beste helpforum,
ik heb het spel call of juarez geinstaleerd, maar als ik nu op de snelkoppeling klik wil het spel niet opstarten. Ik krijg de volgende boodschap: Crashexit - the thread attempted to read from or write to a virtual address for which it does not have the appropriate access. ik heb windows vista 32 bit en mijn pc voldoet aan alle systeem eisen van het spel.Weet iemand wat ik kan doen om dit te verhelpen?
groeten ruben
hier is de data van de error:
[PID] 3280
[CRTTI::AddInterface] Interface <javax.swing.event.InternalFrameListener> not found
[CRTTI::AddInterface] Interface <javax.swing.event.ChangeListener> not found
[CRTTI::AddInterface] Interface <javax.swing.event.DocumentListener> not found
[CRTTI::AddInterface] Interface <javax.swing.event.ListSelectionListener> not found
[CRTTI::AddInterface] Interface <javax.swing.event.TreeSelectionListener> not found
WARNING: cannot find attribute described by fRangeInfo in class FXProximityEmitter
WARNING: cannot find attribute described by fFadeInOutTextInfo in class InstantFadeInOut
[CFactory::CreateObject] WARNING! object of class <LawmanGame> creator_level==NULL!
[CFactory::CreateObject] WARNING! object of class <SecretsManager> creator_level==NULL!
[CPU] vendor: GenuineIntel, features: FPU CMOV TSC MMX SSE SSE2 SSE3, clock frequency: 1995.00MHz
[CFactory::CreateObject] WARNING! object of class <Renderer> creator_level==NULL!
D3DRenderer: supported display modes:
320x200, bpp:16, hz:60, fmt: R5G6B5, widescreen: yes
320x200, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: yes
320x240, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
320x240, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
400x300, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
400x300, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
512x384, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
512x384, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
640x400, bpp:16, hz:60, fmt: R5G6B5, widescreen: yes
640x400, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: yes
640x480, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
640x480, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
800x600, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
800x600, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
1024x768, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
1024x768, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
1280x600, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
1280x600, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
1280x720, bpp:16, hz:60, fmt: R5G6B5, widescreen: yes
1280x720, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: yes
1280x768, bpp:16, hz:60, fmt: R5G6B5, widescreen: no
1280x768, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: no
1280x800, bpp:16, hz:60, fmt: R5G6B5, widescreen: yes
1280x800, bpp:24, hz:60, fmt: X8R8G8B8, widescreen: yes
VendorDesc: Mobile Intel(R) 965 Express Chipset Family
VendorID: 32902
DeviceID: 10754
Driver: igdumd32.dll, version: 7.14.10.1409
TweakFlags: 0
VarScripted loaded: data/varlist.scr!
LAWMAN Validating settings... OK
VendorID: 32902
DeviceID: 10754
TweakFlags: 0
D3DRenderer: display mode chosen:
resolution: 1024x768, refresh: 60Hz, fsaa: 0
frame buffer: color_bits: 24, alpha_bits: 0, format: X8R8G8B8
back buffer: color_bits: 24, alpha_bits: 8, format: A8R8G8B8
depth buffer: depth_bits: 24, stencil_bits: 0, format: D24X8
[CD3DRenderer::Initialize] Create device error D3DERR_NOTAVAILABLE
FATAL ERROR: cannot initialize Direct3D device!
D3DERR_NOTAVAILABLE
VendorID: 32902
DeviceID: 10754
TweakFlags: 0
D3DERR_NOTAVAILABLE
*** Exception ***
The thread attempted to read from or write to a virtual address for which it does not have the appropriate access.
groeten ruben
[PID] 3280
VendorID: 32902
DeviceID: 10754
TweakFlags: 0
VendorID: 32902
DeviceID: 10754
TweakFlags: 0
D3DERR_NOTAVAILABLE
VendorID: 32902
DeviceID: 10754
TweakFlags: 0
D3DERR_NOTAVAILABLE
*** Exception ***
