in de systemroot map (c/windows)
was ook een minidump.DMP file
daar kreeg ik de volgende LOG uit
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 6001.18226.amd64fre.vistasp1_gdr.090302-1506
Machine Name:
Kernel base = 0xfffff800`0285d000 PsLoadedModuleList = 0xfffff800`02a22db0
Debug session time: Sun May 24 22:44:09.011 2009 (GMT+2)
System Uptime: 0 days 0:27:03.928
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`7efdf018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {ffffffffffffff8b, 1, fffff960001ba6ed, 0}
Page bc782 not present in the dump file. Type ".hh dbgerr004" for details
*** ERROR: Symbol file could not be found. Defaulted to export symbols for win32k.sys -
Page 15ffb5 not present in the dump file. Type ".hh dbgerr004" for details
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Page 1737cb not present in the dump file. Type ".hh dbgerr004" for details
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : win32k.sys ( win32k!W32pArgumentTable+5db1 )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: ffffffffffffff8b, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff960001ba6ed, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: win32k
FAULTING_MODULE: fffff8000285d000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 498fa36b
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
ffffffffffffff8b
FAULTING_IP:
fffff960`001ba6ed ff488b dec dword ptr [rax-75h]
MM_INTERNAL_CODE: 0
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff800028c0671 to fffff800028b1650
STACK_TEXT:
fffffa60`0c838918 fffff800`028c0671 : 00000000`00000050 ffffffff`ffffff8b 00000000`00000001 fffffa60`0c838a10 : nt!KeBugCheckEx
fffffa60`0c838920 fffff800`028b01d9 : 00000000`00000001 fffffa80`06adbbb0 00000000`74a43300 00000000`0026e1b0 : nt!ExReleaseResourceLite+0x1391
fffffa60`0c838a10 fffff960`001ba6ed : 00000000`0026e1b0 fffffa60`0c838ca0 00000000`00000000 fffff800`028bf172 : nt!ZwUnloadKeyEx+0x11b9
fffffa60`0c838ba0 00000000`0026e1b0 : fffffa60`0c838ca0 00000000`00000000 fffff800`028bf172 fffffa60`0c838bc8 : win32k!W32pArgumentTable+0x5db1
fffffa60`0c838ba8 fffffa60`0c838ca0 : 00000000`00000000 fffff800`028bf172 fffffa60`0c838bc8 fffffa60`0c838ca0 : 0x26e1b0
fffffa60`0c838bb0 00000000`00000000 : fffff800`028bf172 fffffa60`0c838bc8 fffffa60`0c838ca0 00000000`00000001 : 0xfffffa60`0c838ca0
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: win32k!W32pArgumentTable+5db1
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: win32k.sys
BUCKET_ID: WRONG_SYMBOLS
