foutmelding soldier of fortune
jamba
8 sep 2000
Ik heb soldier of fortune 2 geinstalleerd. Nu krijg ik bij het opstarten echter een foutmelding en wel de volgende, weet iemand een oplossing?
SOF2 0.13 win-x86 Feb 21 2002
Initialising zone memory .....
------- Filesystem Initialization --------
Current search path:
c:/progra~1/soldie~1/base/therest.pk3 (8176 files)
c:/progra~1/soldie~1/base/textures1234.pk3 (10528 files)
c:/progra~1/soldie~1/base/textures0.pk3 (2837 files)
c:/progra~1/soldie~1/base/skins.pk3 (3333 files)
c:/progra~1/soldie~1/base/musicandsound.pk3 (3499 files)
c:/progra~1/soldie~1/base/mp.pk3 (392 files)
c:/progra~1/soldie~1/base/models.pk3 (4096 files)
c:/progra~1/soldie~1/base/maps.pk3 (457 files)
C:\PROGRA~1\SOLDIE~1/base
33318 files in pk3 files
couldn't exec myconfig.cfg
couldn't exec autoexec.cfg
---------- Getting System Info -----------
OS: Microsoft WinXP Service Pack 2 (NT)
RDTSC instruction supported
SSE enabled processor
Pentium III / Xeon (model 7) running at 545 MHz
127MB physical memory available
couldn't exec scalability/user_Derk.cfg
--------- Client Initialization ----------
Loading renderer.....
--------- Initializing Renderer ----------
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
Error during initialization SYSTEM ERROR
Ik heb Nvidia geinstalleerd en gedraaid. die kon echter geen drivers vinden die compatible zijn met de hardware op mijn computer. Wat kan ik nog meer doen?
Heb je wel een Nvidia grafische kaart?
Het kan ook zijn dat je een ander merkt hebt, of begrijp ik je nu verkeerd?
klopt, dat bedacht ik me ook toen ik de software had gedownload. Ik heb volgens mij een 3dfx voodoo3, kan dat? of is dat weer een andere kaart?
ik vind dat bij devicemanager\display adapters
Is dat de goede? zo ja: Ik heb daarvan nog geen nieuwe drivers kunnen vinden op internet. Hoe kan ik die vinden?
Ik heb een bestand met drivers gevonden, genaamd :v3_4_5win2kXP1.08-xp
Ik heb het geinstalleerd maar het werkt niet. Het is een programma 3dfx tools met drie opties:
3dfx hub
3dfx manager
3dfx taskman icons
als ik hub doe gebeurt er niets en als ik de manager opstart krijg ik een venster waarin ik alleen oken apply kan drukken maar ook dan gebeurt er niets.
