Hulp nodig bij VBA code Access
Fuser149
13 feb 2012
Ik ben bezig voor het werk met het maken van een database en wil gegevens uit de database automatisch in outlook agenda laten verschijnen. Ik heb volgende code op het internet gevonden maar ik krijg steeds de foutmelding: ongeldig gebruik van het sleutelwoord ME... Ik ken zelf niets van programmeertaal dus zou iemand me kunnen helpen? Alvast bedankt!
 Private Sub btnAddApptToOutlook_Click()
'On Error GoTo ErrHandle
    Dim olNS As Object
    Dim olApptFldr As Object
    ' Save the Current Record
    If Me.Dirty Then Me.Dirty = False
    ' Exit the procedure if appointment has been added to Outlook.
    If Me.chkAddedToOutlook = True Then
        MsgBox "This appointment has already added to Microsoft Outlook.", vbCritical
        Exit Sub
    Else
        ' Use late binding to avoid the "Reference" issue
        Dim olApp As Object        'Outlook.Application
        Dim olAppt As Object        'olAppointmentItem
        'This is how we would do it if we were using "early binding":
'        Dim olApp As Outlook.Application
'        Dim olappt As Outlook.AppointmentItem
'        Set olapp = CreateObject("Outlook.Application")
'        Set olappt = olapp.CreateItem(olAppointmentItem)
        If isAppThere("Outlook.Application") = False Then
            ' Outlook is not open, create a new instance
            Set olApp = CreateObject("Outlook.Application")
        Else
            ' Outlook is already open--use this method
            Set olApp = GetObject(, "Outlook.Application")
        Set olAppt = olApp.CreateItem(1) ' 1 = olAppointmentItem
        ' Add the Form data to the Appointment Properties
        With olAppt
            If Nz(Me.chkAllDayEvent) = True Then
                .AllDayEvent = True
                ' Format the dates in the Form Controls
                Me.txtStartDate = FormatDateTime(Me.txtStartDate, vbShortDate)
                Me.txtEndDate = FormatDateTime(Me.txtEndDate, vbShortDate)
                ' For all day events use "" for the start time and the end time
                Me.cboStartTime = ""
                Me.cboEndTime = ""
                ' Get the Start and the End Dates
                Dim dteTempEnd As Date
                Dim dteStartDate As Date
                Dim dteEndDate As Date
                dteStartDate = CDate(FormatDateTime(Me.txtStartDate, vbShortDate)) ' Begining Date of appointment
                dteTempEnd = CDate(FormatDateTime(Me.txtEndDate, vbShortDate))      ' Use to compute End Date of appointment
                ' Add one day to dteEndDate so Outlook will set the number of days correctly
                dteEndDate = DateSerial(Year(dteTempEnd + 1), Month(dteTempEnd + 1), Day(dteTempEnd + 1))
                .Start = dteStartDate
                .End = dteEndDate
                ' Set the number of minutes for each day in the AllDayEvent Appointment
                Dim lngMinutes As Long
                lngMinutes = CDate(Nz(dteEndDate)) - CDate(Nz(dteStartDate))
                ' The duration in Minutes, 1440 per day
                lngMinutes = lngMinutes * 1440
                ' Add the minutes to the Access Form
                Me.txtApptLength.value = lngMinutes
                .Duration = lngMinutes
            Else
                ' The Validation Rule for the Start Date TextBox requires a
                ' Start Date so there is no need to check for it here
                If Len(Me.cboStartTime & vbNullString) = 0 Then
                    ' There is no end time on the Form
                    ' Add vbNullString ("") to avoid an error
                    Me.cboStartTime = vbNullString
                ' Set the Start Property Value
                .Start = FormatDateTime(Me.txtStartDate, vbShortDate) _
                   & " " & FormatDateTime(Me.cboStartTime, vbShortTime)
                ' If there is no End Date on the Form just skip it
                If Len(Me.txtEndDate & vbNullString) > 0 Then
                    If Len(Me.cboEndTime & vbNullString) = 0 Then
                        Me.cboEndTime = vbNullString
                    Else
                        ' Set the End Property Value
                        .End = FormatDateTime(Me.txtEndDate, vbShortDate) _
                           & " " & FormatDateTime(Me.cboEndTime, vbShortTime)
                If Len(Me.txtApptLength & vbNullString) = 0 Then
                    Dim timStartTime As Date
                    Dim timEndTime As Date
                    ' Format the Start Time and End Time
                    timStartTime = FormatDateTime(Me.txtStartDate, vbShortDate) _
                    timEndTime = FormatDateTime(Me.txtEndDate, vbShortDate) _
                    .Duration = Me.txtApptLength
            If Nz(Me.chkAllDayEvent) = False Then
                .AllDayEvent = False
            If Len(Me.cboApptDescription & vbNullString) > 0 Then
                .Subject = Me.cboApptDescription
            If Len(Me.txtApptNotes & vbNullString) > 0 Then
                .Body = Me.txtApptNotes
            If Len(Me.txtLocation & vbNullString) > 0 Then
                .Location = Me.txtLocation
            If Me.chkApptReminder = True Then
                If IsNull(Me.txtReminderMinutes) Then
                    Me.txtReminderMinutes.value = 30
                .ReminderOverrideDefault = True
                .ReminderMinutesBeforeStart = Me.txtReminderMinutes
                .ReminderSet = True
            ' Save the Appointment Item Properties
            .Save
        ' Set chkAddedToOutlook to checked
        ' Save the Current Record because we checked chkAddedToOutlook
        ' Inform the user
        MsgBox "New Outlook Appointment Has Been Added!", vbInformation
ExitHere:
    ' Release Memory
    Set olApptFldr = Nothing
    Set olNS = Nothing
    Set olAppt = Nothing
    Set olApp = Nothing
    Exit Sub
ErrHandle:
    MsgBox "Error " & Err.Number & vbCrLf & Err.Description _
    & vbCrLf & "In procedure btnAddApptToOutlook_Click in Module Module1"
    Resume ExitHere
' Procedure : isAppThere
' Author    : Rick Dobson, Ph.D - Programming Microsoft Access 2000
' Purpose   : To check if an Application is Open
' Arguments : appName The name of the Application
' Example   : isAppThere("Outlook.Application")
Function isAppThere(appName) As Boolean
On Error Resume Next
    Dim objApp As Object
    isAppThere = True
    Set objApp = GetObject(, appName)
    If Err.Number <> 0 Then isAppThere = False
End Function
Doe ons een lol, en maak bovenstaande code eerst eens op met de CODE tag (knop met #); zo is er geen beginnen aan...
Je geeft een beetje weinig informatie; om te beginnen: waar heb je deze code neergezet? In een aparte module, of op je formulier? En de volgende vraag: in welke regel krijg je de foutmelding?
Ik heb de code in een aparte module gestoken en ik krijg foutmelding bij volgende regel:
ik ken echt niks van VBA HELP :)
Daar ga je inderdaad al in de fout: de code werkt alleen op het formulier dat je gebruikt. Als je alles verplaatst naar het formulier zou het al een stuk beter moeten gaan. Verder heb je nog een aantal tekstvelden nodig die de juiste naam moeten hebben. Die heb ik even voor je in een tabelletje gezet:
Me.chkAllDayEvent .AllDayEvent
Me.txtStartDate .Start
Me.txtEndDate .End
Me.cboStartTime .Start
Me.cboEndTime .End
Me.txtApptLength .Duration
Me.cboApptDescription .Subject
Me.txtApptNotes .Body
Me.txtLocation .Location
Me.txtReminderMinutes .ReminderMinutesBeforeStart
