embedded radio maken
phobia
4 sep 2006
waarom kan ik zo
href="mms://81.173.21.65/a12fm"
de stream wel laten openen in een mediaplayer
maar zo niet?
<SCRIPT language=JavaScript>
													if ( navigator.appName == "NETSCAPE" )
														//-- This next line ensures that any plugins just installed are updated in the Browser
														//-- without quitting the browser.
														navigator.plugins.refresh();
														// We don't need the APPLET within IE
														// ***Please note that if you do not need to script events, you can safely remove the next two lines
														document.write("\x3C" + "applet MAYSCRIPT Code=NPDS.npDSEvtObsProxy.class")
														document.writeln(" width=5 height=5 name=appObs\x3E \x3C/applet\x3E")
											</SCRIPT>
											 <!-- Set ShowControls, ShowDisplay, ShowStatusBar to value 0 to not display the corresponding thing under the video window -->
													<object id="MediaPlayer" width=165 height=20 standby="A12 FM" type="application/x-oleobject">
														<param name="FileName" value="mms://81.173.21.65/a12fm">
														<PARAM NAME="AudioStream" VALUE="-1">
														<param name="TransparentAtStart" value="true">
														<param name="AutoStart"          value="true">
														<param name="AnimationatStart"   value="false">
														<param name="ShowStatusBar"      value="true">
														<param name="ShowControls"       value="true">
														<param name="autoSize"           value="false">
														<param name="ShowPositionControls" value="false">
														<param name="displaySize"        value="0">
														<param name="AudioStream"        value="true">
														<embed type="application/x-mplayer2" pluginspage="http://www.microsoft.com/isapi/redir.dll?prd=windows&sbp=mediaplayer&ar=Media&sba=Plugin&" src="mms://wm.rtl.nl/yorinfm" autostart=1 width=200 height=20 transparentatstart=0 animationatstart=0 showcontrols=0 showstatusbar=1 autosize=0 displaysize=0 audiostream=1>
												</embed>
												</OBJECT>
ik wil de radio op de site zelf laten spelen.
Hoi phobia,
In het <embed> element zit een
  • src="mms://wm.rtl.nl/yorinfm"
i.p.v.
  • src="mms://81.173.21.65/a12fm"
Is dat het?
Met vriendelijke groet,
CSShunter
