Public Class Form1
Dim op As String
Dim num1 As Double = 0
Dim num2 As Double = 0
Private Sub Button11_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button11.Click
num1 = CDbl(TextBox1.Text)
TextBox1.Text = ""
op = "+"
Private Sub Button12_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button12.Click
TextBox1.Text = ""
op = "-"
Private Sub Button13_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button13.Click
TextBox1.Text = ""
op = "*"
Private Sub Button14_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button14.Click
TextBox1.Text = ""
op = "/"
Private Sub Button17_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button17.Click
TextBox1.Text = ""
op = "%"
Private Sub Button15_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button15.Click
If TextBox1.Text = "" Then
Exit Sub
Else
num2 = CDbl(TextBox1.Text)
If op = "+" Then
TextBox1.Text = num1 + num2
ElseIf op = "-" Then
TextBox1.Text = num1 - num2
ElseIf op = "*" Then
TextBox1.Text = num1 * num2
ElseIf op = "/" Then
TextBox1.Text = num1 / num2
ElseIf op = "%" Then
TextBox1.Text = (num1 / 100) * (num2)
Private Sub TextBox()
TextBox1.Text = FormatNumber(TextBox1.Text, 2)
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
TextBox1.Text = TextBox1.Text & 2
Private Sub Button1_MouseClick(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles Button1.MouseClick
TextBox1.Text = TextBox1.Text & 1
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
TextBox1.Text = TextBox1.Text & 3
Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
TextBox1.Text = TextBox1.Text & 4
Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.Click
TextBox1.Text = TextBox1.Text & 5
Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.Click
TextBox1.Text = TextBox1.Text & 6
Private Sub Button7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.Click
TextBox1.Text = TextBox1.Text & 7
Private Sub Button8_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button8.Click
TextBox1.Text = TextBox1.Text & 8
Private Sub Button9_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button9.Click
TextBox1.Text = TextBox1.Text & 9
Private Sub Button10_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button10.Click
TextBox1.Text = TextBox1.Text & 0
Private Sub Button16_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button16.Click
TextBox1.Text = TextBox1.Text & ","
Private Sub Button18_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button18.Click
TextBox1.Text = ""
Private Sub Button19_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button19.Click
Close()
End Class
