Pull functie van Harlan Grove
DCWDPT
16 mrt 2009
Kan iemand mij aan de Pull-functie geschreven door Harlan Grove helpen? Ik heb zelf gezocht op het internet, maar ik kan alleen een verwijzing vinden naar een ftp-server (ftp://members.aol.com/hrlngrv/pull.zip). Maar daar kan ik het niet van downloaden. Heeft iemand een alternatief?
Function pull(xref As String) As Variant
  'inspired by Bob Phillips and Laurent Longre
  'but written by Harlan Grove
  'Copyright (c) 2003 Harlan Grove.
  'This code is free software; you can redistribute it and/or modify
  'it under the terms of the GNU General Public License as published
  'by the Free Software Foundation; either version 2 of the License,
  'or (at your option) any later version.
  '2004-05-30
  'still more fixes, this time to address apparent differences between
  'XL8/97 and later versions. Specifically, fixed the InStrRev call,
  'which is fubar in later versions and was using my own hacked version
  'under XL8/97 which was using the wrong argument syntax. Also either
  'XL8/97 didn't choke on CStr(pull) called when pull referred to an
  'array while later versions do, or I never tested the 2004-03-25 fix
  'against multiple cell references.
  '2004-05-28
  'fixed the previous fix - replaced all instances of 'expr' with 'xref'
  'also now checking for initial single quote in xref, and if found
  'advancing past it to get the full pathname [dumb, really dumb!]
  '2004-03-25
  'revised to check if filename in xref exists - if it does, proceed;
  'otherwise, return a #REF! error immediately - this avoids Excel
  'displaying dialogs when the referenced file doesn't exist
  Dim xlapp As Object, xlwb As Workbook
  Dim b As String, r As Range, C As Range, n As Long
  '** begin 2004-05-30 changes **
  '** begin 2004-05-28 changes **
  '** begin 2004-03-25 changes **
  n = InStrRev(xref, "\")
  If n > 0 Then
    If Mid(xref, n, 2) = "\[" Then
      b = Left(xref, n)
      n = InStr(n + 2, xref, "]") - n - 2
      If n > 0 Then b = b & Mid(xref, Len(b) + 2, n)
    Else
      n = InStrRev(Len(xref), xref, "!")
      If n > 0 Then b = Left(xref, n - 1)
    '** key 2004-05-28 addition **
    If Left(b, 1) = "'" Then b = Mid(b, 2)
    On Error Resume Next
    If n > 0 Then If Dir(b) = "" Then n = 0
    Err.Clear
    On Error GoTo 0
  If n <= 0 Then
    pull = CVErr(xlErrRef)
    Exit Function
  '** end 2004-03-25 changes **
  '** end 2004-05-28 changes **
  pull = Evaluate(xref)
  '** key 2004-05-30 addition **
  If IsArray(pull) Then Exit Function
  '** end 2004-05-30 changes **
  If CStr(pull) = CStr(CVErr(xlErrRef)) Then
    On Error GoTo CleanUp   'immediate clean-up at this point
    Set xlapp = CreateObject("Excel.Application")
    Set xlwb = xlapp.Workbooks.Add  'needed by .ExecuteExcel4Macro
    On Error Resume Next    'now clean-up can wait
    n = InStr(InStr(1, xref, "]") + 1, xref, "!")
    b = Mid(xref, 1, n)
    Set r = xlwb.Sheets(1).Range(Mid(xref, n + 1))
    If r Is Nothing Then
      pull = xlapp.ExecuteExcel4Macro(xref)
    Else
      For Each C In r
        C.Value = xlapp.ExecuteExcel4Macro(b & C.Address(1, 1, xlR1C1))
      Next C
      pull = r.Value
CleanUp:
    If Not xlwb Is Nothing Then xlwb.Close 0
    If Not xlapp Is Nothing Then xlapp.Quit
    Set xlapp = Nothing
End Function
Edit: rdg1314 was me al voor. Ik word traag.
Met vriendelijke groet,
Roncancio
Warme bakkertje, rdg1314 en Roncancio,
Al vast enorm bedankt voor jullie reacties. Ik denk dat ik hiermee wel verder zal komen. En anders zien jullie me zeker weer terug met een vraag op het forum.
Ik heb nu eerst 4 weken vakantie, dus vanaf 17 augustus werk ik verder aan mijn bestand. Ik laat de vraag nog een tijdje open staan om te zien of ik nog meer reacties krijg. Dat zie ik dan na mijn vakantie wel.
Veel plezierige Exceltijd en tot later.
:thumb: :)
Prettig verlof:thumb::thumb::thumb:
