Farcry:
Minimum System Requirements Single Player Only
- Computer: AMD Athlon 1 GHz or Pentium III 1 Ghz (AMD Athlon XP 2000 / Pentium 4 2 Ghz recommended)
- Operating System: FarCry is supported on the following operating systems: Windows 98SE, Windows ME, Windows 2000, and Windows XP.
- Memory: The game requires 256 MB of RAM.
- Controls: A keyboard and mouse are required
- Drives: 4 Gb of free space on hard disc are required to install and play the game. 4x DVD or 16x CDROM is required to install the game.
- Video: A 3D accelerator video card with support for DirectX® 9.0b and at least 64 MB of video memory is required.
- Sound: A DirectX®-compatible 16-bit PCI sound card is recommended.
For Multiplayer play only the following configurations are supported
Recommended System Requirements
- Computer: A 2 GHz AMD processor or better is recommended.
- Memory: We recommend 512 MB of RAM
- Drives: 4 Gb of free space on hard disc are required to install and play the game. 8x DVD or 32x CDROM is recommended to install the game.
- Video: A 3D accelerator video card with support for DirectX® 9.0b and at least 128 MB of video memory is recommended
- Multiplayer Connectivity: Access to UBI.com online gaming service, requires a low-latency, active Internet connection, rated at 64 Kbps upstream or faster. Multiplayer games played over a LAN require an active connection to a TCP/IP network. We recommend the use of cable or ADSL connection with 512 Kb/s in downstream and 128 kb/s in upstream.
High System Requirements
- Computer: A 3 GHz AMD processor or better is recommended.
- Memory: We recommend 1024 MB of RAM
- Drives: 4 Gb of free space on hard disc are required to install and play the game. 16x DVD or 32x CDROM is recommended to install the game.
- Multiplayer Connectivity: We recommend the use of cable or ADSL connection with 512 Kb/s in downstream and 128 kb/s in upstream.
Multiplayer Server Requirements
Dedicated Server
- Computer: A 2.4 GHz AMD processor or better is recommended.
Non Dedicated Server:
Computer: A 2.8 Ghz AMD processor is recommended
Memory: We recommend 1 Gb of RAM, however we do not recommend connecting many players to a non-dedicated server.
COD4
systeem eisen:
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Lijkt mij allemaal geen probleem.
