Soldier front veroorzaakt BSOD
ExtraBB
19 apr 2009
hoi,
elke keer als ik soldier front opstart krijg ik een BSOD.
Ik gebruik de windows 7 RC maar ik weet dat mensen met vista en xp ook last van dit probleem hebben,
hier de crashdump:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Bruno\Desktop\051209-38454-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
Windows 7 Kernel Version 7100 MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7100.0.x86fre.winmain_win7rc.090421-1700
Machine Name:
Kernel base = 0x82803000 PsLoadedModuleList = 0x8294b810
Debug session time: Tue May 12 20:54:04.275 2009 (GMT+2)
System Uptime: 0 days 5:46:12.428
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \??\C:\ijji\ENGLISH\u_sf\GameGuard\dump_wmimmc.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dump_wmimmc.sys
*** ERROR: Module load completed but symbols could not be loaded for dump_wmimmc.sys
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, a67587ec, 8dd81980, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : dump_wmimmc.sys ( dump_wmimmc+357ec )
Followup: MachineOwner
Kunnen jullie me helpen?
alvast bedankt,
Bruno
ziet er toch naar uit dat soldier front problemen heeft met windows 7.
aangezien hij verschillende errors geeft die iets met OS symbols te maken hebben.
zeker weet ik het niet dus mss kun je beter w8en op een andere reactie.
