Op zoek naar Gaming PC
eerste is 6870 standaard versie, tweede rij is 6850 standaard versie dus misschien is die andere nog net iets sneller
Gebruikte driver versie Catalyst 11.1 Catalyst 11.1
3DMark Vantage (Performance) 17710 15216
3DMark11 - Performance 4225 3560
3DMark11 - Extreme 1424 1160
Heaven 2.0 DX11 [1920x1080 No tesselation] 52 fps 44,4 fps
Heaven 2.0 DX11 [1920x1080 Normal tesselation] 37,2 fps 31,6 fps
Heaven 2.0 DX11 [1920x1080 Extreme tesselation] 24,6 fps 21,0 fps
Far Cry 2 [1680x1050 - Very High] - Gemiddeld 104,8 fps 90,3 fps
Far Cry 2 [1680x1050 4xAA - Very High] - Gemiddeld 85,5 fps 74,8 fps
Far Cry 2 [1920x1080 - Very High] - Gemiddeld 97,2 fps 82,2 fps
Far Cry 2 [1920x1080 4xAA - Very High] - Gemiddeld 78,17 fps 67,9 fps
Resident Evil 5 [1680x1050 - High] - Gemiddeld 118,1 fps 104,1 fps
Resident Evil 5 [1680x1050 4xAA - High] - Gemiddeld 112 fps 98,3 fps
Resident Evil 5 [1920x1080 - High] - Gemiddeld 108,2 fps 93,8 fps
Resident Evil 5 [1920x1080 4xAA - High] - Gemiddeld 101,5 fps 88,9 fps
Street Fighter 4 [1680x1050 - High] - Gemiddeld 246 fps
Street Fighter 4 [1680x1050 4xAA - High] - Gemiddeld 152,2 fps
Street Fighter 4 [1920x1080 - High] - Gemiddeld 224,9 fps
Street Fighter 4 [1920x1080 4xAA - High] - Gemiddeld 138,8 fps
Tom Clancy's HAWX DX10(.1) [1680x1050 - High] - Gemiddeld 110 fps 96 fps
Tom Clancy's HAWX DX10(.1) [1680x1050 4xAA - High] - Gemidde 95 fps 85 fps
Tom Clancy's HAWX DX10(.1) [1920x1080 - High] - Gemiddeld 102 fps 88 fps
Tom Clancy's HAWX DX10(.1) [1920x1080 4xAA - High] - Gemidde 88 fps 78 fps
S.T.A.L.K.E.R. Call of Pripyat [1680x1050 Extreme] - Tessela 93 fps 65 fps
S.T.A.L.K.E.R. Call of Pripyat [1680x1050 4x AA Extreme] - T 45 fps 33 fps
S.T.A.L.K.E.R. Call of Pripyat [1920x1080 Extreme] - Tessela 82 fps 57 fps
S.T.A.L.K.E.R. Call of Pripyat [1920x1080 4x AA Extreme] - T 39 fps 29 fps
Metro 2033 DX11 [1680x1050, Normal] 38,3 fps 34,6 fps
Metro 2033 DX11 [1680x1050, Very High] 25,3 fps 22,3 fps
Metro 2033 DX11 [1920x1080, Normal] 34 fps 31,3 fps
Metro 2033 DX11 [1920x1080, Very High] 22 fps 19,6 fps
Just Cause 2 [1680x1050, Very High, 0x/16x] - Dark Tower 67 fps 56,5 fps
Just Cause 2 [1680x1050, Very High, 4x/16x] - Dark Tower 54 fps 49,1 fps
Just Cause 2 [1920x1080, Very High, 0x/16x] - Dark Tower 59,8 fps 50,4 fps
Just Cause 2 [1920x1080, Very High, 4x/16x] - Dark Tower 48,4 fps 42,2 fps
DiRT 2 [1680x1050, 0x AA - Ultra High] Gemiddeld 71,7 fps 62,9 fps
DiRT 2 [1680x1050, 4x AA - Ultra High] Gemiddeld 65,5 fps 57 fps
DiRT 2 [1920x1080, 0x AA - Ultra High] Gemiddeld 68 fps 58,6 fps
DiRT 2 [1920x1080, 4x AA - Ultra High] Gemiddeld 61,4 fps 53,8 fps
AvP DX11 [1680x1050, 0x AA - Very High] Gemiddeld 53,8 fps 43,8 fps
AvP DX11 [1680x1050, 4x AA - Very High] Gemiddeld 36,2 fps 30,3 fps
AvP DX11 [1920x1080, 0x AA - Very High] Gemiddeld 48,1 fps 39,2 fps
AvP DX11 [1920x1080, 4x AA - Very High] Gemiddeld 32,5 fps 27,2 fps
Stroomverbruik (systeem) - Idle 121 W 119 W
Stroomverbruik (systeem) - Far Cry 2 (max) 262 W 232 W
Stroomverbruik (systeem) - Metro 2033 (max) 253 W 236 W
Geluidsniveau (10 cm. - Full load) 58,7 dB(A) 52,1 dB(A)
Ik hoop dat je het beetje kan lezen
Haha, beetje onduidelijk :P
Maar er zit volgens mij niet zoveel verschil in... Alleen de FPS. Maar een paar FPS minder betekent nog lange geen lags toch?:)
Even een boel posts terug, valt me nu pas op :P
@firest0rm, assemblage, doet de winkel dat altijd? Zodat ik dat niet meer hoef te doen? Bij welke winkel kopen jullie je onderdelen? (Online?)
nee behalve als ze echt heel laag zitten. Over een jaar of meer komen er ook nieuwe games die echt zwaar zijn voor die kaart. Bij de 6870 hoef je hem pas later te vervangen. Meestal onder de 30 fps ga je het bij drukke spel momenten wel merken.
Dit is dus een beetje jou keuze wil je sneller upgrade of nu iets meer betalen. Over 1/2 jaar kan je het beter upgrade met jou budget.
Ik weet niet of ik dat al hier had verteld, maar je kan dan beter er voor zorgen dat je een goede cpu en moederbord hebt. Dat is duurder te upgrade als je dat snel moet doen. In vergelijking is een videokaart upgrade goedkoper.
Als moederbord zou ik dan toch eerder voor een MSI P67A-C45 (B3) gaan. Behalve natuurlijk als je budget daar te laag voor is.
Als dat niet lukt denk ik wel dat je met die samenstelling ene goede pc hebt voor dat bedrag. Waar je nog wat aan kan upgrade.
Mijn enigste vraagtekens staan nog even of er een micro atx in die kast past.
Ik heb mijn onderdelen bij salland gekocht, maar ik koop het eigenlijk waar het het goedkoopste is.
Assemblage kan de winkel wel doen, maar dit kost toch weer 50 tot 120 euro dacht ik. Bij azerty kost het € 120,-
Wat mag een micro ATX dan wel weer zijn? Een mini-moederbord??:confused:
Ja, hier een afbeelding van het formaat verschil. De gaatjes in de kast moeten goed zitten.
Even Gegoogled, op coolermaster.nl geweest. Cooler Master Elite 310 is zowel ATX als micro-ATX compatible ;)
Zit er nog een verschil in prijs in micro-ATX/ATX dan?
En die FPS onder de 30.... Zal wel meevallen. Als Ultra High niet wil, doe je toch gewoon High?
En nog steeds mijn vorige vraag: Zit er verschil in prijs tussen ATX en micro-ATX?
nee dit moet je er bij selecteren anders krijg je de onderdelen los
assemblage kost 35 tot 50 euro verschilt per winkel
@firest0rm - Ik heb nog die oude pc die kapot is, niet meer werkt. Is het de bedoeling dat na het in elkaar schroeven hij ook aan moet kunnen? Want dat kan die niet meer
ja een werkende pc is wel handig zo kan je zien of je de pc weer werkt nadat je hem inelkaar hebt gezet
micro atx is inderdaad wat goedkoper. Firestorm bij sommige winkels is het wel wat meer hoor. Als hij beetje technisch is kan hij ook zelf de pc in elkaar zetten. Goed de boekjes door kijken waar alle stekers in moeten voral op het moederbord. Hij kan hier anders ook altijd vragen. Het budget is niet al te hoog maar als je denkt dat je de pc gaat slopen zou ik het wel laten doen.
Hmm, ik heb ook nog zo'n USB voor draadloos internet.. Geen netwerkkaart nodig dan, toch?
Zou iemand voor mij een PC kunnen samenstellen met een Micro-ATX?
Blijkbaar gaat het sparen een stuk sneller dan verwacht :)
Kwam nog ong. 130 euro verjaardagsgeld tegen, verstopt :P
haha dat doe je goed xD
wat is het totale budget nu?
moet hier windows bij?
wie gaat de assemblage doen?
Het totale budget zal ik morgenavond posten ;) Dan weet ik het precieze budget.
Kan er een illegale Windows 7 versie op? Is dat makkelijk te doen vanaf een lege PC? Via BIOS/Setup ofzo?
Assemblage ga ik als het goed is zelf doen. Eerst nog even proberen met een oud Windows-98 PC :P
er kan altijd een illegale windows op hier moet je wel zelf aan zien te komen daar mogen wij niet bij helpen
verder is het budget wel erg van bellang als wij jou willen helpen dus even wachten dan maar
Oh,ik herinner me nog dat bij het illegale activeren, je het merk van je pc moet aanklikken... Wat zal ik dan moeten aanklikken? Het merk van m'n moederbord ofzo? :P
Weet iemand trouwens nog een goeie guide voor het in elkaar zetten van een PC?
eh we mogen helaas dus niet helpen met illegale software dit moe je zelf uitvogellen
Sorry, maar die persoon geeft alleen zijn mening, geen guide ;)
