/*! HTML5 Shiv v3.6 | @afarkas @jdalton @jon_neal @rem | MIT/GPL2 Licensed */
;(function(window, document) {
/*jshint evil:true */
/** Preset options */
var options = window.html5 || {};
/** Used to skip problem elements */
var reSkip = /^<|^(?:button|map|select|textarea|object|iframe|option|optgroup)$/i;
/** Not all elements can be cloned in IE (this list can be shortend) **/
var saveClones = /^<|^(?:a|b|button|code|div|fieldset|form|h1|h2|h3|h4|h5|h6|i|iframe|img|input|label|li|link|ol|option|p|param|q|script|select|span|strong|style|table|tbody|td|textarea|tfoot|th|thead|tr|ul)$/i;
/** Detect whether the browser supports default html5 styles */
var supportsHtml5Styles;
/** Name of the expando, to work with multiple documents or to re-shiv one document */
var expando = '_html5shiv';
/** The id for the the documents expando */
var expanID = 0;
/** Cached data for each document */
var expandoData = {};
/** Detect whether the browser supports unknown elements */
var supportsUnknownElements;
(function() {
try {
var a = document.createElement('a');
a.innerHTML = '<xyz></xyz>';
//if the hidden property is implemented we can assume, that the browser supports basic HTML5 Styles
supportsHtml5Styles = ('hidden' in a);
supportsUnknownElements = a.childNodes.length == 1 || (function() {
// assign a false positive if unable to shiv
(document.createElement)('a');
var frag = document.createDocumentFragment();
return (
typeof frag.cloneNode == 'undefined' ||
typeof frag.createDocumentFragment == 'undefined' ||
typeof frag.createElement == 'undefined'
} catch(e) {
supportsHtml5Styles = true;
supportsUnknownElements = true;
* Creates a style sheet with the given CSS text and adds it to the document.
* @private
* @param {Document} ownerDocument The document.
* @param {String} cssText The CSS text.
* @returns {StyleSheet} The style element.
function addStyleSheet(ownerDocument, cssText) {
var p = ownerDocument.createElement('p'),
parent = ownerDocument.getElementsByTagName('head')[0] || ownerDocument.documentElement;
p.innerHTML = 'x<style>' + cssText + '</style>';
return parent.insertBefore(p.lastChild, parent.firstChild);
* Returns the value of `html5.elements` as an array.
* @private
* @returns {Array} An array of shived element node names.
function getElements() {
var elements = html5.elements;
return typeof elements == 'string' ? elements.split(' ') : elements;
* Returns the data associated to the given document
* @private
* @returns {Object} An object of data.
function getExpandoData(ownerDocument) {
var data = expandoData[ownerDocument[expando]];
if (!data) {
data = {};
expanID++;
ownerDocument[expando] = expanID;
expandoData[expanID] = data;
return data;
* returns a shived element for the given nodeName and document
* @memberOf html5
* @param {String} nodeName name of the element
* @param {Document} ownerDocument The context document.
* @returns {Object} The shived element.
function createElement(nodeName, ownerDocument, data){
if (!ownerDocument) {
ownerDocument = document;
if(supportsUnknownElements){
return ownerDocument.createElement(nodeName);
if (!data) {
data = getExpandoData(ownerDocument);
var node;
if (data.cache[nodeName]) {
node = data.cache[nodeName].cloneNode();
} else if (saveClones.test(nodeName)) {
node = (data.cache[nodeName] = data.createElem(nodeName)).cloneNode();
} else {
node = data.createElem(nodeName);
// Avoid adding some elements to fragments in IE < 9 because
// * Attributes like `name` or `type` cannot be set/changed once an element
// is inserted into a document/fragment
// * Link elements with `src` attributes that are inaccessible, as with
// a 403 response, will cause the tab/window to crash
// * Script elements appended to fragments will execute when their `src`
// or `text` property is set
return node.canHaveChildren && !reSkip.test(nodeName) ? data.frag.appendChild(node) : node;
* returns a shived DocumentFragment for the given document
* @memberOf html5
* @returns {Object} The shived DocumentFragment.
function createDocumentFragment(ownerDocument, data){
return ownerDocument.createDocumentFragment();
data = data || getExpandoData(ownerDocument);
var clone = data.frag.cloneNode(),
i = 0,
elems = getElements(),
l = elems.length;
for(;i<l;i++){
clone.createElement(elems[i]);
return clone;
* Shivs the `createElement` and `createDocumentFragment` methods of the document.
* @private
* @param {Document|DocumentFragment} ownerDocument The document.
* @param {Object} data of the document.
function shivMethods(ownerDocument, data) {
if (!data.cache) {
data.cache = {};
data.createElem = ownerDocument.createElement;
data.createFrag = ownerDocument.createDocumentFragment;
data.frag = data.createFrag();
ownerDocument.createElement = function(nodeName) {
//abort shiv
if (!html5.shivMethods) {
return data.createElem(nodeName);
return createElement(nodeName, ownerDocument, data);
ownerDocument.createDocumentFragment = Function('h,f', 'return function(){' +
'var n=f.cloneNode(),c=n.createElement;' +
'h.shivMethods&&(' +
// unroll the `createElement` calls
getElements().join().replace(/\w+/g, function(nodeName) {
data.frag.createElement(nodeName);
return 'c("' + nodeName + '")';
');return n}'
)(html5, data.frag);
* Shivs the given document.
* @memberOf html5
* @param {Document} ownerDocument The document to shiv.
* @returns {Document} The shived document.
function shivDocument(ownerDocument) {
var data = getExpandoData(ownerDocument);
if (html5.shivCSS && !supportsHtml5Styles && !data.hasCSS) {
data.hasCSS = !!addStyleSheet(ownerDocument,
// corrects block display not defined in IE6/7/8/9
'article,aside,figcaption,figure,footer,header,hgroup,nav,section{display:block}' +
// adds styling not present in IE6/7/8/9
'mark{background:#FF0;color:#000}'
if (!supportsUnknownElements) {
shivMethods(ownerDocument, data);
return ownerDocument;
* The `html5` object is exposed so that more elements can be shived and
* existing shiving can be detected on iframes.
* @type Object
* @example
* // options can be changed before the script is included
* html5 = { 'elements': 'mark section', 'shivCSS': false, 'shivMethods': false };
var html5 = {
* An array or space separated string of node names of the elements to shiv.
* @memberOf html5
* @type Array|String
'elements': options.elements || 'abbr article aside audio bdi canvas data datalist details figcaption figure footer header hgroup mark meter nav output progress section summary time video',
* A flag to indicate that the HTML5 style sheet should be inserted.
* @memberOf html5
* @type Boolean
'shivCSS': (options.shivCSS !== false),
* Is equal to true if a browser supports creating unknown/HTML5 elements
* @memberOf html5
* @type boolean
'supportsUnknownElements': supportsUnknownElements,
* A flag to indicate that the document's `createElement` and `createDocumentFragment`
* methods should be overwritten.
* @memberOf html5
* @type Boolean
'shivMethods': (options.shivMethods !== false),
* A string to describe the type of `html5` object ("default" or "default print").
* @memberOf html5
* @type String
'type': 'default',
// shivs the document according to the specified `html5` object options
'shivDocument': shivDocument,
//creates a shived element
createElement: createElement,
//creates a shived documentFragment
createDocumentFragment: createDocumentFragment
// expose html5
window.html5 = html5;
// shiv the document
shivDocument(document);
}(this, document));
