";
    else {
  $ph_stage = "<lcnfg";
    else {
  Restore the value of PHORM_CONFIG */
  $PHORM_CONFIG = $ph_varHold["PHORM_CONFIG"];
  Check $PHORM_RCONFIG */
  $ph_section = "phorm_rconfig";
  $PHORM_RCONFIG = (!isset($PHORM_RCONFIG) || ($PHORM_RCONFIG != false && $PHORM_RCONFIG != "N"));
  if (($PHORM_RCONFIG && !$PHORM_CONFIG)
  ||  (!count($HTTP_POST_VARS) && !count($HTTP_GET_VARS))) {
    $ph_Abort = true;
    if ($PHORM_URL) $ph_Redirect = $PHORM_URL;
    else $ph_Errs['040'] = ph_Message("E040");
  If there was a match in the phormbase file, change $ph_cwd to the specified dir */
  $ph_section = "chdir 1";
  if ($ph_basedir && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> cwd $ph_basedir<BR>";
    if (!is_dir($ph_basedir)) {
      $ph_Errs['030'] = ph_Message("E030");
      $ph_Abort = true;
    else {
      $ph_cwd = $ph_basedir;
  Process the form-specific configuration file, if any */
  $ph_section = "phorm_config";
  if ($PHORM_CONFIG && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> PHORM_CONFIG ($ph_cwd/$PHORM_CONFIG)<BR>";
//  Strip any path info
    $PHORM_CONFIG = basename($PHORM_CONFIG);
//  If it's there and readable, include it; else generate an error.
    if (is_readable("$ph_cwd/$PHORM_CONFIG")) {
      include("$ph_cwd/$PHORM_CONFIG");
    else {
      $ph_Errs['050'] = ph_Message("E050");
      $ph_Abort = true;
  If $PHORM_BASE was set in the config file, change to the specified dir */
  $ph_section = "chdir 2";
  if ($PHORM_BASE && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> $PHORM_CONFIG: $PHORM_BASE<BR>";
    if (!ereg("^[/\\\]", $PHORM_BASE)) $PHORM_BASE = "$ph_root/$PHORM_BASE";
    if (!is_dir($PHORM_BASE)) {
      $ph_Errs['060'] = ph_Message("E060");
      $ph_Abort = true;
    else {
      $ph_cwd = $PHORM_BASE;
  Restore only the declared configuration variables from the form */
  $ph_section = "restore phorm_";
  if ($ph_ForceDec && is_array($ph_varHold) && !$ph_Abort) {
    while (list($ph_var, $ph_val) = each($ph_varHold)) {
      if ($$ph_var == ph_DECLARE) {
        $$ph_var = $ph_varHold[$ph_var];
          $ph_fvar = $ph_var."_name"; $$ph_fvar = $ph_varHold[$ph_fvar];
          $ph_fvar = $ph_var."_size"; $$ph_fvar = $ph_varHold[$ph_fvar];
          $ph_fvar = $ph_var."_type"; $$ph_fvar = $ph_varHold[$ph_fvar];
  $ph_ParseCode = ($ph_LibLoad && ph_CheckVers("4.0.0") && $PHORM_PARSPHP);
  if (!$PHORM_LINEBRK) $PHORM_LINEBRK = str_replace(" ", "", "
  $PHORM_LINEBRK = str_replace("CR", "\r", $PHORM_LINEBRK);
  $PHORM_LINEBRK = str_replace("LF", "\n", $PHORM_LINEBRK);
// You can't use $PHORM_ACK and $PHORM_RDIRECT together.
  if (strlen($PHORM_ACK) && strlen($PHORM_RDIRECT)) {
    unset($PHORM_RDIRECT);
    $ph_Alerts['100'] =  ph_Message("A100");
// If $PHORM_ACK, $PHORM_RDIRECT and $PHORM_POSTINC are not set, use the generic
// ack template.
  if (!strlen($PHORM_ACK) && !strlen($PHORM_RDIRECT) && !strlen($PHORM_POSTINC)) {
    $PHORM_ACK = ph_GENERIC;
  if (strlen($PHORM_RDIRECT)) $ph_Redirect = $PHORM_RDIRECT;
// Process plugins
  $ph_stage = ">lcnfg";
    else {
  $ph_section = "setup 2";
  $ph_TextLog = (isset($PHORM_LOG) && isset($PHORM_LOGVAR));
// Try to be smart about a few $PHORM_ variables (hope I'm not MSing)
  if (strlen($PHORM_TO) && !strlen($PHORM_ALERTTO)) $PHORM_ALERTTO = $PHORM_TO;
  if (!strlen($PHORM_TMPL))    $PHORM_TMPL = ph_GENERIC;
  if (!strlen($PHORM_SUBJECT)) $PHORM_SUBJECT = "Phorm Data";
  if (!isset($PHORM_FROM)) {
    if     (isset($Email))    $PHORM_FROM = $Email;
    elseif (isset($EMail))    $PHORM_FROM = $EMail;
    elseif (isset($email))    $PHORM_FROM = $email;
    elseif (isset($PHORM_TO)) $PHORM_FROM = $PHORM_TO;
    else                      $PHORM_FROM = $PHORM_ALERTTO;
// Convert "array-able" variables to arrays if they aren't.
  if (isset($PHORM_LOG)) {
    settype($PHORM_LOG, "array");
    list($ph_TextLogFirstKey) = each($PHORM_LOG);
    reset($PHORM_LOG);
  if (isset($PHORM_LOGVAR))  settype($PHORM_LOGVAR, "array");
  if (isset($PHORM_TMPL))    settype($PHORM_TMPL,    "array");
  if (isset($PHORM_TO))      settype($PHORM_TO,      "array");
  if (isset($PHORM_EFROM))   settype($PHORM_EFROM,   "array");
  if (isset($PHORM_SUBJECT)) settype($PHORM_SUBJECT, "array");
  if (isset($PHORM_HEADERS)) settype($PHORM_HEADERS, "array");
  $aPHORM_MYTABLE = is_array($PHORM_MYTABLE);
  if (isset($PHORM_MYTABLE)) settype($PHORM_MYTABLE, "array");
  if (isset($PHORM_MYVARS))  settype($PHORM_MYVARS,  "array");
// Set the text log delimiter if it isn't
  settype($PHORM_LDELIM, "array");
  if (!isset($PHORM_LDELIM[0])) $PHORM_LDELIM[0] = "\t";
// Set the text log quote character if it isn't
  settype($PHORM_LOGQUOT, "array");
  if (!isset($PHORM_LOGQUOT[0])) $PHORM_LOGQUOT[0] = "'";
// Include the database variables file.
  $ph_section = "dbv";
  if ($PHORM_MYDBV && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> Read database variables from $ph_tpd/$PHORM_MYDBV<BR>";
    if (is_readable("$ph_tpd/$PHORM_MYDBV")) {
      include("$ph_tpd/$PHORM_MYDBV");
    else {
      $ph_Alerts['007'] = ph_Message("A007");
// Check file attachment module version
    $ph_fmode = "CheckVers";
    include "$ph_root/lib/fileattach.php";
    if ($ph_FATVers != $ph_FILVers) $ph_Alerts['163'] = ph_message("A163");
// Process plugins
  $ph_stage = ">setu2";
    else {
  $ph_stage = "<filup";
    else {
  Process file uploads */
  if ($ph_UpFiles && !$ph_Abort) {
    if (!$ph_UpLoads) {
      $ph_Alerts['011'] = ph_Message("A011");
    else {
      include "$ph_root/lib/fileupload.php";
      if ($ph_FUPVers == $ph_FILVers) { include "$ph_root/lib/fileupload.php"; }
      else { $ph_Alerts['153'] = ph_message("A153"); }
// Process plugins
  $ph_stage = ">filup";
    else {
  $ph_stage = "<dbopn";
    else {
  Open the database */
  $ph_section = "open db";
  if ($ph_debug71)
    echo "<B>Host:</B> $DHost <B>User:</B> $DUser <B>Pass:</B> $DPass <B>Base:</B> $DBase<BR>";
  if (isset($DHost) && isset($DUser) && isset($DPass) && isset($DBase) && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> Open Database<BR>";
    $ph_ID = @mysql_connect($DHost, $DUser, $DPass);
    if (!$ph_ID) {
      $ph_Alerts['030'] = ph_Message("A030");
      if ($php_errormsg) $ph_Alerts['030P'] = "%%%: $php_errormsg";
    else {
      $ph_selected = @mysql_select_db($DBase, $ph_ID);
      if (!$ph_selected) {
        $ph_Alerts['031'] = ph_Message("A031");
        if ($php_errormsg) $ph_Alerts['031P'] = "%%%: $php_errormsg";
    $ph_dbOpen = ($ph_ID && $ph_selected);
// Process plugins
  $ph_stage = ">dbopn";
    else {
  // Load and parse the rules file.
  if ($PHORM_VALDEFS && !$ph_Abort) {
    $PHORM_VALDEFS = basename($PHORM_VALDEFS);
    if ($ph_debug2) echo "<B><B>JS:</B></B> ValDefs ($ph_tpd/$PHORM_VALDEFS)<BR>";
    if (!$ph_RuleFile = @file("$ph_tpd/$PHORM_VALDEFS")) {
      $ph_Alerts['008'] = ph_Message("A008");
      if ($php_errormsg) $ph_Alerts['008P'] = "%%%: $php_errormsg";
    else {
      if ($PHORM_OLDVAL && is_readable("$ph_root/lib/oldval.php")) {
        include ("$ph_root/lib/oldval.php");
      else {
        $ph_Files = array("");
        $ph_RuleFile = ereg_replace("\r\n?", "\n", implode('', $ph_RuleFile));
        $ph_RuleFile = split("\n *###[\n ]*", $ph_RuleFile);
        $ph_RuleNum = 0;
        while (list($ph_key, $ph_Rule) = each($ph_RuleFile)) {
          $ph_Rule = explode("\n", $ph_Rule);
          if (count($ph_Rule) < 2) continue;
          $ph_RuleNum++;
          unset ($ph_RULE); unset ($ph_CRIT); unset ($ph_FFLD);
          unset ($ph_ARGS); unset ($ph_COND); unset ($ph_LEVL);
          unset ($ph_CMNT); unset ($ph_MESG); unset ($ph_mode);
          while (list(,$ph_element) = each($ph_Rule)) {
            $ph_element = trim($ph_element);
            list($ph_token, $ph_tknval) = split(' *: *', $ph_element, 2);
            $ph_token = strtoupper($ph_token);
            switch ($ph_token) {
            case 'FILES' :
              $ph_RuleNum--;
              $ph_mode = 'FILE';
              break;
            case 'RULE' :
              $ph_RULE = $ph_tknval;
              break;
            case 'CRIT' :
            case 'CRITERION' :
              $ph_CRIT = $ph_tknval;
              break;
            case 'ARGS' :
            case 'ARGUMENTS' :
            case 'ARGUMENT' :
              $ph_ARGS = $ph_tknval;
              ph_VarSub($ph_ARGS);
              break;
            case 'COND' :
            case 'CONDITION' :
              $ph_COND = $ph_tknval;
              break;
            case 'FFLD' :
            case 'FIELD' :
            case 'FORM FIELD' :
            case 'FORMFIELD' :
              $ph_FFLD = $ph_tknval;
              break;
            case 'LEVL' :
            case 'LEVEL' :
              $ph_LEVL = $ph_tknval;
              break;
            case 'CMNT' :
            case 'COMMENT' :
            case 'COMMENTS' :
              $ph_CMNT = $ph_tknval;
              break;
            case 'MESG' :
            case 'MESSAGE' :
              $ph_MESG = $ph_tknval;
              $ph_mode = 'MESG';
              break;
            default :
              if ($ph_mode == "FILE") $ph_Files[] = $ph_element;
              if ($ph_mode == "MESG") $ph_MESG.= "$ph_element ";
              break;
          if ($ph_mode != "FILE") {
            $ph_RuleIdx = (isset($ph_RULE))? $ph_RULE : $ph_RuleNum;
            // Split arguments for multi-argument criteria
            if (in_array($ph_CRIT, $ph_MultiArgs)) {
              $ph_ARGS = str_replace('\ ', "\3", $ph_ARGS);
              $ph_ARGS = split(' +', $ph_ARGS);
              while (list($ph_ix, $ph_arg) = each($ph_ARGS)) {
                $ph_ARGS[$ph_ix] = str_replace("\3", ' ', $ph_arg);
            else settype($ph_ARGS, 'array');
            $ph_Rules[$ph_RuleIdx] = array (
              "CRIT" => $ph_CRIT,
              "FFLD" => $ph_FFLD,
              "ARGS" => $ph_ARGS,
              "COND" => $ph_COND,
              "LEVL" => $ph_LEVL,
              "CMNT" => $ph_CMNT,
              "MESG" => $ph_MESG
// Load plugin criteria
  if (!$ph_Abort) {
    $ph_vdir = opendir("$ph_root/plugins/validation/");
    while ($ph_entry = readdir($ph_vdir)) {
      if (ereg("(.*)\.crit$", $ph_entry, $ph_regs)) {
        $ph_CRIT = strtoupper($ph_regs[1]);
        $ph_critfile = implode('', file("$ph_root/plugins/validation/$ph_entry"));
        if (ereg('\[CRIT:([A-Za-z]*)\]', $ph_critfile, $ph_regs)) {
        $ph_ExtCrits[$ph_CRIT] = "$ph_root/plugins/validation/$ph_entry";
  $ph_stage = "<valid";
    else {
  Perform data validation */
  $ph_section = "validation";
  if ($PHORM_VALDEFS && is_array($ph_Rules) && !$ph_Abort) {
    while (list($ph_RuleNum, $ph_Rule) = each($ph_Rules)) {
      unset ($ph_CRIT); unset ($ph_FFLD); unset ($ph_ARGS);
      unset ($ph_COND); unset ($ph_LEVL); unset ($ph_CMNT); unset ($ph_MESG);
      extract($ph_Rule, EXTR_PREFIX_ALL, "ph");
      if (!$ph_CRIT || !$ph_FFLD || !$ph_MESG) {
        if (!$ph_CRIT) $ph_Alerts['071'] = ph_Message("A071");
        if (!$ph_FFLD) $ph_Alerts['072'] = ph_Message("A072");
        if (!$ph_MESG) $ph_Alerts['073'] = ph_Message("A073");
        continue;
      if (!isset($ph_LEVL)) $ph_LEVL = 1;
      if ($ph_debug42)
          echo "&nbsp;&nbsp;<B>vd:</B>$ph_CRIT ($ph_COND)|$ph_FFLD|$ph_LEVL|$ph_CMNT<BR>";
      $ph_ValErr = false;
      $ph_ValCondition = true;
      $ph_FFLD = ereg_replace("^\$", "", $ph_FFLD);
      $ph_ffld = $ph_FFLD;
      if (!strlen($ph_COND)) $ph_COND = "true";
      ph_VarSub($ph_COND);
      if (!ereg('^\((.*)\)$', $ph_COND)) $ph_COND = "($ph_COND)";
      if ($ph_debug36)
        echo "<B>Phorm@".(__LINE__ + 1)."</B> \$ph_ValCondition = $ph_COND ? true : false;<BR>";
      eval("\$ph_ValCondition = $ph_COND ? true : false;");
      if (is_int(strpos($ph_CRIT, "FILE"))) {
        $ph_FILEID = $ph_FFLD;
        $ph_FFLD = "PHORM_FILE$ph_FFLD";
      $ph_FFLD = str_replace(".", ".$", $ph_FFLD);
      if ($ph_debug36)
        echo "<B>Phorm@".(__LINE__ + 1)."</B> \$ph_Val = \$$ph_FFLD;<BR>";
      eval("\$ph_Val = \$$ph_FFLD;");
      $ph_skipped = ($ph_ValCondition)? "" : "<FONT COLOR=CRIMSON>(skipped)</FONT><BR>";
      if ($ph_debug421)
        echo "&nbsp;&nbsp;<B>vd:</B>#$ph_RuleNum $ph_CRIT [$ph_ffld:$ph_Val] $ph_skipped";
      if (!$ph_ValCondition) continue;
      switch ($ph_CRIT) {
      case "REQ" :
        if (!strlen(trim($ph_Val))) $ph_ValErr = true;
        break;
      case "EMAIL" :
        if (!strlen(trim($ph_Val))) break;
        $ph_EmLevel = $ph_ARGS[0];
        if (!$ph_EmLevel) $ph_EmLevel = 2;
        if (trim($ph_Val) && ph_MailChek($ph_Val, $ph_EmLevel)) $ph_ValErr = true;
        break;
      case "CCARD" :
        if (!$ph_ARGS[0])
          $ph_Alerts['051'] = ph_Message("A051");
        $ph_Valh = $ph_Val;
//      Strip any non-digits out of the card number
        $ph_CType = $$ph_ARGS[0]; $ph_CType = strtolower($ph_CType);
        if (strlen($ph_CType) > 3) $ph_CType = $ph_Cards[$ph_CType];
        $ph_Val = ereg_replace("[^0-9]", "", $ph_Val);
        if (strlen($ph_Val) < 12) $ph_CType = "";
        $ph_CVal = false;
        switch ($ph_CType) {
        case "mcd" :
          $ph_CVal = (ereg("^5[1-5].{14}$", $ph_Val) && ph_luhn($ph_Val));
          break;
        case "vis" :
          $ph_CVal = (ereg("^4.{15}$|^4.{12}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "amx" :
          $ph_CVal = (ereg("^3[47].{13}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "dsc" :
          $ph_CVal = (ereg("^6011.{12}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "dnc" :
          $ph_CVal = (ereg("^30[0-5].{11}$|^3[68].{12}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "jcb" :
          $ph_CVal = (ereg("^3.{15}$|^2131|1800.{11}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "dlt" :
          $ph_CVal = (ereg("^4.{15}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "swi" :
          $ph_CVal = (ereg("^[456].{15}$|^[456].{17,18}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        case "enr" :
          $ph_CVal = (ereg("^2014|.{11}$|^2149.{11}$", $ph_Val) &&
                      ph_luhn($ph_Val));
          break;
        } // switch ($ph_CType)
        if ($ph_Valh && !$ph_CVal) $ph_ValErr = true;
        break;
      case "FILEREQ" :
        if ($ph_FileTable[$ph_FILEID]['stat'] == 1) $ph_ValErr = true;
        break;
      case "NOFILE" :
        if ($ph_FileTable[$ph_FILEID]['stat'] == 2) $ph_ValErr = true;
        break;
      case "FILEDSC" :
        if ($ph_FileTable[$ph_FILEID]['stat'] == 6) $ph_ValErr = true;
        break;
      case "FILEEXT" :
        if (!isset($ph_ARGS[0]))
          $ph_Alerts['066'] = ph_Message("A066");
        $ph_FileExtn = strtolower($ph_FileTable[$ph_FILEID]['extn']);
        $ph_aidx = 0; $ph_Match = false;
        while ($ph_ARGS[$ph_aidx])
           if (strtolower($ph_ARGS[$ph_aidx++]) == $ph_FileExtn) $ph_Match = true;
        if ($ph_FileExtn && !$ph_Match) {
          $ph_ValErr = true;
          if (!ereg('[1236]', $ph_FileTable[$ph_FILEID]['stat']))
            @unlink("$ph_upd/".$ph_FileTable[$ph_FILEID]['full']);
        break;
      case "FILESIZ" :
          $ph_Alerts['067'] = ph_Message("A067");
        if ($ph_FileTable[$ph_FILEID]['size'] > $ph_ARGS[0]) {
          $ph_ValErr = true;
          if ($ph_FileTable[$ph_FILEID]['stat'] != 6)
        break;
      case "FILERR" :
        if ($ph_FileTable[$ph_FILEID]['stat'] == 3) {
          $ph_FileName = $ph_FileTable[$ph_FILEID]['full'];
          $ph_ValErr = true;
        break;
      case "REGEX" :
          $ph_Alerts['050'] = ph_Message("A050");
        if (!ereg($ph_ARGS[0], $ph_Val)) $ph_ValErr = true;
        break;
      case "UNIQUE" :
        if (!isset($ph_ARGS[1])) $ph_Alerts['060'] = ph_Message("A060");
        if (!$ph_dbOpen)         $ph_Alerts['061'] = ph_Message("A061");
        if ($ph_dbOpen) {
          $ph_uCol = $ph_ARGS[0];
          if (ereg("\+", $ph_uCol)) {
            $ph_uCols = explode("+", $ph_uCol);
            $ph_uCol = "concat(";
            while (list(,$ph_val) = each($ph_uCols)) {
              if ($ph_uCol > "concat(") $ph_uCol.= ",";
              $ph_uCol.= $ph_val;
            $ph_uCol.= ")";
//        First check for a $PHORM_MYTABLE index, for backward compatibility
          if (is_numeric($ph_ARGS[1])) {
            if (is_array($PHORM_MYTABLE)) $ph_uTable = $PHORM_MYTABLE[$ph_ARGS[1]];
            else $ph_uTable = $PHORM_MYTABLE;
          else $ph_uTable = $ph_ARGS[1];
          $ph_UNQQString = "select * from $ph_uTable where $ph_uCol='$ph_Val'";
          if ($ph_debug72) echo "<B>UNIQUE:</B> $ph_UNQQString<BR>";
          $ph_Result = MySQL_Query($ph_UNQQString, $ph_ID);
          if (!$ph_Result || MySQL_Error()) {
            $ph_UNQMyErr = ereg_replace("[^A-Za-z0-9'., ]","",MySQL_Error());
            $ph_Alerts['062'] = ph_Message("A062");
          else {
            if (MySQL_Num_Rows($ph_Result) > 0) $ph_ValErr = true;
        break;
      case "EXISTS" :
        if (!isset($ph_ARGS[1])) $ph_Alerts['063'] = ph_Message("A063");
        if (!$ph_dbOpen)         $ph_Alerts['064'] = ph_Message("A064");
        if ($ph_dbOpen) {
              $ph_uCol.= $ph_val;
            $ph_uCol.= ")";
          $ph_EXSQString = "select * from $ph_uTable where $ph_uCol='$ph_Val'";
          if ($ph_debug72) echo "<B>EXISTS:</B> $ph_EXSQString<BR>";
          $ph_Result = MySQL_Query($ph_EXSQString, $ph_ID);
            $ph_EXSMyErr = ereg_replace("[^A-Za-z0-9'., ]","",MySQL_Error());
            $ph_Alerts['065'] = ph_Message("A065");
          else {
            if (MySQL_Num_Rows($ph_Result) == 0) $ph_ValErr = true;
        break;
      case "PHONE" :
        $ph_Match = ereg("^(\(?[0-9]{3}\)?[ -])?[0-9]{3}[ -][0-9]{4}$", $ph_Val);
        if ($ph_Val && !$ph_Match) $ph_ValErr = true;
        break;
      case "PHONEC" :
        if (!ereg("^[0-9() +-]*$", $ph_Val)) $ph_ValErr = true;
        break;
      case "RANGE" :
          $ph_Alerts['052'] = ph_Message("A052");
        if ($ph_Val < $ph_ARGS[0] || $ph_Val > $ph_ARGS[1])
          $ph_ValErr = true;
        break;
      case "ONEOF" :
          $ph_Alerts['053'] = ph_Message("A053");
        $ph_Match = false;
        while (list(,$ph_ARG) = each($ph_ARGS))
           if ($ph_ARG == $ph_Val) $ph_Match = true;
        if (!$ph_Match) $ph_ValErr = true;
        break;
      case "DATECMP":
          $ph_Alerts['068'] = ph_Message("A068");
        $ph_nowDate = date("Ymd");
        list($ph_fldMo, $ph_fldDa, $ph_fldYr) = explode("/", $ph_Val);
        if (strlen($ph_fldMo) <  2) $ph_fldMo = "0$ph_fldMo";
        if (strlen($ph_fldDa) <  2) $ph_fldDa = "0$ph_fldDa";
        if (strlen($ph_fldYr) == 2) $ph_fldYr = "20$ph_fldYr";
        $ph_fldDate = $ph_fldYr.$ph_fldMo.$ph_fldDa;
        if ($ph_ARGS[1])
          list($ph_maxMo, $ph_maxDa, $ph_maxYr) = explode("/", $ph_ARGS[1]);
        else
          list($ph_maxMo, $ph_maxDa, $ph_maxYr) = explode("/", "99/99/9999");
        if (strlen($ph_maxMo) < 2) $ph_maxMo = "0$ph_maxMo";
        if (strlen($ph_maxDa) < 2) $ph_maxDa = "0$ph_maxDa";
        if (strlen($ph_maxYr) < 4) $ph_maxYr = "20$ph_maxYr";
        $ph_maxDate = $ph_maxYr.$ph_maxMo.$ph_maxDa;
        if (ereg("[!<>=]", $ph_ARGS[0])) {
          $ph_cmpDate = ($ph_ARGS[1])? $ph_maxDate : $ph_nowDate;
          switch ($ph_ARGS[0]) {
          case "=" :
            if ($ph_fldDate != $ph_cmpDate) $ph_ValErr = true;
            break;
          case ">" :
            if ($ph_fldDate <= $ph_cmpDate) $ph_ValErr = true;
            break;
          case "<" :
            if ($ph_fldDate >= $ph_cmpDate) $ph_ValErr = true;
            break;
          case "<=" :
            if ($ph_fldDate >  $ph_cmpDate) $ph_ValErr = true;
            break;
          case ">=" :
            if ($ph_fldDate <  $ph_cmpDate) $ph_ValErr = true;
            break;
          case "!=" :
            if ($ph_fldDate == $ph_cmpDate) $ph_ValErr = true;
            break;
        else {
          list($ph_minMo, $ph_minDa, $ph_minYr) = explode("/", $ph_ARGS[0]);
          if (strlen($ph_minMo) < 2) $ph_minMo = "0$ph_minMo";
          if (strlen($ph_minDa) < 2) $ph_minDa = "0$ph_minDa";
          if (strlen($ph_minYr) < 4) $ph_minYr = "20$ph_minYr";
          $ph_minDate = $ph_minYr.$ph_minMo.$ph_minDa;
          if ($ph_fldDate < $ph_minDate || $ph_fldDate > $ph_maxDate) $ph_ValErr = true;
        break;
      case "ALPHA" :
        if (!ereg("^[A-Za-z]*$", $ph_Val)) $ph_ValErr = true;
        break;
      case "NUMERIC" :
        if (!ereg("^[-+]?[,0-9]*\.?[0-9]*$", $ph_Val)) $ph_ValErr = true;
        break;
      case "FLDLEN":
        if (!isset($ph_ARGS[2]))
          $ph_Alerts['069'] = ph_Message("A069");
        if ($ph_ARGS[2] == "=" && $ph_ARGS[1] > 0) $$ph_FFLD = substr($$ph_FFLD, 0, $ph_ARGS[1]);
        else {
          if (strlen($ph_Val) < $ph_ARGS[0] || ($ph_ARGS[1] > 0 && strlen($ph_Val) > $ph_ARGS[1]))
          $ph_ValErr = true;
        break;
      case "GT" :
        if (!isset($ph_ARGS[0])) $ph_Alerts['054'] = ph_Message("A054");
        if ($ph_Val <= $ph_ARGS[0]) $ph_ValErr = true;
        break;
      case "LT" :
        if (!isset($ph_ARGS[0])) $ph_Alerts['055'] = ph_Message("A055");
        if ($ph_Val >= $ph_ARGS[0]) $ph_ValErr = true;
        break;
      case "EQ" :
        if (!isset($ph_ARGS[0])) $ph_Alerts['056'] = ph_Message("A056");
        if ($ph_Val != $ph_ARGS[0]) $ph_ValErr = true;
        break;
      case "GE" :
        if (!isset($ph_ARGS[0])) $ph_Alerts['057'] = ph_Message("A057");
        if ($ph_Val < $ph_ARGS[0]) $ph_ValErr = true;
        break;
      case "LE" :
        if (!isset($ph_ARGS[0])) $ph_Alerts['058'] = ph_Message("A058");
        if ($ph_Val > $ph_ARGS[0]) $ph_ValErr = true;
        break;
      case "NE" :
        if (!isset($ph_ARGS[0])) $ph_Alerts['059'] = ph_Message("A059");
        if ($ph_Val == $ph_ARGS[0]) $ph_ValErr = true;
        break;
      default:
        if (isset($ph_ExtCrits[$ph_CRIT])) {
          include $ph_ExtCrits[$ph_CRIT];
        else {
          if (!is_int(strpos($ph_Crits, $ph_CRIT."|"))) {
            $ph_BadCrit = $ph_CRIT;
            $ph_Alerts['070'] = ph_Message("A070");
        break;
      } // switch ($ph_CRIT)
      if ($ph_debug421 && $ph_ValErr)  echo " - <FONT COLOR=CRIMSON>[<B>Fail</B>]</FONT><BR>";
      if ($ph_debug421 && !$ph_ValErr) echo " - <FONT COLOR=TEAL>[<B>Pass</B>]</FONT><BR>";
      if ($ph_ValErr) {
        $ph_ValidErr = true;
        $ph_ErrLevel = max($ph_ErrLevel, $ph_LEVL);
        if ($ph_Invals) $ph_Invals.= ",";
        $ph_Invals.= $ph_RuleNum;
        $ph_ErrMsgs[$ph_RuleNum] = $ph_MESG;
        if ($ph_ErrMsgs[$ph_FFLD]) $ph_ErrMsgs[$ph_FFLD].= "<BR>\n";
        $ph_ErrMsgs[$ph_FFLD].= $ph_MESG;
        if ($ph_ValMsg[$ph_LEVL]) $ph_ValMsg[$ph_LEVL] .= "<BR>\n";
        $ph_ValMsg[$ph_LEVL] .= $ph_MESG;
    } // Process rules
    if ($ph_ErrLevel) {
      $ph_MaxLevel = sizeof($ph_Files) - 1;
      $ph_errfile = $ph_ErrLevel;
      if ($ph_errfile > $ph_MaxLevel) $ph_errfile = $ph_MaxLevel;
      $ph_ErrFileName = $ph_Files[$ph_errfile];
      if (ereg('^\$[/\\]', $ph_ErrFileName)) {
        if (isset($DOCUMENT_ROOT)) {
          $ph_ErrFileName =
            ereg_replace('[/\\]$', '', $DOCUMENT_ROOT).substr($ph_ErrFileName, 1);
        else {
          $ph_Alerts['012'] = ph_Message("A012");
          $ph_ErrFileName = $ph_tpd.'/'.basename($ph_ErrFileName);
      else {
        if (!ereg("^[./]|^[A-Za-z]:", $ph_ErrFileName))
          $ph_ErrFileName = "$ph_tpd/$ph_ErrFileName";
//    Parse the message for variable replacements.
      $ph_ValMessage = $ph_ValMsg[$ph_ErrLevel];
      ph_VarSub($ph_ValMessage);
//    If we can't open the error template file...
      if (!strlen($ph_ErrFileName)
      ||  !is_readable($ph_ErrFileName)
      ||  !is_file($ph_ErrFileName)) {
        if (!is_readable($ph_ErrFileName))
          $ph_Alerts['001'] = ph_Message("A001");
//      ...try the generic error template, or use a hard-coded template
        if (!$ph_ErrFile = @implode("", @file("$ph_root/files/valid_err.html")))
        $ph_ErrFile = "
        <HTML>
        <HEAD>
        <TITLE>Data Validation Error</TITLE>
        </HEAD>
        <BODY BGCOLOR=#FFC0C0 TEXT=#800000>
        <CENTER><H3>Data Validation Error</H3></CENTER>
        {{ph_ValMessage}}
        <BR><BR>
        Use your browser's BACK button to return to the form.
        {{ph_HTLink}}
        </BODY>
        </HTML>";
        ph_VarSub($ph_ErrFile);
//    Otherwise, read and parse the error template
      else {
        $ph_ErrFile = implode("", file($ph_ErrFileName));
//      Add our tag at the end of the file.
        if (eregi("</BODY>", $ph_ErrFile))
          $ph_ErrFile = eregi_replace("</BODY>", "$ph_HTLink\n<!-- Generated by Phorm -->\n</BODY>", $ph_ErrFile);
        else
          $ph_ErrFile.= "$ph_HTLink<!-- Generated by Phorm -->";
//      Insert the error message(s) in the appropriate place(s)
        while (is_int($ph_tagstart = strpos($ph_ErrFile, "<!-- Phorm Messages"))) {
          $ph_tagend = strpos($ph_ErrFile, "-->", $ph_tagstart);
          $ph_taglen = $ph_tagend - $ph_tagstart + 3;
          $ph_datalen = max(0, $ph_taglen - 23);
          $ph_tag = substr($ph_ErrFile, $ph_tagstart, $ph_taglen);
          $ph_dat = trim(substr($ph_ErrFile, $ph_tagstart + 20, $ph_datalen));
          list($ph_idx, $ph_HTML) = split(" ", $ph_dat, 2);
          if ($ph_idx == "%%%") {
            if ($ph_ValMsg[$ph_ErrLevel])
              $ph_HTML = str_replace("###", $ph_ValMsg[$ph_ErrLevel], $ph_HTML);
            else $ph_HTML = "";
          elseif (!$ph_idx) {
            if ($ph_ValMsg[$ph_ErrLevel]) $ph_HTML = $ph_ValMsg[$ph_ErrLevel];
            else $ph_HTML = "";
          elseif ($ph_idx && !$ph_HTML) {
            if ($ph_ErrMsgs[$ph_idx]) $ph_HTML = $ph_ErrMsgs[$ph_idx];
            else $ph_HTML = "";
          else {
              $ph_HTML = str_replace("###", $ph_ErrMsgs[$ph_idx], $ph_HTML);
            else $ph_HTML = "";
          $ph_ErrFile = str_replace($ph_tag, $ph_HTML, $ph_ErrFile);
        if (ereg("\.php[34]?$", $ph_ErrFileName) && $ph_ParseCode) {
          ob_start();
          eval("?>$ph_ErrFile<?");
          $ph_ErrFile = ob_get_contents();
          ob_end_clean();
//      Parse the file for variable replacements.
//      Parse the file for form fields for data recycling
        $ph_ErrFileUC = strtoupper($ph_ErrFile);
        $ph_TagTable = ph_ParseHTML($ph_ErrFile, 'INPUT, SELECT, TEXTAREA', true);
        if (is_array($ph_TagTable)) {
          if ($ph_debug422) echo '<B>Fields are displayed in reverse order.</B><BR>';
          while (list($ph_TagStart, $ph_tTag) = each($ph_TagTable)) {
            $ph_Tag    = $ph_tTag['tag'];
            $ph_TagLen = $ph_tTag['len'];
            $ph_Atts  = ph_ParseTag($ph_Tag);
            $ph_Atts  = $ph_Atts[0];
            $ph_TAG   = $ph_Atts['TAG'];
            $ph_TYPE  = $ph_Atts['TYPE'];
            $ph_VALUE = $ph_Atts['VALUE'];
            $ph_NAME  = $ph_Atts['NAME'];
            $ph_Variable = $ph_NAME;
            if (ereg('([^\[]+)\[.*\]', $ph_Variable, $ph_regs)) {
              $ph_Variable = $ph_regs[1];
            unset($ph_Atts['tag']); unset($ph_Atts['len']);
            unset($ph_Atts['TAG']);
            unset($ph_FldVal); unset($ph_FldArray);
            // Determine the value for this field
            if (is_array($$ph_Variable)) {     // Array value
              if ($ph_debug36)
                echo "<B>Phorm@".(__LINE__ + 2).
                "</B> \$ph_FldArray = \$$ph_Variable;<BR>";
              eval("\$ph_FldArray = \$$ph_Variable;");
              if (ereg('(.+)\[\]$', $ph_NAME, $ph_regs)) {    // An empty index
                $ph_ArrayName = $ph_regs[1];
                if (!$ph_ArrayFldVals[$ph_ArrayName]) {
                  $ph_ArrayItem = str_replace('[', "['", $ph_ArrayName);
                  $ph_ArrayItem = str_replace(']', "']", $ph_ArrayItem);
                  if ($ph_debug36)
                    "</B> \$ph_ArrayFldVals['$ph_ArrayName'] = \$$ph_ArrayItem;<BR>";
                  eval("\$ph_ArrayFldVals['$ph_ArrayName'] = \$$ph_ArrayItem;");
                  $ph_ArrayFldVals[$ph_ArrayName] = array_reverse($ph_ArrayFldVals[$ph_ArrayName]);
                list(,$ph_FldVal) = each($ph_ArrayFldVals[$ph_ArrayName]);
              else {                                          // All filled indices
                if ($ph_debug36)
                  echo "<B>Phorm@".(__LINE__ + 1)."</B> \$ph_FldVal = \$$ph_NAME;<BR>";
                eval("\$ph_FldVal = \$$ph_NAME;");
            // Non-array value
            else $ph_FldVal = $$ph_NAME;
            if ($ph_debug422)
              echo "<B>FF:</B> $ph_TAG ($ph_TYPE) \"$ph_NAME\" = $ph_FldVal<BR>\n";
            switch($ph_TAG) {
            case 'INPUT':
              if (!isset($ph_TYPE)) $ph_TYPE = '';
              switch(strtoupper($ph_TYPE)) {
              case ''    :
              case 'TEXT':
                $ph_Atts['VALUE'] = $ph_FldVal;
                break; // case "TEXT":
              case "CHECKBOX" :
                unset($ph_Atts['CHECKED']);
                if (is_array($ph_FldArray)) {
                  if (in_array($ph_VALUE, $ph_FldArray))
                    $ph_Atts['CHECKED'] = true;
                else {
                  if (strlen(trim($ph_FldVal))) $ph_Atts['CHECKED'] = true;
                break; // case "CHECKBOX" :
              case "RADIO" :
                $ph_Atts['CHECKED'] = ($ph_VALUE == $ph_FldVal)? true : false;
                break; // case "RADIO" :
              case 'HIDDEN' :
                break; // case 'HIDDEN'
              }    // switch ($ph_TYPE)
              $ph_RepTag = "<$ph_TAG";
              while (list($ph_Attribute, $ph_AttVal) = each($ph_Atts)) {
                if (!is_bool($ph_AttVal))
                  $ph_RepTag.= " $ph_Attribute=\"$ph_AttVal\"";
                else
                  if ($ph_AttVal) $ph_RepTag.= " $ph_Attribute";
              $ph_RepTag.= '>';
              $ph_ErrFile =
              substr($ph_ErrFile, 0, $ph_TagStart)
                    .$ph_RepTag
                    .substr($ph_ErrFile, $ph_TagStart + $ph_TagLen);
              break; // case "INPUT":
            case "TEXTAREA":
              $ph_TClose = strpos($ph_ErrFileUC, "</TEXTAREA", $ph_TagStart);
              $ph_ValStart = $ph_TagStart + $ph_TagLen;
              $ph_ValLen = $ph_TClose - $ph_ValStart;
              if (is_integer($ph_TClose)) {
                $ph_TVal = substr($ph_ErrFile, $ph_ValStart, $ph_ValLen);
                $ph_ErrFile =
                substr($ph_ErrFile, 0, $ph_ValStart)
                      .$ph_FldVal
                      .substr($ph_ErrFile, $ph_TClose);
              break; // case "TEXTAREA":
            case "SELECT":
              $ph_Selected = (isset($ph_FldArray))? $ph_FldArray : $ph_FldVal;
              if (!is_array($ph_Selected)) settype($ph_Selected, "array");
              $ph_EndSel       = strpos($ph_ErrFileUC, "</SELECT", $ph_TagStart);
              $ph_SelBlockLen  = $ph_EndSel - $ph_TagStart + 9;
              $ph_SelBlock     = substr($ph_ErrFile, $ph_TagStart, $ph_SelBlockLen);
              $ph_SelBlockUC   = strtoupper($ph_SelBlock);
              $ph_RepBlock = $ph_Tag."\n";
              $ph_oTagEnd = 0; unset($ph_OptionTable);
              $ph_OptionTable = ph_ParseHTML($ph_SelBlock, "OPTION", false);
              if (is_array($ph_OptionTable)) {
                while (list($ph_oTagStart, $ph_otTag) = each($ph_OptionTable)) {
                  $ph_oTag    = $ph_otTag['tag'];
                  $ph_oTagLen = $ph_otTag['len'];
                  $ph_oAtts = ph_ParseTag($ph_oTag);
                  $ph_oAtts  = $ph_oAtts[0];
                  $ph_VALUE = $ph_oAtts["VALUE"];
                  unset($ph_oAtts['tag']); unset($ph_oAtts['len']);
                  unset($ph_oAtts['TAG']);
                  $ph_oTClose = strpos($ph_SelBlockUC, "</OPTION", $ph_oTagStart);
                  $ph_oValStart = $ph_oTagStart + $ph_oTagLen;
                  $ph_oValLen = $ph_oTClose - $ph_oValStart;
                  if (is_integer($ph_oTClose))
                    $ph_Content = substr($ph_SelBlock, $ph_oValStart, $ph_oValLen);
//                If there's no VALUE attribute, use the element content.
                  if (!$ph_VALUE) $ph_VALUE = $ph_Content;
                  $ph_oAtts['SELECTED'] =
                    (in_array($ph_VALUE, $ph_Selected))? true : false;
                  $ph_oTag = '  <OPTION';
                  while (list($ph_Attribute, $ph_AttVal) = each($ph_oAtts)) {
                      $ph_oTag.= " $ph_Attribute=\"$ph_AttVal\"";
                    else
                      if ($ph_AttVal) $ph_oTag.= " $ph_Attribute";
                  $ph_oTag.= '>';
                  $ph_RepBlock.= $ph_oTag.$ph_Content."</OPTION>\n";
                } // while <OPTION>
              }   // if ($OptionTable)
              $ph_RepBlock.= '</SELECT>';
              $ph_ErrFile =
                    .$ph_RepBlock
                    .substr($ph_ErrFile, $ph_TagStart + $ph_SelBlockLen);
              break; // case "SELECT":
            } // switch ($ph_TAG)
          } // while <INPUT|TEXTAREA|SELECT>
        } // is_array($ph_TagTable)
      } // else (parse error file)
      $ph_Abort = true;
      unset($ph_Redirect);
    } // if ($ph_ErrLevel)
// Process plugins
  $ph_stage = ">valid";
    else {
  echo $ph_ErrFile;
  $ph_stage = "<fopen";
    else {
  Load the acknowledgement template file. */
  $ph_section = "open files";
  if ($PHORM_ACK && !$ph_Abort) {
    if ($PHORM_ACK == ph_GENERIC)        $PHORM_ACK = "$ph_root/files/generic.html";
    else if (!strpos($PHORM_ACK, '://')) $PHORM_ACK = "$ph_tpd/$PHORM_ACK";
    if ($ph_debug3) echo "<B>NS:</B> Open Ack Template <B>$PHORM_ACK</B>.<BR>";
    if (!$ph_AckFile = @file($PHORM_ACK)) {
      $ph_Errs['070'] = ph_Message("E070");
      if ($php_errormsg) $ph_Errs['070P'] = "%%%: $php_errormsg";
      $ph_Abort = true;
    else $ph_AckFile = implode("", $ph_AckFile);
  Load the autoresponder template file */
  if ($PHORM_RESPOND && !$ph_Abort) {
    if ($ph_debug3) echo "<B>NS:</B> Open Responder <B>$PHORM_RESPOND</B>.<BR>";
    if (!$ph_ResponderFile = @file("$ph_tpd/$PHORM_RESPOND")) {
      $ph_Alerts['002'] = ph_Message("A002");
      if ($php_errormsg) $ph_Alerts['002P'] = "%%%: $php_errormsg";
  Open the log file(s) */
  while ($ph_TextLog && (list($ph_key, $lPHORM_LOG) = each($PHORM_LOG)) && !$ph_Abort) {
    if (!ereg("^[/\\\]", $lPHORM_LOG)) $lPHORM_LOG = "$ph_tpd/$lPHORM_LOG";
    if ($ph_debug3) echo "<B>NS:</B> Open Log File <B>$lPHORM_LOG</B>.<BR>";
    if (!$ph_lf[$ph_key] = @fopen($lPHORM_LOG, "a")) {
      $ph_Alerts['004'] = ph_Message("A004");
      if ($php_errormsg) $ph_Alerts['004P'] = "%%%: $php_errormsg";
// Process plugins
  $ph_stage = ">fopen";
    else {
  $ph_stage = "<dblog";
    else {
  Log to MySQL Database */
  $ph_section = "db log";
  if ($ph_dbOpen && isset($PHORM_MYTABLE) && isset($PHORM_MYVARS) && !$ph_Abort) {
    if ($ph_debug2) echo "<B>JS:</B> MySQL Logger.<BR>";
    while (list($ph_key, $lPHORM_MYTABLE) = each($PHORM_MYTABLE)) {
      $lPHORM_MYVARS = $PHORM_MYVARS[$ph_key];
      if (!strlen(trim($lPHORM_MYVARS))) continue;
      $ph_CVPairs = split(" ?, ?", $lPHORM_MYVARS);
      $ph_idx = -1;
      $ph_Vals = "'";
      $ph_Cols = "";
      while (list(,$ph_CVPair) = each($ph_CVPairs)) {
        list($ph_Col, $ph_Var) = split(" *= *", $ph_CVPair);
        $ph_Var = ereg_replace("^\\$", "", $ph_Var);
        if (strlen($ph_Cols) > 1) $ph_Cols.= ",";
        if (strlen($ph_Vals) > 1) $ph_Vals.= ",'";
        if (ereg("'([^']*)'", $ph_Var, $ph_regs)) $ph_Value = $ph_regs[1];
        else {
          if ($ph_debug36)
            echo "<B>Phorm@".(__LINE__ + 1)."</B> \$ph_Value = \$$ph_Var;<BR>";
          eval("\$ph_Value = \$$ph_Var;");
        if (!get_magic_quotes_gpc()) $ph_Value = AddSlashes($ph_Value);
        $ph_Vals.= $ph_Value."'";
        $ph_Cols.= $ph_Col;
      $ph_LOGQString = "insert into $lPHORM_MYTABLE ($ph_Cols) values ($ph_Vals)";
      if ($ph_debug72) echo "<B>Log:</B> $ph_LOGQString<BR>";
      $ph_Result = MySQL_Query($ph_LOGQString, $ph_ID);
      $ph_LOGMyErr = ereg_replace("[^A-Za-z0-9'., ]","",MySQL_Error());
      if (!$ph_Result) $ph_Alerts['040'] = ph_Message("A040");
      else $ph_dbLogged = true;
      $ph_InsertID = MySQL_Insert_ID($ph_ID);
      if ($aPHORM_MYTABLE) $PHORM_MYSQLID[$ph_key] = $ph_InsertID;
      else $PHORM_MYSQLID = $ph_InsertID;
    $ph_GotData = ($ph_GotData || $ph_dbLogged);
// Process plugins
  $ph_stage = ">dblog";
    else {
  $ph_stage = "<respn";
    else {
  Read the autoresponder template and email it back to the visitor */
  $ph_section = "autoresponder";
  if ($ph_ResponderFile && $PHORM_FROM && !$ph_Abort) {
    if ($ph_debug2) echo "<B>JS:</B> Parse Autoresponder <B>$PHORM_RESPOND</B>.<BR>";
    $ph_Message = implode("", $ph_ResponderFile);
    ph_VarSub($ph_Message);
    ph_VarSub($PHORM_RESUBJ);
//  Add our tag at the end of the message.
    if ($ph_HTTag) $ph_Message.= $ph_HTTag;
//  Construct the headers and send the message
    $ph_Headers = "From: $PHORM_RESFROM$ph_nl";
    if ($PHORM_RESRPLY) $ph_Headers.= "Reply-to: $PHORM_RESRPLY$ph_nl";
    $PHORM_RESHDRS = ereg_replace("\r\n?", "\n", $PHORM_RESHDRS);
    $PHORM_RESHDRS = eregi_replace("X-Mailer:[^\n]*\n", "", $PHORM_RESHDRS);
    $ph_Headers.= $PHORM_RESHDRS."X-Mailer: PHP/$ph_Vers$ph_nl";
    if (isset($PHORM_RESATCH)) {
      if ($ph_debug3) echo "<B>NS:</B> Autoresponder Attach File <B>$PHORM_RESATCH</B>.<BR>";
      if (!is_readable("$ph_atd/$PHORM_RESATCH")) {
        $ph_Alerts['003'] = ph_Message("A003");
      else {
          $ph_AttachList[] = "$ph_atd/$PHORM_RESATCH";
          include("$ph_root/lib/fileattach.php");
        else {
          $ph_Alerts['010'] = ph_Message("A010");
    if ($PHORM_EMCRLF) {
      while (ereg("[^\r]\n", $ph_Message))
        $ph_Message = ereg_replace("([^\r])\n", "\\1\r\n", $ph_Message);
      while (ereg("[^\r]\n", $ph_Headers))
        $ph_Headers = ereg_replace("([^\r])\n", "\\1\r\n", $ph_Headers);
    if ($ph_debug52)
      echo
      "<B>Responder:</B>\n".
      "<BLOCKQUOTE><PRE>\n".
      "To: $PHORM_FROM\n".
      "Subject: $PHORM_RESUBJ\n".
      $ph_Headers."\n".
      $ph_Message."\n".
      "</PRE></BLOCKQUOTE>\n";
    $PHORM_FROM   = ereg_replace("\r?\n", '', $PHORM_FROM);
    $PHORM_RESUBJ = ereg_replace("\r?\n", '', $PHORM_RESUBJ);
    if (!
    @Mail($PHORM_FROM,
         $PHORM_RESUBJ,
         $ph_Message,
         $ph_Headers)
      $ph_Alerts['110'] = ph_Message("A110");
      if ($php_errormsg) $ph_Alerts['110P'] = "%%%: $php_errormsg";
  } // ($PHORM_RESPOND)
// Process plugins
  $ph_stage = ">respn";
    else {
  $ph_stage = "<txlog";
    else {
  Log variables to the text log file. */
  $ph_section = "text log";
  while ($ph_TextLog && (list($ph_key, $lPHORM_LOGVAR) = each($PHORM_LOGVAR)) && !$ph_Abort) {
    if (!$ph_lf[$ph_key]) $ph_key = $ph_TextLogFirstKey;
    $lPHORM_LDELIM  = $PHORM_LDELIM[$ph_key];
    $lPHORM_LOGQUOT = $PHORM_LOGQUOT[$ph_key];
    $lPHORM_LOG     = $PHORM_LOG[$ph_key];
    if (!strlen($lPHORM_LDELIM))  $lPHORM_LDELIM  = $PHORM_LDELIM[0];
    if (!strlen($lPHORM_LOGQUOT)) $lPHORM_LOGQUOT = $PHORM_LOGQUOT[0];
    if ($ph_debug2) echo "<B>JS:</B> Log to text file <B>$lPHORM_LOG</B>.<BR>";
    $ph_LogVars = split(",? +", $lPHORM_LOGVAR);
    unset($ph_LogLine);
    while (list(,$ph_LogVar) = each($ph_LogVars)) {
      $ph_lQuote = (ereg("'", $ph_LogVar))? substr($lPHORM_LOGQUOT, 0, 1) : "";
      $ph_rQuote = (ereg("'", $ph_LogVar))? substr($lPHORM_LOGQUOT, -1) : "";
      $ph_LogVar = str_replace("'", "", $ph_LogVar);
      $ph_LogVar = ereg_replace("^\\$", "", $ph_LogVar);
//    If $$ph_LogVar is an array, break it down
      ereg("^([A-Za-z0-9_]*)((\[[A-Za-z0-9_]*\])*)$", $ph_LogVar, $ph_regs);
      $ph_LogVar  = $ph_regs[1];
      $ph_indices = $ph_regs[2];
      $ph_indices = split("\]\[", ereg_replace("^\[|\]$", "", $ph_indices));
      $ph_Value = $$ph_LogVar;
      while (is_array($ph_Value)) {
        list(,$ph_SubIdx) = each($ph_indices);
        if (!strlen($ph_SubIdx)) break;
        $ph_SubIdx = ereg_replace("^['\"]|['\"]$", "", $ph_SubIdx);
        $ph_Value = $ph_Value[$ph_SubIdx];
      $ph_LogLine[] = $ph_lQuote.$ph_Value.$ph_rQuote;
    $ph_LogLine = implode($lPHORM_LDELIM, $ph_LogLine);
    if ($ph_lf[$ph_key]) $ph_nul = fputs($ph_lf[$ph_key], $ph_LogLine.$PHORM_LINEBRK);
    if ($ph_nul) $ph_txLogged = true;
    $ph_GotData = ($ph_GotData || $ph_txLogged);
// Process plugins
  $ph_stage = ">txlog";
    else {
  $ph_stage = "<email";
    else {
  Read the mail template file(s) and mail it (them) to the user */
  $ph_section = "user template";
  if (strlen($PHORM_ALERTTO) && !strlen($PHORM_TO) && !$PHORM_INFONLY && !$ph_GotData) {
    $PHORM_TO = $PHORM_ALERTTO;
  if (isset($PHORM_TMPL) && isset($PHORM_TO) && !$ph_Abort) {
    if ($ph_debug2) echo "<B>JS:</B> Mail Template(s)<BR>";
    if (count($PHORM_TMPL) > $ph_MaxTMPL) $ph_Alerts['120'] = ph_Message("A120");
    list(,$fPHORM_TO)      = each($PHORM_TO);
    list(,$fPHORM_SUBJECT) = each($PHORM_SUBJECT);
    while ($ph_MaxTMPL-- && list($ph_key, $lPHORM_TMPL) = each($PHORM_TMPL)) {
      if ($lPHORM_TMPL == ph_GENERIC) $lPHORM_TMPL = "$ph_root/files/generic.txt";
      else                            $lPHORM_TMPL = "$ph_tpd/$lPHORM_TMPL";
      $ph_Message   = "";
      $ph_Headers   = "";
      $ph_NonHeader = "";
      $lPHORM_TO      = "";
      $lPHORM_FROM    = "";
      $lPHORM_SUBJECT = "";
      $lPHORM_HEADERS = "";
      $ph_TemplateHeaders = false;
      if (ereg("(.+) +\+h$", $lPHORM_TMPL, $ph_regs)) {
        $lPHORM_TMPL = trim($ph_regs[1]);
        $ph_TemplateHeaders = true;
      if ($ph_debug8) echo "Mail Template <B>$lPHORM_TMPL</B><BR>";
      if (!$ph_Template = @implode("", file($lPHORM_TMPL))) {
        $ph_Alerts['005'] = ph_Message("A005");
        if ($php_errormsg) $ph_Alerts['005P'] = "%%%: $php_errormsg";
        continue;
//    Convert all line breaks to LF for easier processing
      $ph_Template = ereg_replace("\r\n?", "\n", $ph_Template);
      ph_VarSub($ph_Template, true);
      $ph_Message = $ph_Template;
//    First see if there are headers included in the template
      if ($ph_TemplateHeaders) {
        list($ph_Headers, $ph_Message) = split("\n\n", $ph_Message, 2);
        $ph_Headers = explode("\n", $ph_Headers);
        while (list(,$ph_Header) = each($ph_Headers)) {
          list($ph_token, $ph_tknval) = split(": ", $ph_Header, 2);
//        If the line isn't really a header, move it down to the message.
          if (!strlen($ph_tknval)) {
            $ph_NonHeader.= "$ph_token$ph_nl";
            continue;
          case "To" :
            $lPHORM_TO  = $ph_tknval;
            break;
          case "From" :
            $lPHORM_FROM = $ph_tknval;
            break;
          case "Subject" :
            $lPHORM_SUBJECT = $ph_tknval;
            break;
          default:
            $lPHORM_HEADERS.= $ph_Header."$ph_nl";
        if (strlen($ph_NonHeader)) $ph_Message = $ph_NonHeader.$ph_Message;
      if (!strlen($lPHORM_TO))      $lPHORM_TO      = $PHORM_TO[$ph_key];
      if (!strlen($lPHORM_FROM))    $lPHORM_FROM    = $PHORM_EFROM[$ph_key];
      if (!strlen($lPHORM_SUBJECT)) $lPHORM_SUBJECT = $PHORM_SUBJECT[$ph_key];
      if (!strlen($lPHORM_TO))      $lPHORM_TO      = $fPHORM_TO;
      if (!strlen($lPHORM_FROM))    $lPHORM_FROM    = $PHORM_FROM;
      if (!strlen($lPHORM_SUBJECT)) $lPHORM_SUBJECT = $fPHORM_SUBJECT;
      $lPHORM_HEADERS.= ereg_replace("\r\n?", "\n", $PHORM_HEADERS[$ph_key]);
      if (strlen($lPHORM_FROM)) {
        if (strlen($lPHORM_HEADERS) && !ereg("\n$", $lPHORM_HEADERS)) $lPHORM_HEADERS.= "$ph_nl";
        $lPHORM_HEADERS.= "From: $lPHORM_FROM$ph_nl";
      ph_VarSub($lPHORM_SUBJECT);
      $lPHORM_HEADERS = eregi_replace("X-Mailer:[^\n]*\n", "", $lPHORM_HEADERS);
      $ph_Headers = $lPHORM_HEADERS."X-Mailer: PHP/$ph_Vers$ph_nl";
      if ($ph_AttachList) {
        $ph_FileList = implode(", ", $ph_AttachList);
        $ph_s = (sizeof($ph_AttachList > 1))? "s" : "";
        if ($ph_debug3) echo "<B>NS:</B> Email Attach File$ph_s <B>$ph_FileList</B>.<BR>";
        else {
          $ph_Alerts['006'] = ph_Message("A006");
      $lPHORM_TO      = ereg_replace("\r?\n", '', $lPHORM_TO);
      $lPHORM_SUBJECT = ereg_replace("\r?\n", '', $lPHORM_SUBJECT);
      if ($ph_debug81)
        echo
        "To: $lPHORM_TO\n".
        "Subject: $lPHORM_SUBJECT\n".
        $ph_Headers."\n".
        $ph_Message."\n".
      if (
      @Mail($lPHORM_TO,
           $lPHORM_SUBJECT,
           $ph_Message,
           $ph_Headers)
      ) $ph_eMailed = true;
      else {
        $ph_Alerts['121'] = ph_Message("A121");
        if ($php_errormsg) $ph_Alerts['121P'] = "%%%: $php_errormsg";
      $ph_GotData = ($ph_GotData || $ph_eMailed);
// Process plugins
  $ph_stage = ">email";
    else {
  $ph_GotData = ($ph_GotData || $PHORM_INFONLY);
  if (!$ph_GotData && !$ph_ValidErr && !$ph_Redirect) {
    if (!$ph_Errs['040']) $ph_Errs['090'] = ph_Message("E090");
    $ph_Abort = true;
  $ph_stage = "<ackpg";
    else {
  Read the ack template and output it. */
  $ph_section = "ack";
  if ($ph_AckFile && !$ph_Abort)  {
    if ($ph_debug2) echo "<B>JS:</B> Ack Template <B>$PHORM_ACK</B><BR>";
    if (ereg("\.php[34]?$", $PHORM_ACK) && $ph_ParseCode) {
      ob_start();
      eval("?>$ph_AckFile<?");
      $ph_AckFile = ob_get_contents();
      ob_end_clean();
    $ph_AckFile = eregi_replace("<!-- Phorm Messages -->", $ph_ValMsg[0], $ph_AckFile);
    ph_VarSub($ph_AckFile);
    if (eregi("</BODY>", $ph_AckFile, $ph_regs))
      $ph_AckFile =
        eregi_replace("</BODY>", "$ph_HTLink\n<!-- Generated by Phorm -->\n$ph_regs[0]", $ph_AckFile);
    else
      $ph_AckFile.= "$ph_HTLink\n<!-- Generated by Phorm -->";
// Process plugins
  $ph_stage = ">ackpg";
    else {
    echo $ph_AckFile;
    $ph_Acked = true;
  $ph_stage = "<pproc";
    else {
  If PHORM_POSTINC is defined, include it. */
  $ph_section = "postinc";
  if ($PHORM_POSTINC)  {
    if ($ph_debug3) echo "<B>NS:</B> Post Processing <B>$PHORM_POSTINC</B>.<BR>";
    if (!is_readable("$ph_tpd/$PHORM_POSTINC")) {
      $ph_Alerts['130'] = ph_Message("A130");
      $ph_Abort = true;
    else include("$ph_tpd/$PHORM_POSTINC");
// Process plugins
  $ph_stage = ">pproc";
    else {
  $ph_stage = "<aande";
    else {
  Email any alerts and errors to the user, if an address was specified. */
  if (($ph_Alerts || $ph_Errs) && $PHORM_ALERTTO) {
    $ph_Message = '';
    $ph_errs = ''; $ph_alerts = '';
    // Get rid of some clutter
    unset($ph_Quotes); unset($ph_mime); unset($ph_HTTag);
    unset($ph_HTLink); unset($ph_vRegs); unset($ph_Messages);
    $ph_GLOBALS = ph_ArrayDump($GLOBALS, true);
    if (is_array($ph_Errs)) {
      while (list($ph_errno, $ph_err) = each($ph_Errs)) {
        $ph_err = str_replace("%%%", $ph_errno, $ph_err);
        while (ereg($ph_vReg, $ph_err, $ph_regs))
          $ph_err = str_replace($ph_regs[0], $$ph_regs[1], $ph_err);
        $ph_errs.= "$ph_err\n";
      reset($ph_Errs);
    if (is_array($ph_Alerts)) {
      while (list($ph_alertno, $ph_alert) = each($ph_Alerts)) {
        $ph_alert = str_replace("%%%", $ph_alertno, $ph_alert);
        while (ereg($ph_vReg, $ph_alert, $ph_regs))
          $ph_alert = str_replace($ph_regs[0], $$ph_regs[1], $ph_alert);
        $ph_alerts.= "$ph_alert\n";
      reset($ph_Alerts);
    $ph_errs   = ereg_replace("<[^>]*>", "", $ph_errs);
    $ph_alerts = ereg_replace("<[^>]*>", "", $ph_alerts);
    if ($ph_errs) $ph_Message = "Fatal errors displayed to visitor:$ph_nl$ph_errs$ph_nl$ph_nl";
    if ($ph_alerts) $ph_Message.= "Internal Alerts:$ph_nl$ph_alerts$ph_nl";
    $ph_Message.= "{$ph_nl}Phorm: http://$HTTP_HOST{$REQUEST_URI}";
    $ph_Message.= "{$ph_nl}HTTP_REFERER: $HTTP_REFERER";
    $ph_Message.= "{$ph_nl}REMOTE_ADDR: $REMOTE_ADDR$ph_nl$ph_nl";
    $ph_Message.= "Global Variables:$ph_nl";
    $ph_Message.= $ph_GLOBALS;
    if (!$PHORM_ALERTFM) $PHORM_ALERTFM = "Phorm Processor <Phorm.Processor>";
    $ph_Headers = "From: $PHORM_ALERTFM$ph_nl".
                  "X-Mailer: PHP3/$ph_Vers$ph_nl";
    if (!
    @mail($PHORM_ALERTTO,
         "Phorm Alert",
         $ph_Message,
         $ph_Headers)
      $ph_Alerts['140'] = ph_Message("A140");
      if ($php_errormsg) $ph_Alerts['140P'] = "%%%: $php_errormsg";
  Display any fatal error messages to the visitor. Display internal alerts, if PHORM_ALERTTO is
  not defined or there was an error on emailing alerts. */
  $ph_section = "errors";
  if ($ph_Errs || ($ph_Alerts && ($ph_debug1 || !$PHORM_ALERTTO || $ph_Alerts['140']))) {
    $ph_errs = ""; $ph_alerts = "";
        $ph_errs.= "$ph_err<BR>\n";
      reset($ph_Errs);
        $ph_alerts.= "$ph_alert<BR>\n";
      reset($ph_Alerts);
    if ($ph_errs) $ph_errmsg = "<B>Errors:</B><BR>\n$ph_errs\n<BR>\n";
    if ($ph_alerts) $ph_errmsg.= "<B>Alerts:</B><BR>\n$ph_alerts\n";
    // Output the messages.
    if ($ph_Acked) {
      echo $ph_errmsg;
    else {
      $ph_ErrPage = "$ph_root/files/$PHORM_NAME"."_err.html";
      if (!is_readable($ph_ErrPage)) $ph_ErrPage = "$ph_root/files/phorm_err.html";
      if (is_readable($ph_ErrPage)) {
        $ph_errpage = implode("", file($ph_ErrPage));
        $ph_errpage = str_replace("<!-- Phorm Messages -->", $ph_errmsg, $ph_errpage);
        if (function_exists('ph_VarSub')) ph_VarSub($ph_errpage);
        echo $ph_errpage;
      else {
        echo "<HTML>\n".
             "<HEAD>\n".
             "<TITLE>Phorm Error</TITLE>\n".
             "</HEAD>\n".
             "<BODY BGCOLOR=#FFD0C1 TEXT=#800000>\n\n".
             "<H3>Phorm Messages</H3>\n".
             "$ph_errmsg\n".
             "$ph_HTLink\n".
             "</BODY></HTML>";
// Process plugins
  $ph_stage = ">aande";
    else {
  if ($ph_Redirect) Header("Location: $ph_Redirect");
  function ph_oveuh() {
    eval(base64_decode(
    'Z2xvYmFsJFBIT1JNX0VBU1RSRUcsJFBIT1JNX05BTUU7JHBoX1F1b3Rlcz1hcnJheSgnIklmIGEg'.
    'bmF0aW9uIGV4cGVjdHMgdG8gYmUgaWdub3JhbnQgYW5kIGZyZWUgaW4gYSBzdGF0ZSBvZiBjaXZp'.
    'bGl6YXRpb24sIGl0IGV4cGVjdHMgd2hhdCBuZXZlciB3YXMgYW5kIG5ldmVyIHdpbGwgYmUuIElm'.
    'IHdlIGFyZSB0byBndWFyZCBhZ2FpbnN0IGlnbm9yYW5jZSBhbmQgcmVtYWluIGZyZWUsIGl0IGlz'.
    'IHRoZSByZXNwb25zaWJpbGl0eSBvZiBldmVyeSBBbWVyaWNhbiB0byBiZSBpbmZvcm1lZC4iPEJS'.
    'PiZuYnNwOyZuYnNwOy0tIFRob21hcyBKZWZmZXJzb24nLCciVGhlIG9uZSBpbXB1bHNlIGluIG1h'.
    'biB3aGljaCBjYW5ub3QgYmUgZXJhc2VkIGlzIGhpcyBpbXB1bHNlIHRvd2FyZCBmcmVlZG9tLCBo'.
    'aXMgaW1wdWxzZSB0b3dhcmQgc2FuaXR5LCB0b3dhcmQgaGlnaGVyIGxldmVscyBvZiBhdHRhaW5t'.
    'ZW50IGluIGFsbCBvZiBoaXMgZW5kZWF2b3JzLiI8QlI+Jm5ic3A7Jm5ic3A7LS0gTC4gUm9uIEh1'.
    'YmJhcmQnLCciSXQgaXMgb25seSBpbXBlcmZlY3Rpb24gdGhhdCBjb21wbGFpbnMgb2Ygd2hhdCBp'.
    'cyBpbXBlcmZlY3QuIFRoZSBtb3JlIHBlcmZlY3Qgd2UgYXJlLCB0aGUgbW9yZSBnZW50bGUgYW5k'.
    'IHF1aWV0IHdlIGJlY29tZSB0b3dhcmRzIHRoZSBkZWZlY3RzIG9mIG90aGVycy4iPEJSPiZuYnNw'.
    'OyZuYnNwOy0tIEpvc2VwaCBBZGRpc29uJywnIk9uZSBvZiB0aGUgcGVuYWx0aWVzIGZvciByZWZ1'.
    'c2luZyB0byBwYXJ0aWNpcGF0ZSBpbiBwb2xpdGljcyBpcyB0aGF0IHlvdSBlbmQgdXAgYmVpbmcg'.
    'Z292ZXJuZWQgYnkgeW91ciBpbmZlcmlvcnMuIjxCUj4mbmJzcDsmbmJzcDstLSBQbGF0bycsJyJB'.
    'cyBhIGNoaWxkLCB0aGUgbWVhc3VyZSBvZiB5b3VyIHByb2dyZXNzIGlzIGhvdyBtdWNoIHlvdSBj'.
    'YW4gZG8gZm9yIHlvdXJzZWxmLiBBcyBhbiBhZHVsdCwgdGhlIG1lYXN1cmUgb2YgeW91ciBwcm9n'.
    'cmVzcyBpcyBob3cgbXVjaCB5b3UgY2FuIGRvIGZvciBvdGhlcnMuIjxCUj4mbmJzcDsmbmJzcDst'.
    'LSBNZXRodXNlbGFoIEpvbmVzJywnIkNpdmlsaXphdGlvbiBpcyBub3Qgc29tZXRoaW5nIGluYm9y'.
    'biBvciBpbXBlcmlzaGFibGU7IGl0IG11c3QgYmUgYWNxdWlyZWQgYW5ldyBieSBldmVyeSBnZW5l'.
    'cmF0aW9uLiBNYW4gZGlmZmVycyBmcm9tIHRoZSBiZWFzdCBvbmx5IGJ5IGVkdWNhdGlvbiwgd2hp'.
    'Y2ggbWF5IGJlIGRlZmluZWQgYXMgdGhlIHRlY2huaXF1ZSBvZiB0cmFuc21pdHRpbmcgY2l2aWxp'.
    'emF0aW9uLiI8QlI+Jm5ic3A7Jm5ic3A7LS0gV2lsbCBEdXJhbnQnLCciRXZpbCBuZXZlciBzZWVz'.
    'IGl0c2VsZiBpbiB0aGUgbWlycm9yLiI8QlI+Jm5ic3A7Jm5ic3A7LS0gSi4gTWljaGFlbCBTdHJh'.
    'Y3p5bnNraScsJyJJbiBvcmRlciB0byBkaXNjb3ZlciB3aG8geW91IGFyZSwgZmlyc3QgbGVhcm4g'.
    'd2hvIGV2ZXJ5Ym9keSBlbHNlIGlzIC0gYW5kIHlvdVwncmUgd2hhdFwncyBsZWZ0LiI8QlI+Jm5i'.
    'c3A7Jm5ic3A7LS0gQXNobGVpZ2ggQnJpbGxpYW50JywnIlNlcnZpY2UgdG8gb3RoZXJzIGlzIHRo'.
    'ZSByZW50IHlvdSBwYXkgZm9yIHlvdXIgcm9vbSBoZXJlIG9uIGVhcnRoLiI8QlI+Jm5ic3A7Jm5i'.
    'c3A7LS0gTXVoYW1tYWQgQWxpJywnIlRoZSBmdXR1cmUgaXMgYWxsIGFyb3VuZCB1cywgd2FpdGlu'.
    'ZyBpbiBtb21lbnRzIG9mIHRyYW5zaXRpb24sIHRvIGJlIGJvcm4gaW4gbW9tZW50cyBvZiByZXZl'.
    'bGF0aW9uLiI8QlI+Jm5ic3A7Jm5ic3A7LS0gR1wnS2FyLCBCYWJ5bG9uIDUnLCciQ2Vuc29ycyBm'.
    'ZWVsIHRoZXkgYXJlIHNhZmUgZnJvbSBvYmplY3Rpb25hYmxlIG1hdGVyaWFsIGJ1dCBtdXN0IHBy'.
    'b3RlY3Qgb3RoZXJzIHdobyBhcmUgbm90IGFzIHNtYXJ0IG9yIG1vcmFsLiI8QlI+Jm5ic3A7Jm5i'.
    'c3A7LS0gUm9nZXIgRWJlcnQnLCdFdmVyeWJvZHkgaXMgc29tZWJvZHkgZWxzZVwncyB3ZWlyZG8u'.
    'JywnIlByb2dyZXNzIGluIHNjaWVuY2UgaXMgc29tZXRoaW5nIGxpa2UgY2xpbWJpbmcgYSBtb3Vu'.
    'dGFpbi4gT25seSBtb3N0IG1vdW50YWluZWVycyBkb25cJ3Qgc2V0IHVwIGEgbmV3IGJhc2VjYW1w'.
    'IGV2ZXJ5IHRlbiBmZWV0LCB0aGVuIGxlYXAgb3V0IGFuZCBhdHRhY2sgYW55b25lIHdobyB0cmll'.
    'cyB0byBjbGltYiBwYXN0IHRoZW0uIjxCUj4mbmJzcDsmbmJzcDstLSBCaWxsIEJlYXR5JywnIkkg'.
    'aG9wZSB3ZSBzaGFsbCBjcnVzaCBpbiBpdHMgYmlydGggdGhlIGFyaXN0b2NyYWN5IG9mIG91ciBt'.
    'b25pZWQgY29ycG9yYXRpb25zIHdoaWNoIGRhcmUgYWxyZWFkeSB0byBjaGFsbGVuZ2Ugb3VyIGdv'.
    'dmVybm1lbnQgdG8gYSB0cmlhbCBvZiBzdHJlbmd0aCwgYW5kIGJpZCBkZWZpYW5jZSB0byB0aGUg'.
    'bGF3cyBvZiBvdXIgY291bnRyeS4iPEJSPiZuYnNwOyZuYnNwOy0tIFRob21hcyBKZWZmZXJzb24n'.
    'LCciV2FyIG1heSBzb21ldGltZXMgYmUgYSBuZWNlc3NhcnkgZXZpbC4gQnV0IG5vIG1hdHRlciBo'.
    'b3cgbmVjZXNzYXJ5LCBpdCBpcyBhbHdheXMgYW4gZXZpbCwgbmV2ZXIgYSBnb29kLiBXZSB3aWxs'.
    'IG5vdCBsZWFybiBob3cgdG8gbGl2ZSB0b2dldGhlciBpbiBwZWFjZSBieSBraWxsaW5nIGVhY2gg'.
    'b3RoZXJcJ3MgY2hpbGRyZW4uIjxCUj4mbmJzcDsmbmJzcDstLSBKaW1teSBDYXJ0ZXInLCciTmF0'.
    'dXJhbGx5IHRoZSBjb21tb24gcGVvcGxlIGRvblwndCB3YW50IHdhci4gQnV0IGFmdGVyIGFsbCBp'.
    'dCBpcyB0aGUgbGVhZGVycyBvZiBhIGNvdW50cnkgd2hvIGRldGVybWluZSBwb2xpY3ksIGFuZCBp'.
    'dCBpcyBhbHdheXMgYSBzaW1wbGUgbWF0dGVyIHRvIGRyYWcgdGhlIHBlb3BsZSBhbG9uZy4gQWxs'.
    'IHlvdSBoYXZlIHRvIGRvIGlzIHRlbGwgdGhlbSB0aGV5IGFyZSBiZWluZyBhdHRhY2tlZCwgYW5k'.
    'IGRlbm91bmNlIHRoZSBwYWNpZmlzdHMgZm9yIGxhY2sgb2YgcGF0cmlvdGlzbSBhbmQgZXhwb3Np'.
    'bmcgdGhlIGNvdW50cnkgdG8gZGFuZ2VyLiI8QlI+Jm5ic3A7Jm5ic3A7LS0gSGVybWFubiBHb2Vy'.
    'aW5nJywnIldhdGNoIG91dCEgSXRcJ3MgcXVpdGUgcG9zc2libGUgdGhhdCBzb21lIG9mIG15IGJl'.
    'c3QgbWlzdGFrZXMgaGF2ZW5cJ3QgeWV0IGJlZW4gbWFkZS4iPEJSPiZuYnNwOyZuYnNwOy0tIEFz'.
    'aGxlaWdoIEJyaWxsaWFudCcsJyJUaGUgd29ybGQgaXMgYWx3YXlzIHJlYWR5IHRvIHJlY2VpdmUg'.
    'dGFsZW50IHdpdGggb3BlbiBhcm1zLiBWZXJ5IG9mdGVuIGl0IGRvZXMgbm90IGtub3cgd2hhdCB0'.
    'byBkbyB3aXRoIGdlbml1cy4iPEJSPiZuYnNwOyZuYnNwOy0tIE9saXZlciBXZW5kZWxsIEhvbG1l'.
    'cycsJyJJIGxvdmUgdGhlIG1hbiBiZXR0ZXIgd2hvIHN3ZWFycyBhIHN0cmVhbSBhcyBsb25nIGFz'.
    'IG15IGFybSB5ZXQgZGVhbHMganVzdGljZSB0byBoaXMgbmVpZ2hib3JzIGFuZCBtZXJjaWZ1bGx5'.
    'IGRlYWxzIGhpcyBzdWJzdGFuY2UgdG8gdGhlIHBvb3IsIHRoYW4gdGhlIGxvbmcsIHNtb290aC1m'.
    'YWNlZCBoeXBvY3JpdGUuIjxCUj4mbmJzcDsmbmJzcDstLSBKb3NlcGggU21pdGgnLCciVmlvbGVu'.
    'Y2UgaXMgdGhlIGxhc3QgcmVmdWdlIG9mIHRoZSBpbmNvbXBldGVudC4iPEJSPiZuYnNwOyZuYnNw'.
    'Oy0tIElzYWFjIEFzaW1vdicpO2lmKCRQSE9STV9OQU1FPT0nUGhvcm1Jc0Nvb2wnKSRQSE9STV9F'.
    'QVNUUkVHPSRwaF9RdW90ZXNbcmFuZCgwLDE5KV07'));
php installeren wil niet zeggen zat jouw webserver ook weet dat het php kan verwerken. Maak eens een nieuw bestand met de inhoud
PHP:
<?php
	phpinfo();
en sla het op als test.php. Zet het op jouw eigen server en op de planet/kpn server en ga in je browser naar test.php. Wat krijg je dan te zien?
Dat bevestigd mijn vermoeden nogmaals. Wat krijg je te zien als je het op je eigen server probeert? Ik denk dat je letterlijk de tekst te zien krijgt omdat je bent vergeten de webserver te configureren dus ik ben benieuwd.
Op mijn eigen server geplaatst: http://www.dj-gilbert.com/test.php en zie dan weer:
You have attempted to execute a CGI, ISAPI, or other executable program from a directory that does not allow programs to be executed.
Please try the following:
* Contact the Web site administrator if you believe this directory should allow execute access.
HTTP Error 403.1 - Forbidden: Execute access is denied.
Internet Information Services (IIS)
Technical Information (for support personnel)
* Go to Microsoft Product Support Services and perform a title search for the words HTTP and 403.
* Open IIS Help, which is accessible in IIS Manager (inetmgr), and search for topics titled Configuring ISAPI Extensions, Configuring CGI Applications, Securing Your Site with Web Site Permissions, and About Custom Error Messages.
* In the IIS Software Development Kit (SDK) or at the MSDN Online Library, search for topics titled Developing ISAPI Extensions, ISAPI and CGI, and Debugging ISAPI Extensions and Filters.
Dit is voor het eerst dat ik met php te maken heb en zal dan inderdaad wel veel zijn vergeten in te stellen puur uit onwetendheid. Ik heb al diverse sites bezocht met informatie over php maar kom er gewoonweg niet meer uit. Probeer het altijd eerst zelf maar als dat niet lukt dan vraag ik jullie om hulp :o
Conclusie:
  • planet/kpn biedt geen ondersteuning voor php
  • je hebt op je eigen server wel php geinstalleerd, maar je bent vergeten iis te configureren
Ik heb zelf geen ervaring met iis en het configureren daarvan, maar misshien dat iemand anders je kan helpen (of anders kun je altijd nog even googlen).
Conclusie:
In ieder geval bedankt voor de moeite en ik heb volgens mij een site gevonden waar ik wat aan ga hebben: http://www.vanenter.nl/blog/index.php/2007/php-installeren-op-windows-2003-iis/ nu ff geen tijd meer maar hopelijk vanavond wel. Thx again !
Klasse flits! Mooi stukje helpdesk zo! ;)
Maarre, spiritual, je kunt in plaats van IIS ook ff WAMP / XAMPP / USBWebServer pakken. Daar hoef je vrijwel niets voor te configureren en dan draai je Apache in plaats van IIS. Nooit problemen mee.
