Robbinski12
- 7 apr 2008
Hallo allemaal,
Kan iemand mij helpen met mijn query??
[SQL]SELECT * FROM `users` WHERE `username`='1' AND `password`='2' INNER JOIN `sites` ON `sites`.`id`=`users`.`siteid`[/SQL]
Dit is de error: "#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'INNER JOIN `sites` ON `sites`.`id`=`users`.`siteid` LIMIT 0, 30' at line 1"
Alvast bedankt!
Robin
Alvast bedankt!
Robin
