adacadabra voor mij maar ik hoop dat dit is wat je bedoelt? EN Bennie....weet jij ook hoe je drivers moet updaten en waar vindt ik die?
SiSoftware Sandra
System Mainboard
Manufacturer : Giga-Byte Technology Co., LTD
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : 8IDX
Version : 1.x
BIOS ID : 11/15/2001-8IDX-6A69VG0CC-00
System Chipset : Intel 845 (Brookdale) Chipset
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 768MB
Bank0/1 - A0 : None None None None DIMM WDRAM 512MB/64
Bank2/3 - A1 : Empty
Bank4/5 - A2 : Empty
System Chipset
Model : Intel Corporation 82845 Brookdale Host-Hub Interface Bridge (A3-step)
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 SMBus/i2c
Front Side Bus Speed : 4x 100MHz (400MHz data rate)
Max FSB Speed / Max Memory Speed : 4x 100MHz / 1x 133MHz
In Order Queue Depth : 12 req(s)
Chipset Hub Interface
Type : HubInterface
Version : 1.00
No. Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1x
Speed : 4x 66MHz (264MHz data rate)
APIC 1
Version : 2.00
Speed : 17MHz
Multiplier : 1/2x
Max Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : No
Logical/Chipset Memory Banks
Bank 0 Setting : 512MB SDRAM 8-1-1-1R 6-1-1-1W 3-3-3CL
Speed : 1x 133MHz (133MHz data rate)
Multiplier : 1.33x
Refresh Rate : 7.80µs
Power Down Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : 512MB 16x(64Mx4) SDRAM PC133U-333-542 (CL3 upto 133MHz) (CL2 upto 100MHz)
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 25.0°C / 77.0°F
CPU Temperature : 26.0°C / 78.8°F
Power / Aux Temperature : 46.0°C / 114.8°F td
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 4327rpm
Voltage Sensor(s)
CPU Core Voltage : 1.70V
Aux Voltage : 1.79V
+3.3V Voltage : 3.39V
+5V Voltage : 5.05V
+12V Voltage : 11.36V
-12V Voltage : -11.70V
-5V Voltage : -5.41V
Standby Voltage : 5.05V
Battery Voltage : 0.26V
AGP Bus
Version : 2.00
Speed : 66MHz
Current Data Transfer Rate : 4x 66MHz (264MHz data rate)
Side Band Enabled : No
Side Band Support : Yes
Fast-Writes Enabled : Yes
Aperture Size : 64MB
PCI Bus(es)
Version : 2.20
No Bridges : 2
PCI Bus 0 : PCI (33MHz)
PCI Bus 2 : PCI (33MHz)
Multiplier : 1/3x
LPC Hub Controller 1
Model : Intel Corporation 82801BA (ICH2) LPC Interface Controller
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Random Number Generator Support : Yes
USB Controller 1
Model : Intel Corporation 82801BA/BAM (ICH2/ICH2-M) USB Universal Host Controller
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.10
Channels : 2
Speed : 48MHz
FireWire/1394 Controller 1
Model : Pinnacle Systems Inc Studio DV
Version : 1.00
OHCI Interface : Yes
Enhanced 1394a Support : No
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : Intel 801xx SMBus
Version : 1.02
Speed : 16kHz
Expansion Slot(s)
PCI : PCI 32-bit 5V FullLength InUse
PCI (1h) : PCI 32-bit 5V FullLength InUse (Intel Corporation 82845 Brookdale Host-AGP Bridge (A3-step))
PCI (2h) : PCI 32-bit 5V FullLength InUse
PCI (3h) : PCI 32-bit 5V FullLength Available
PCI (4h) : PCI 32-bit 5V FullLength InUse
PCI (5h) : PCI 32-bit 5V FullLength Available
AGP (8h) : AGP 32-bit 5V FullLength InUse (Nvidia Corp GeForce2 MX 100/200 (DDR) [NV11DDR])
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO Compatible - Floppy / None
COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
Keyboard : Keyboard Port - None / PS/2
PS/2 Mouse - Detected : Mouse Port - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2545 : Large memory modules should be Registered/Buffered.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
SiSoftware Sandra
Computer System
Processor(s)
Model : Intel(R) Pentium(R) 4 CPU 1700MHz
Speed : 1.70GHz
Performance Rating : PR1870 (estimated)
Type : Standard
L2 On-board Cache : 256kB ECC synchronous ATC
System Mainboard
System BIOS : Award Software International, Inc. 6.00 PG
System Mainboard : Giga-Byte Technology Co., LTD 8IDX
System Chipset : Intel Corporation 82845 Brookdale Host-Hub Interface Bridge (A3-step)
Installed Memory : 512MB SDRAM
Memory Bus Speed : 1x 133MHz (133MHz data rate)
Video System
Monitor/Panel : Philips 107E (17-inch/CM2600)
Adapter : NVIDIA GeForce2 MX 100/200
Physical Storage Devices
Removable Drive : Diskettestation
Disk Drive : ST360021A
CD-ROM/DVD : LITE-ON LTR-16102B
CD-ROM/DVD : PIONEER DVD-ROM DVD-106
Logical Storage Devices
1.44MB 3.5" (A
: N/A
Hard Disk (C
: 9.5GB (5.4GB, 57% Free) (NTFS)
Hard Disk (D
: 13.9GB (10.8GB, 77% Free) (FAT32)
Hard Disk (E
: 32.5GB (27.9GB, 86% Free) (NTFS)
CD-ROM/DVD (F
: N/A
CD-ROM/DVD (G
: N/A
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : Intel(r) 82801BA/BAM USB universele host-controller - 2442
USB Controller/Hub : Intel(r) 82801BA/BAM USB universele host-controller - 2444
USB Controller/Hub : USB-hoofdhub
USB Controller/Hub : General purpose USB Hub
USB Controller/Hub : Philips Composite USB-apparaat
FireWire/1394 Controller : Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Keyboard : Standaardtoetsenbord (101/102 toetsen) of Microsoft Natural PS/2-toetsenbord
Mouse : PS/2-compatibele muis
MultiMedia Device(s)
Device : Creative SB Live!-reeks (WDM)
Device : Creative SB Live!-spelpoort
Printers and Faxes
Model : HP DeskJet 840C/841C/842C/843C
Operating System(s)
Windows System : Microsoft Windows XP Home Ver 5.01.2600 Service Pack 1
Network Adapter(s)
Networking Installed : Yes
Adapter : CNet PRO200 PCI Fast Ethernet Adapter
